| Fitting Highway Hawk short pipes on Suzuki M800 | |
Guest Guest
| Subject: Fitting Highway Hawk short pipes on Suzuki M800 Wed Nov 30, 2011 6:26 pm | |
| Many Thanks Jez A message sent to me by (Dozers Dad) Hi Peter, My HH Shortcuts didn't come with any instructions. It's not rocket sience but once you've got the original system off gimme a call if you get stuck mate....... Regards Jez (aka Dozers Dad) PS.... A top tip to get you started is that once the original system is off. You need to remove the large triangular bracket that it attached to at the back of the bike and the plastic frame cover just in front of it. That is where the new bracket fits. Very loosely fit the two pipes together before you offer them up to the cylinderhead. The rest should become apparent as you go along but if not gimme a bell. PPS.... If you've got a hex bit for a socket set or an impact drive bit. Use the bit and a 6mm ring spanner to tighten the lower bolt on the front cylinder. Getting at it with an Allen key is mission "almost" impossible! :shock: Many thanks again D/D a great help |
