 Rear Sprocket Bolts
3 posters
hmac
hmac
Rear Sprocket Bolts Empty
PostSubject: Rear Sprocket Bolts   Rear Sprocket Bolts Icon_minitimeMon Mar 19, 2018 9:41 am
Does any know how to replace the rear sprocket bolts on a VZ800 Marauder?
Fitting a new chain and sprockets and one of the rear sprocket nuts is badly rounded and wont come loose. I have tried hammering a smaller socket onto it but it just spun off.
I am wondering if I just grind it flush with the sprocket is it then just a case of knocking the remains of the bolt out and dropping in a new one, or would I need to get it pressed out and new one pressed in.
PostSubject: Re: Rear Sprocket Bolts   Rear Sprocket Bolts Icon_minitimeMon Mar 19, 2018 10:15 am
Grind the head off then punch it out with a suitable punch & go to the bolt stockist you're bound to know locally & get a replacement & your away.
hmac
hmac
PostSubject: Re: Rear Sprocket Bolts   Rear Sprocket Bolts Icon_minitimeMon Mar 19, 2018 10:29 am
Thanks for the speedy reply Peter. That's what I'm hoping will happen, ordered new sprocket nuts from Wemoto last night. Will order
new bolts now and give it a go.
Rear Sprocket Bolts 10067711
hmac
hmac
PostSubject: Re: Rear Sprocket Bolts   Rear Sprocket Bolts Icon_minitimeSun Mar 25, 2018 5:14 pm
OK, so today I tackled the rounded sprocket nut. Cut the nut of with my angle grinder and the remains of the bolt fell out the back sprocket carrier. No hammering, punching or pressing needed. New bolt inserted, fitted new chain and sprockets and good to go.
PostSubject: Re: Rear Sprocket Bolts   Rear Sprocket Bolts Icon_minitimeSun Mar 25, 2018 6:44 pm
Good to hear that Harry as you never know with things like that!
PostSubject: Re: Rear Sprocket Bolts   Rear Sprocket Bolts Icon_minitimeSun Mar 25, 2018 8:42 pm
Rear Sprocket Bolts 2170595768
hmac
hmac
PostSubject: Re: Rear Sprocket Bolts   Rear Sprocket Bolts Icon_minitimeSun Mar 25, 2018 8:44 pm
Got the chain and sprocket done, rear brake stripped, cleaned, lubed and reassembled. Then moved on to the chain guard, one of the phillips head screws that secures it had refused to budge and I ended up drilling the head off with a 7mm bit, I then used a 4mm bit to try and drill through before moving to a larger drill. I applied pressure and boom I was through. The drill had gripped the remains of the screw and spun it out the back of the swing arm with no damage to the threads. Must be my lucky day, no work tomorrow so having a couple of beers to celebrate a good days spannering.
PostSubject: Re: Rear Sprocket Bolts   Rear Sprocket Bolts Icon_minitimeSun Mar 25, 2018 9:08 pm
Put some money on the lottery while the goings good  Rear Sprocket Bolts 3498837457
hmac
hmac
PostSubject: Re: Rear Sprocket Bolts   Rear Sprocket Bolts Icon_minitimeSun Mar 25, 2018 10:34 pm
thumup
Rear Sprocket Bolts
» Sprocket nuts !
» VZ800 17 tooth sprocket
» VZ800 Sprocket / Gearing Change
» Installed 17T front sprocket ....... 2000 Suzuki Marauder VZ800Y
Rear Sprocket Bolts Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Rear Sprocket Bolts Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Rear Sprocket Bolts Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Rear Sprocket Bolts Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Rear Sprocket Bolts Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Rear Sprocket Bolts Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Rear Sprocket Bolts Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Rear Sprocket Bolts Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Rear Sprocket Bolts Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Rear Sprocket Bolts Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Rear Sprocket Bolts Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Rear Sprocket Bolts Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Rear Sprocket Bolts Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Rear Sprocket Bolts Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Rear Sprocket Bolts Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Rear Sprocket Bolts Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Rear Sprocket Bolts Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Rear Sprocket Bolts Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Rear Sprocket Bolts Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Rear Sprocket Bolts Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
