| 12v power outlet in headlight bucket M800 & C800 | |
ippikin Member
| Subject: 12v power outlet in headlight bucket M800 & C800 Tue Jan 24, 2012 11:08 pm | |
| I have discovered the 12v accessory power outlet in my VZ800 (K8) (2008 M800 by any other name) 's headlight. It terminates in a white connector with 2 terminals which seem to be at 90 degrees to each other.
Does anyone know where I can get a male connector to fit into the stock female connector? I don't really want to cut the stock connector off.
Also I read somewhere it's a 10A rated circuit..... does anyone know? I'm hoping to wire my heated grips into it.
Thanks | |
| Subject: Re: 12v power outlet in headlight bucket M800 & C800 Tue Jan 24, 2012 11:56 pm | |
| It is a standard automotive connector, I can't tell you where to go over over there but any automotive accessory or autoelectric shop should have them. Otherwise you can just use standard crimp type spade connectors and they will fit into the 2 pin housing. | |
| | | smart Valued Member
| Subject: Re: 12v power outlet in headlight Wed Jan 25, 2012 9:37 pm | |
| hey Grob try vehicle wiring products ltd their in derbyshire they do lots of different connectors | |
| | | ippikin Member
| Subject: Re: 12v power outlet in headlight bucket M800 & C800 Wed Jan 25, 2012 10:13 pm | |
| - smart wrote:
- hey Grob try vehicle wiring products ltd their in derbyshire they do lots of different connectors
Thanks. Will do. | |
| Subject: Re: 12v power outlet in headlight bucket M800 & C800 Thu Jan 26, 2012 8:27 pm | |
| You would get one at either Halfords or Maplins Yes it is 10amp Thought I would add a couple of photo's for anyone who is wondering what it looks like | |
| Subject: Re: 12v power outlet in headlight bucket M800 & C800 Thu Jan 26, 2012 9:49 pm | |
| Well you learn something new every day I didn't even know there was a power outlet in the headlight bucket | |
| | | ippikin Member
| Subject: Re: 12v power outlet in headlight bucket M800 & C800 Thu Jan 26, 2012 11:20 pm | |
| Subject: Re: 12v power outlet in headlight bucket M800 & C800 Thu Jan 26, 2012 11:55 pm | |
| It's wired back to the fuse box and is marked as power source 10A. | |
| | | smart Valued Member
| Subject: Re: 12v power outlet in headlight Tue Jan 31, 2012 10:32 pm | |
| hi Grob is this connecter pemanent live or ignition live if so would be great for heated grips? | |
| Subject: Re: 12v power outlet in headlight bucket M800 & C800 Tue Jan 31, 2012 11:14 pm | |
| It's ignition wired. No power when key off. I use mine for my GPS. | |
| | | smart Valued Member
| Subject: Re: 12v power outlet in headlight Wed Feb 01, 2012 10:22 pm | |
| hi Ian thank's for that now i know where to wire my heated grips!! | |
| | | ippikin Member
| Subject: Re: 12v power outlet in headlight bucket M800 & C800 Wed Feb 01, 2012 11:19 pm | |
| Just finished wiring my heated grips into this connector..... works great! Couldn't find a connector block so just slotted some spade terminals in and taped it up. | |
| | | Guest Guest
| Subject: Re: 12v power outlet in headlight bucket M800 & C800 Sat Feb 04, 2012 4:31 pm | |
| - ippikin wrote:
- Couldn't find a connector block so just slotted some spade terminals in and taped it up.
I can't find the male ends for this plug ether, anyone know were i can get them. I'm gunna wire them to my pump, a torch i can carry,sat nav. shame its not direct to the battery could if used it to charge as well . |
| Subject: Re: 12v power outlet in headlight bucket M800 & C800 Sat Feb 04, 2012 5:45 pm | |
| I have looked everywhere & I can't find them either, might be worth taking that one off and adding your own or run the wires in to a block connection so that you can run several items from it. If you want to run numerous items possibly think about adding a 12v cigarette/cigar type of connection like I have for the satnav etc Link | |
| | | CycleBiker Member
| Subject: Re: 12v power outlet in headlight bucket M800 & C800 Sat Feb 04, 2012 6:01 pm | |
| I believe that connector is for the factory light bar (which incidentally I have read is crap) but obviously you can use it for anything you want. I believe I have a source noted somewhere for those connectors and will post if I find it. If you are doing your own wiring it might be worth making a pigtail with a spare take of in case you want to power something else later (though you won't power much else if you have heated gloves on that circuit).
I finally installed a secondary fuse panel for accessories. | |
| Subject: Re: 12v power outlet in headlight bucket M800 & C800 Tue May 01, 2012 7:45 pm | |
| Wonder if these are the fellas on Fleabay? LINKY Might have a punt and order one! | |
| | | | Sponsored content
| Subject: Re: 12v power outlet in headlight bucket M800 & C800 | |
