 VL800 clutch housing
2 posters
Koala 1970
VL800 clutch housing Empty
PostSubject: VL800 clutch housing   VL800 clutch housing Icon_minitimeSat Feb 26, 2022 10:48 am
Well here's an update. I have fully stripped down my bike, checked the driveshaft and all good. Lubed it up with some moly and put it back together. Whilst the bike was in bits, I have cleaned all the filthy inaccessible areas and painted the rust with black hammerite smooth. I've now removed the clutch and the plates were burnt out and everything stunk of burn, including the oil. I've got new plates and springs and here is where it all hit the fan... Two of the spring bolts snapped inside the clutch housing/basket!!!!! I thought I was only torquing them to 7 lb/foot but one snapped and as it tried to undo another, it also snapped. Am now considering buying a new housing if I can remove the existing one without a removal tool (using a dog lead appears to work but we shall see) Are the VL800/VS800/C800/C50/M800 all the same clutch parts? Also if anyone has a clutch basket/housing, let me know
PostSubject: Re: VL800 clutch housing   VL800 clutch housing Icon_minitimeSat Mar 05, 2022 8:43 am
Find the part here - it will cross reference which other machines the same part will fit.
https://www.motorcyclespareparts.eu/en/suzuki-parts/2006-vl800c-volusia-motorcycles
You're right with the torque measurements - are they the original bolts you have ? They've not been replaced with titanium ?
Koala 1970 likes this post
Koala 1970
PostSubject: Re: VL800 clutch housing   VL800 clutch housing Icon_minitimeSun Mar 06, 2022 10:48 am
Cheers for the parts link. Yes they are the original clutch bolts. Where would I source titanium bolts to fit? Would stainless steel ones be ok?
I managed to remove the housing using a rachet strap and have now received a new housing.
Would prefer to sort bolts before I embark on this next part
PostSubject: Re: VL800 clutch housing   VL800 clutch housing Icon_minitimeSun Mar 06, 2022 10:53 am
Do not go for titanium - they're a nightmare. They have a lower shear factor than steel. They stretch then snap. Go for stainless every time. I use Pro-Bolt - buy a set of new ones
https://www.pro-bolt.com/
» vs800 Clutch
» CLUTCH SLIPPING STILL
» Clutch advice
» Help with clutch - C50
» Clutch problem
VL800 clutch housing Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
VL800 clutch housing Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
VL800 clutch housing Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
VL800 clutch housing Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
VL800 clutch housing Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
VL800 clutch housing Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
VL800 clutch housing Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
VL800 clutch housing Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
VL800 clutch housing Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
VL800 clutch housing Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
VL800 clutch housing Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
VL800 clutch housing Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
VL800 clutch housing Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
VL800 clutch housing Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
VL800 clutch housing Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
VL800 clutch housing Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
VL800 clutch housing Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
VL800 clutch housing Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
VL800 clutch housing Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
VL800 clutch housing Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
