 Which amp fuse to use
3 posters
trevski
trevski
Which amp fuse to use Empty
PostSubject: Which amp fuse to use   Which amp fuse to use Icon_minitimeWed May 09, 2018 2:51 pm
Hi guys, I have a cigarette charger which will have a Zus Nonda Dual charger to charge both a GoPro and SatNav at the same time. Which fuse would be better to hook it up to? I have seen most places say 15 amp is fine but just wanted to double check
PostSubject: Re: Which amp fuse to use   Which amp fuse to use Icon_minitimeWed May 09, 2018 11:04 pm
When I fitted a cig lighter for charging stuff, I hooked it up to the “secret” connection in the headlamp bowl. Not sure if you’re 2001 model will have that, but worth a look. It means it’s only live when the ignition is on, meaning you cant accidentally leave something plugged in and drain you’re battery....
PostSubject: Re: Which amp fuse to use   Which amp fuse to use Icon_minitimeThu May 10, 2018 9:01 am
If you are worried then put a 5amp fuse inline for small uses & a 10amp for higher pull so at that rate it will cover most things except lights etc ok.
» Fuse box
» auxcillary fuse Box on M50
» Re-Locating Fuse box VZ800
» Fuse Box 2009 models
» Tail light fuse blowing
Which amp fuse to use Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Which amp fuse to use Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Which amp fuse to use Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Which amp fuse to use Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Which amp fuse to use Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Which amp fuse to use Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Which amp fuse to use Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Which amp fuse to use Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Which amp fuse to use Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Which amp fuse to use Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Which amp fuse to use Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Which amp fuse to use Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Which amp fuse to use Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Which amp fuse to use Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Which amp fuse to use Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Which amp fuse to use Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Which amp fuse to use Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Which amp fuse to use Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Which amp fuse to use Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Which amp fuse to use Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
