 Tyre Pressures
5 posters
ippikin
ippikin
Tyre Pressures Empty
PostSubject: Tyre Pressures   Tyre Pressures Icon_minitimeTue Dec 20, 2011 4:23 pm
Can anyone tell me what the normal tyre pressures are for a VZ800 K8 model please? Tyre Pressures 1090754380
PostSubject: Re: Tyre Pressures   Tyre Pressures Icon_minitimeTue Dec 20, 2011 9:50 pm
I believe that recommended pressure is 29psi front tyre, 36 psi rear tyre on your model
It should say in your hand book and also on the sticker on the rear mudguard if it is still there.
I run my C800 above recommendation as I think the handling is sloppy at the recommended C800 Pressure. So I put in 32psi front and 38psi in the rear but they are slightly different bikes. I ride my bike quite hard and found the recommend pressure gave a sloppy response & the slightly higher pressure more responsive.
PostSubject: Re: Tyre Pressures   Tyre Pressures Icon_minitimeTue Dec 20, 2011 10:08 pm
My bike handled better when I went to the pressure Mr I runs at but that was also a C not an M. The tyre pressure for the C & M are identical though so what you run them at is a matter of personal preference
ippikin
ippikin
PostSubject: Thanks   Tyre Pressures Icon_minitimeWed Dec 21, 2011 12:13 am
Thanks for the advice.
PostSubject: Re: Tyre Pressures   Tyre Pressures Icon_minitimeWed Dec 21, 2011 8:31 pm
You'll probably get more wear out of your tyres if you run 32/38. I wore out a stock rear at 4,500 although I had been at 34 for a while. My current Pirrelli Route has done 4,000 now at 38 and is barely half worn - stock tyres are a bit crappy mind. My front stock is still ok at 8500 but will need changing at about 9500. Tyre pressures and choice of tyres can make a big difference but riding style is not to be underestimated. I can safely say that I hammered my bike for the first 5,000. When I got new exhausts and could hear the damn things at last, I stopped trying to make the engine heared above the traffic and eased off on the throttle a bit. As Mr I. rightly says, the bikes handle better at the higher pressure, although you do feel the bumps more. I will say this - the 800's are wonderfully adaptable machines - steady eddy or nutter, either style will give you rewards in their own way. That big front tyre is no small player in the bike's success, I would say.
PostSubject: Re: Tyre Pressures   Tyre Pressures Icon_minitimeWed Dec 21, 2011 11:20 pm
Wise words from the Bluesman there, the most important thing to remember is that different tyres will react differently at different pressures. My bike is still on stock tyres and I found the 32/38psi worked really well for those tyres however I may run at slightly different pressures when I renew them with the presently planned Metzler ME880's. Trial and error is the key!
PostSubject: Re: Tyre Pressures   Tyre Pressures Icon_minitimeThu Dec 22, 2011 5:20 pm
I think that Metzler tyres run at quiet a high pressure compared to most, which ones are you going to get?
The ME-880 Marathon's or the ME-880 white walls. White walls I suspect
Tyre Pressures ME_880_Marathon_173X236 ME-880 Marathon Tyre Pressures ME_880_Whitewall_173X236 ME-880 White walls
pledge
pledge
PostSubject: Re: Tyre Pressures   Tyre Pressures Icon_minitimeThu Dec 22, 2011 5:52 pm
I really like the whitewalls they look very classic.
PostSubject: Re: Tyre Pressures   Tyre Pressures Icon_minitimeThu Dec 22, 2011 6:06 pm
Yeah gotta be the white walls, they are real nice and will really add to the bike.
PostSubject: Re: Tyre Pressures   Tyre Pressures Icon_minitimeThu Dec 22, 2011 9:23 pm
If they got dirty would you clean them or can you get whitewall paint?
PostSubject: Re: Tyre Pressures   Tyre Pressures Icon_minitimeFri Dec 23, 2011 10:11 am
My mate has white walls on his Rocket and sprays them with Muc-off leaves for a minute the gives a quick scrub around with a medium hard brush and then cleans them off properly with clean water but I dont know if that the proper way that is recomended or not
PostSubject: Re: Tyre Pressures   Tyre Pressures Icon_minitimeFri Dec 23, 2011 11:16 am
I would clean them, I have read a lot about white walls & the best thing to do is clean them on a regular basis to keep them in tip top condition. That way you stop oils and grime from deeply penetrating the white wall which makes them harder to keep really bright.
Tyre Pressures
» New tyre
» New Tyre
» Tyre Questions
» scrubbing in your new tyre
» Tyre recommendation
Tyre Pressures Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Tyre Pressures Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Tyre Pressures Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Tyre Pressures Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Tyre Pressures Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Tyre Pressures Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Tyre Pressures Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Tyre Pressures Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Tyre Pressures Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Tyre Pressures Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Tyre Pressures Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Tyre Pressures Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Tyre Pressures Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Tyre Pressures Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Tyre Pressures Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Tyre Pressures Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Tyre Pressures Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Tyre Pressures Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Tyre Pressures Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Tyre Pressures Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
