 Bad vibrations
3 posters
Big.Nige
Bad vibrations  Empty
PostSubject: Bad vibrations    Bad vibrations  Icon_minitimeWed Jun 03, 2020 6:21 pm
Hi all Iv just got myself a beautiful vz800 intruder on a 63 plate with 9200 on the clock I have been out on it a few times and have a couple of questions.
First question when the bike gets into the higher rev range it vibrates like washing machine through the seat, bars and pegs basically the whole bike I have checked everything is tight and the tyres are good nothing is wrong with it apart from the servicing it has full history but it looks like its never had the valves adjust could this be why it vibrates so much. My last 4 bikes where Vtwins and none of them vibrated this much I had 2 SV650's and 2 Ducati's but none of them where this like this. If I keep the bike below 3000 rpm (that's a guess as theres no rev counter) it's ok ish at 50 in 5 its perfect but at 70 or higher it's that bad that it makes my vision funny surly this isn't right. Any help would be much appreciated thanks
Bad vibrations  Empty Bad vibrations  Empty
Bad vibrations  I_icon_profile Bad vibrations  I_icon_pm Bad vibrations  I_icon_online
Badger
Badger
PostSubject: Re: Bad vibrations    Bad vibrations  Icon_minitimeWed Jun 03, 2020 8:27 pm
Make sure the tyre pressures are bang on, then get the front wheel balanced at a shop, shouldn't cost much if you remove it yourself.
ArnoldinIdaho
PostSubject: Re: Bad vibrations    Bad vibrations  Icon_minitimeMon Jun 08, 2020 12:34 am
I had a serious vibration problem at speeds above thirty just after changing the front tire.  Took the wheel off at home and realized I had left a pair of pliers between the tire and tube.  Easy fix.
Badger
Badger
PostSubject: Re: Bad vibrations    Bad vibrations  Icon_minitimeMon Jun 08, 2020 9:52 am
Could be worse Arnold, you could be a surgeon.   pale
Big.Nige
PostSubject: Re: Bad vibrations    Bad vibrations  Icon_minitimeTue Jun 16, 2020 10:49 am
I found out what the vibration was it had an aftermarket windscreen on it I took it off and now it rides beautiful. Happy days
Badger
Badger
PostSubject: Re: Bad vibrations    Bad vibrations  Icon_minitimeTue Jun 16, 2020 1:31 pm
Nice one Nige.   This is good information now, for anyone else with the same problem.
Windscreens never even entered my thoughts tbh.
I'm sure I read you can get deflectors fitted somewhere, around the fork area ...?  to assist with screens.
Bad vibrations
» How to mount Tsukayu Jumbo Strong on the C800 to avoid vibrations
Bad vibrations  Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Bad vibrations  Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Bad vibrations  Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Bad vibrations  Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Bad vibrations  Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Bad vibrations  Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Bad vibrations  Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Bad vibrations  Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Bad vibrations  Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Bad vibrations  Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Bad vibrations  Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Bad vibrations  Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Bad vibrations  Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Bad vibrations  Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Bad vibrations  Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Bad vibrations  Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Bad vibrations  Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Bad vibrations  Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Bad vibrations  Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Bad vibrations  Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
