 1998 VS800 65,000mi Clutch Start
RAnst4038
RAnst4038
1998 VS800 65,000mi Clutch Start Empty
PostSubject: 1998 VS800 65,000mi Clutch Start   1998 VS800 65,000mi Clutch Start Icon_minitimeTue Oct 24, 2017 4:30 am
Bike let me sit second time, (first time spider spun a web between the fuel pump reverse contacts overnight while tent camping) clutch switch start interlock. At first fucking with the clutch switch would make it start. Then only by jerking front wheel left. Then nothing & I traced it to y/g wire from clutch switch to starter relay. When I moved the wire harness around at fork it would make contact. Disconnected the two handlebar wire harness & took the handlebar off. The left side harness cover is split in half, the right only half split. Pulled the right side cover off. The two green w yellow tracer wires from the clutch switch are solid. Can’t pull them apart or get them to move the meter from infinity. Checked all wires going to handlebars and all seem fine. Now I’m back to is the clutch switch shot.  1998 VS800 65,000mi Clutch Start 880307
RAnst4038
RAnst4038
PostSubject: Short jumper under seat.   1998 VS800 65,000mi Clutch Start Icon_minitimeWed Oct 25, 2017 1:36 am
Can't believe it, the problem was the short yellow/green double female that connects the start switch to the clutch switch in the plastic wrap under the seat. 1998 VS800 65,000mi Clutch Start 256401
I'm a master mechanic but have almost no electrical experience on bikes. All mine were built like a Seiko watch; except.
They cut the outside rubber seal on the distributor bearing when they sat the head on my Yamaha 360 6 speed at the factory. So it had a slooow leak out the dist cover. This VS800 has always had the bad habit of the clutch fluid turning to pond scum. Rebuilt the master cylinder and that slowed it down. But I still have to replace it once a year.  1998 VS800 65,000mi Clutch Start 594857
» vs800 Clutch
» My .......... 1998 Suzuki Marauder
» 1998 800 Bogs down @ mid-full throttle
» My violated ............. 1998 Suzuki VZ800 Marauder
» Hello, My Suzuki VZ800 1998 in mint condition :-)
1998 VS800 65,000mi Clutch Start Icon_minitimeby Badger Tue Oct 22, 2024 1:36 pm
1998 VS800 65,000mi Clutch Start Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:38 am
1998 VS800 65,000mi Clutch Start Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
1998 VS800 65,000mi Clutch Start Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
1998 VS800 65,000mi Clutch Start Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
1998 VS800 65,000mi Clutch Start Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
1998 VS800 65,000mi Clutch Start Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
1998 VS800 65,000mi Clutch Start Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
1998 VS800 65,000mi Clutch Start Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
1998 VS800 65,000mi Clutch Start Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
1998 VS800 65,000mi Clutch Start Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
1998 VS800 65,000mi Clutch Start Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
1998 VS800 65,000mi Clutch Start Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
1998 VS800 65,000mi Clutch Start Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
1998 VS800 65,000mi Clutch Start Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
1998 VS800 65,000mi Clutch Start Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
1998 VS800 65,000mi Clutch Start Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
1998 VS800 65,000mi Clutch Start Icon_minitimeby Brim Wed Aug 07, 2024 12:28 pm
1998 VS800 65,000mi Clutch Start Icon_minitimeby flying1 Wed Jul 31, 2024 1:59 pm
1998 VS800 65,000mi Clutch Start Icon_minitimeby gary,, Fri Jul 12, 2024 2:30 pm
