| Need help getting clutch side grip part off | |
trevski Member
| Subject: Need help getting clutch side grip part off Tue Sep 05, 2017 3:00 pm | |
| Hi guys, I have managed to get the handle bars off and all parts apart from the chrome part that is at the end of the grip. So I have the end weight off, the grip off but then its just the last part that makes the grips off. I need to get this off so I can take off the clutch lever and then so I can clean it and spray it black. Any tips? | |
| Subject: Re: Need help getting clutch side grip part off Tue Sep 05, 2017 8:19 pm | |
| I just slid a thin screwdriver underneath and worked it round to loosen the glue. | |
| | | trevski Member
| Subject: Re: Need help getting clutch side grip part off Tue Sep 05, 2017 9:58 pm | |
| - simbo wrote:
- I just slid a thin screwdriver underneath and worked it round to loosen the glue.
Was that for the grip or the metal end? The part between the grip and the lever | |
| Subject: Re: Need help getting clutch side grip part off Tue Sep 05, 2017 10:08 pm | |
| A squirt of WD40 can also help once you've got that fine screwdriver inserted between the handlebars & the grip. The little red plastic 'capillary' tube that comes with WD40 is ideal for injecting the fluid on the glue interface. ...... then apply rotational twisting action in alternate directions - it should loosen off the grip. | |
| Subject: Re: Need help getting clutch side grip part off Tue Sep 05, 2017 10:32 pm | |
| - trevski wrote:
Was that for the grip or the metal end? The part between the grip and the lever You mean the decorative plastic chrome trim at the inner end of the rubber grip, if so? give it a firm twist, it's only held on with an evostick type glue, it should have come of with the rubber part. | |
| | | trevski Member
| Subject: Re: Need help getting clutch side grip part off Wed Sep 06, 2017 2:19 pm | |
| Yea it is that part but annoyingly only the rubber part came off :( | |
| Subject: Re: Need help getting clutch side grip part off Wed Sep 06, 2017 6:42 pm | |
| - trevski wrote:
- Yea it is that part but annoyingly only the rubber part came off :(
Sim's right mate, it should come off fairly easily - mine did when I fitted my heated grips. | |
| | | trevski Member
| Subject: Re: Need help getting clutch side grip part off Wed Sep 06, 2017 7:17 pm | |
| Thanks for the help guys, the part that I was trying to get off seems to be stuck on hard but I got the clutch lever off which is what I mainly needed off :) She is slowly coming along :) | |
| Subject: Re: Need help getting clutch side grip part off | |
Latest topics | » Hello by MTB59 Yesterday at 6:29 pm
