 DJ-Mod: running a vx 800 is there any chance to swap the gearing
malaga
DJ-Mod:  running a vx 800   is there any chance to swap the gearing  Empty
PostSubject: DJ-Mod: running a vx 800 is there any chance to swap the gearing    DJ-Mod:  running a vx 800   is there any chance to swap the gearing  Icon_minitimeTue Aug 21, 2018 2:47 pm
running a vx 800
is there any chance to swap the gearing - without opeining the engine as a whole!?
Quote :
, I am new to this site. I just bought an 06' C50T and my fiance and I love it. I have previous experience with an 82' Kawasaki 750 and a 98' Honda Valkyrie (fathers).
I absolutely love everything about this bike except one thing, the highway cruising RPM's. I commute 124 miles a day and love using the bike for the fun factor and fuel mileage. Most of my commute is between 60-75MPH, which is in the 3700-4700 RPM range.
I have been considering different methods to lower cruising RPM's, specifically a taller rear tire/rim or different rear drive gears.
My specific requirements are a happy medium at highway speeds. Here are my opinions on what I may need to do this:
1)optimum efficiency is typically at max torque RPM, which in this case is 3500 RPM according to Suzuki.
2)I would like to run 65MPH (average of different cruising speeds/most highway speed limits) at 3500 RPM.
In order to accomplish this, I would need:
A)a 30" tire, compared to 26" stock tire. This is a 4" difference, which is unlikely to fit under the stock rear fender.
B)Final drive reduction of 3.00, rather than the stock 3.503.
Now my question's to all of you is this: Are you familiar with any company that manufactures different rear differential gears? Also, is there a different Suzuki (or other brand) gear that may fit the c50's rear diff housing that is closer to a 3:1 ratio.
If there is not a gear already manufactured, I may be in contact with a local high-performance manufacturing facility to see if they can manufacture a 3:1 rear drive gear.
Thanks
are there any chances and means to go this way with a VX 800
» a VX 800 and i want to make most of it - regarding the gearing.
» gearing and transmission revisited : calculations on the dj-mod
» VZ800 Sprocket / Gearing Change
» VX 800 : love this bike - but want a taller gearing for Cruising
» VZ 800 96>99+ exhaust swap?
DJ-Mod:  running a vx 800   is there any chance to swap the gearing  Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
DJ-Mod:  running a vx 800   is there any chance to swap the gearing  Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
DJ-Mod:  running a vx 800   is there any chance to swap the gearing  Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
DJ-Mod:  running a vx 800   is there any chance to swap the gearing  Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
DJ-Mod:  running a vx 800   is there any chance to swap the gearing  Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
DJ-Mod:  running a vx 800   is there any chance to swap the gearing  Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
DJ-Mod:  running a vx 800   is there any chance to swap the gearing  Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
DJ-Mod:  running a vx 800   is there any chance to swap the gearing  Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
DJ-Mod:  running a vx 800   is there any chance to swap the gearing  Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
DJ-Mod:  running a vx 800   is there any chance to swap the gearing  Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
DJ-Mod:  running a vx 800   is there any chance to swap the gearing  Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
DJ-Mod:  running a vx 800   is there any chance to swap the gearing  Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
DJ-Mod:  running a vx 800   is there any chance to swap the gearing  Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
DJ-Mod:  running a vx 800   is there any chance to swap the gearing  Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
DJ-Mod:  running a vx 800   is there any chance to swap the gearing  Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
DJ-Mod:  running a vx 800   is there any chance to swap the gearing  Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
DJ-Mod:  running a vx 800   is there any chance to swap the gearing  Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
DJ-Mod:  running a vx 800   is there any chance to swap the gearing  Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
DJ-Mod:  running a vx 800   is there any chance to swap the gearing  Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
DJ-Mod:  running a vx 800   is there any chance to swap the gearing  Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
