 Nut's at the top and bottom of the shaft housing
3 posters
tony from dorset
tony from dorset
Nut's at the top and bottom of the shaft housing Empty
PostSubject: Nut's at the top and bottom of the shaft housing   Nut's at the top and bottom of the shaft housing Icon_minitimeFri Dec 23, 2011 6:08 pm
whats the nut at the top and bottom of the shaft housing looks like oil filer or something scary about the lack of grease
PostSubject: Re: Nut's at the top and bottom of the shaft housing   Nut's at the top and bottom of the shaft housing Icon_minitimeFri Dec 23, 2011 11:55 pm
They are the final drive oil filler cap & drain plug
tony from dorset
tony from dorset
PostSubject: Re: Nut's at the top and bottom of the shaft housing   Nut's at the top and bottom of the shaft housing Icon_minitimeSat Dec 24, 2011 4:47 pm
so what is the issue with the greasing of the shaft ive been reading about is the oil and the grease thing two different areas of lubrication but in the same area?
PostSubject: Re: Nut's at the top and bottom of the shaft housing   Nut's at the top and bottom of the shaft housing Icon_minitimeSat Dec 24, 2011 8:04 pm
Yes thats about it, same area but different sections.
Nut's at the top and bottom of the shaft housing Finaldrive
ippikin
ippikin
PostSubject: Shaft Lube   Nut's at the top and bottom of the shaft housing Icon_minitimeSat Dec 24, 2011 8:18 pm
The hypoid gears of the shaft drive at the back wheel are in a sealed unit (full of gear oil), but the unit has a cog that meshes with a similar one on the back wheel which needs greasing; also the shaft runs up to the engine and has splines that fit into a universal joint; also needs lube. See excellent file in maintenance section of how to do it!
» shaft drive
» Shaft drive assembly
» Drive shaft grease
» Drive shaft warning
» Shaft Greasing
Nut's at the top and bottom of the shaft housing Icon_minitimeby MTB59 Yesterday at 6:29 pm
Nut's at the top and bottom of the shaft housing Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Nut's at the top and bottom of the shaft housing Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Nut's at the top and bottom of the shaft housing Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Nut's at the top and bottom of the shaft housing Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Nut's at the top and bottom of the shaft housing Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Nut's at the top and bottom of the shaft housing Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Nut's at the top and bottom of the shaft housing Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Nut's at the top and bottom of the shaft housing Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Nut's at the top and bottom of the shaft housing Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Nut's at the top and bottom of the shaft housing Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Nut's at the top and bottom of the shaft housing Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Nut's at the top and bottom of the shaft housing Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Nut's at the top and bottom of the shaft housing Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Nut's at the top and bottom of the shaft housing Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Nut's at the top and bottom of the shaft housing Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Nut's at the top and bottom of the shaft housing Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Nut's at the top and bottom of the shaft housing Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Nut's at the top and bottom of the shaft housing Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Nut's at the top and bottom of the shaft housing Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
