 VZ800 Clutch started slipping- help
3 posters
Paul_H
VZ800 Clutch started slipping- help Empty
PostSubject: VZ800 Clutch started slipping- help   VZ800 Clutch started slipping- help Icon_minitimeThu Aug 23, 2018 2:50 pm
Hi all. So picked up a Marauder last week 20,000 miles on the clock. First ride last week faultless. took her out again just now and the clutch is slipping in high gear? Clutch is letting go right on the end of the lever play as well.
So first is there any reason apart from a worn out clutch that this might suddenly happen? I have done nothing to the bike at all.
secondly what do I need to replace the clutch?
do I need top replace friction and steel plates and springs?
Also will I need a new gasket?
Do I need the special tool see on ebay for £25?
anything else?
thanks
P
PostSubject: Re: VZ800 Clutch started slipping- help   VZ800 Clutch started slipping- help Icon_minitimeThu Aug 23, 2018 5:10 pm
Hello, its a bit contravertial but if someone has put mineral oil (car oil) in it then I beleive this can make the clutch slip, it may be worth changing the oil & filter, use semi synthetic bike oil, a good one is 'Silkolene'.
RAnst4038
RAnst4038
PostSubject: Re: VZ800 Clutch started slipping- help   VZ800 Clutch started slipping- help Icon_minitimeTue Aug 28, 2018 6:37 am
Mine slipped when I used full synthetic & it took a while to get it back out of the clutch plates. Only use natural oil that's what it's designed for. Have to take it easy so you don't glaze the plates. In the end I installed a set of the extra heavy springs. Now that I'm 60 & don't ride around at full throttle anymore I wish I knew where the original springs are. VZ800 Clutch started slipping- help 855947
Paul_H
PostSubject: Re: VZ800 Clutch started slipping- help   VZ800 Clutch started slipping- help Icon_minitimeSun Sep 02, 2018 5:22 pm
Stripped down, everything measured within tolerances but the plates were blue. Replaced everything put in new tighter springs. Changed the oil to semi synthetic, new gasket. put back together - sweet as a nut now and no leaks! Hurrah. Been out for a blast and what a difference. Now to get the dent out of the tank and clean up and/or replace some chrome.
Boulevard of Dreams likes this post
» CLUTCH SLIPPING STILL
» clutch slipping now adjusted
» VZ800 Marauder broken clutch cam.
» Replacing Clutch Cable VZ800
» clutch slip - 2002 Suzuki VZ800 Marauder
VZ800 Clutch started slipping- help Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
VZ800 Clutch started slipping- help Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
VZ800 Clutch started slipping- help Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
VZ800 Clutch started slipping- help Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
VZ800 Clutch started slipping- help Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
VZ800 Clutch started slipping- help Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
VZ800 Clutch started slipping- help Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
VZ800 Clutch started slipping- help Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
VZ800 Clutch started slipping- help Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
VZ800 Clutch started slipping- help Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
VZ800 Clutch started slipping- help Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
VZ800 Clutch started slipping- help Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
VZ800 Clutch started slipping- help Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
VZ800 Clutch started slipping- help Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
VZ800 Clutch started slipping- help Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
VZ800 Clutch started slipping- help Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
VZ800 Clutch started slipping- help Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
VZ800 Clutch started slipping- help Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
VZ800 Clutch started slipping- help Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
VZ800 Clutch started slipping- help Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
