| | No sparks | |
Louis1960 Prospect
| Subject: No sparks Thu Mar 08, 2018 6:06 pm | |
| Help please, I have a Sachs B805 with a Suzuki v twin 800 motor and have no sparks | |
| Subject: Re: No sparks Thu Mar 08, 2018 10:22 pm | |
| A few random thoughts ;- Start by checking you have a live feed to the coils (using a volt meter or test lamp) with the ignition on. If not - check the kill switch is in good working order & not shorting out (i.e. strip it down & check it out). Also check to see if the side-stand cut out switch is not sticking/shorting. (Try starting with side stand up) Does the Sachs have a micro switch on the clutch lever that needs the clutch to be disengaged prior to starting ? .... but that is usually on the starter circuit rather than the ignition ('sparks') But before that ..... Do the lights for the ignition circuit come on ? - If not it could be a dodgy ignition switch. .... or even a blown fuse on the ignition circuit. If fuse is gone, it could be a short somewhere in the ignition circuit - look for chaffed wires How have you determined 'No Sparks' ? ... if with a loose plug held on the side of the engine, was it properly earthed (some people are worried about getting a shock ! ) ... It helps to get the wife/girlfriend to assist here Are HT leads & plug caps in good order ? Also wondering is this a 'new' problem, or is the bike a recent purchase - any other symptoms/issues with the bike ? | |
| | | Louis1960 Prospect
| Subject: Re: No sparks Fri Mar 09, 2018 7:24 am | |
| Thanks for that, I have heard the pick ups on the stator can be a problem | |
| | | Louis1960 Prospect
| Subject: Re: No sparks Fri Mar 09, 2018 7:29 am | |
| Bike was running fine then started to misfire then cut out , thought I was out of fuel. got it started but only ran on one cylinder, now will not start at all, no sparks on either plug | |
| Subject: Re: No sparks Fri Mar 09, 2018 1:33 pm | |
| Crikey Yam you said it all there matey!!! | |
| Subject: Re: No sparks | |
| | | | No sparks | |
