| Stearing Damper | |
Shrek Member
| Subject: Stearing Damper Tue Apr 24, 2018 9:19 pm | |
| Does anyone know what (if any) steering damper will fit an 800 2006 Indruder. Mine is a Trike conversion and I gt a little bit of front wheel wobble. | |
| Subject: Re: Stearing Damper Tue Apr 24, 2018 10:04 pm | |
| From what I’ve read this can be an issue with trikes.
There are hardly any on here, so I doubt if anyone on the forum has had the need to fit one.
Maybe speak to the suppliers of someth8ng like this and see what figments they offer...
https://www.jpcycles.com/product/230-242/v-twin-manufacturing-steering-damper | |
| | | captain morgan Member
| Subject: Re: Stearing Damper Wed Apr 25, 2018 8:35 pm | |
| probably wrong but just a thought has your front wheel been balanced? might cause wobble because your on 3 wheels also have you added puncture safe to the front wheel (tyre) or similar product? as if not done correctly it will cause wheel wobble quick question is wobble all the time or just at certain speed and gets worse the faster you go? | |
| | | Ranger Prospect
| Subject: Re: Stearing Damper Thu Jul 04, 2019 12:02 pm | |
| I have the vz marauder trike, I think it can be part of what tyre you run on the front, if it's a rounded ordinary tyre less grip which can cause it to skip on corners too, I've found with mine I use Shiko MT 90/16 the tyre has a flat tread more like the old cross ply, but it holds much better and much less shake, also tyre presures can be a factor, I run my tyres around 15psi. | |
| | | Ranger Prospect
| Subject: Re: Stearing Damper Thu Jul 04, 2019 12:03 pm | |
| just realised how old thios post is | |
| Subject: Re: Stearing Damper | |
| | | | Stearing Damper | |
