 * False Swing Arm Removal Instruction - Suzuki C800 / C50 *
joolz6
raffaele.negrin
9 posters
* False Swing Arm Removal Instruction - Suzuki C800 / C50 * Empty
PostSubject: * False Swing Arm Removal Instruction - Suzuki C800 / C50 *   * False Swing Arm Removal Instruction - Suzuki C800 / C50 * Icon_minitimeTue Mar 06, 2012 1:34 pm
This is one of the easiest mod's that can be done to the 800 and took only 15 minutes in total, which included time to get the tools out and put them away again! There is no point in having the extremely heavy false swing arm on the bike as it is their simply for cosmetic symmetry.
First off remove the side cover, mine is chrome but they are normally plastic. They attach with one 10mm bolt at the top and 2x push lugs. So undo the bolt and pull firmly on the cover and it will come away easily.
* False Swing Arm Removal Instruction - Suzuki C800 / C50 * IMG_0337
Now when you look behind where the cover was you will see 2x 10mm bolts that need to be removed
* False Swing Arm Removal Instruction - Suzuki C800 / C50 * IMG_0338
In Mistress K's thread, she said removing these was a knuckle scraper but I found that using a small socket set with an extention bar you can get to these bolts easily.
* False Swing Arm Removal Instruction - Suzuki C800 / C50 * IMG_0339
Now remove the 2x 10mm bolts that are forward facing and your nearly there.
* False Swing Arm Removal Instruction - Suzuki C800 / C50 * IMG_0340
Lastly remove the big bolt on the side using an 8mm Hex/Allen key and remove the swing arm. Replace the side cover by pushing firmly to position the 2x push lugs and secure the bolt at the top & your all done!
Before
* False Swing Arm Removal Instruction - Suzuki C800 / C50 * IMG_0336
After
* False Swing Arm Removal Instruction - Suzuki C800 / C50 * IMG_0344
If you look you will see that I sprayed the 8mm Hex/Allen bolt silver to match in better, as leaving it dark grey would have made it stand out to much. I did actually spray it before I started the mod & baked it for a short time to harden the paint. At some point I will replace it with a hrome bolt.
PostSubject: Re: * False Swing Arm Removal Instruction - Suzuki C800 / C50 *   * False Swing Arm Removal Instruction - Suzuki C800 / C50 * Icon_minitimeTue Mar 06, 2012 8:38 pm
Great job done Dave excellent write up as usual * False Swing Arm Removal Instruction - Suzuki C800 / C50 * 2170595768
raffaele.negrin
raffaele.negrin
PostSubject: Re: * False Swing Arm Removal Instruction - Suzuki C800 / C50 *   * False Swing Arm Removal Instruction - Suzuki C800 / C50 * Icon_minitimeSun Sep 30, 2012 4:44 pm
Very interesting! Anything that can make the bike lighter is usually a good idea. Will be trying it out :-) Did you notice any difference in handling, turning, braking...?
PostSubject: Re: * False Swing Arm Removal Instruction - Suzuki C800 / C50 *   * False Swing Arm Removal Instruction - Suzuki C800 / C50 * Icon_minitimeSun Sep 30, 2012 6:28 pm
No change at all Raph, it serves no purpose at all.
joolz6
joolz6
PostSubject: Re: * False Swing Arm Removal Instruction - Suzuki C800 / C50 *   * False Swing Arm Removal Instruction - Suzuki C800 / C50 * Icon_minitimeThu Dec 06, 2012 9:14 pm
Feck me ! I think i will have a go at this !!
Merry Christmas to all Suzuki 800 riders !
PostSubject: Re: * False Swing Arm Removal Instruction - Suzuki C800 / C50 *   * False Swing Arm Removal Instruction - Suzuki C800 / C50 * Icon_minitimeThu Dec 06, 2012 9:26 pm
Its a shockingly easy mod to do and cleans up the arse end & in turn makes cleaning easier. Plus its bloody heavy and serves no purpose.
PostSubject: Re: * False Swing Arm Removal Instruction - Suzuki C800 / C50 *   * False Swing Arm Removal Instruction - Suzuki C800 / C50 * Icon_minitimeThu Dec 06, 2012 9:30 pm
On earlier models of the intruder the false swing arm was actually made of plastic.
PostSubject: Re: * False Swing Arm Removal Instruction - Suzuki C800 / C50 *   * False Swing Arm Removal Instruction - Suzuki C800 / C50 * Icon_minitimeSun Dec 16, 2012 6:44 am
Yep ... mine's plastic mate as you commented when you sorted my rear pegs out. It's there only to make the bike look like a hardtail but as I like the look and as mine weighs nothing, there's really no point in removing it.
PostSubject: Re: * False Swing Arm Removal Instruction - Suzuki C800 / C50 *   * False Swing Arm Removal Instruction - Suzuki C800 / C50 * Icon_minitimeSun Dec 22, 2013 8:55 pm
Dave out of curiosity, I know you have not got the diff on that you pictured above as you now have the VS1400 diff on instead but do you still have plans to tart up the diff that this mod has now very much exposed?
PostSubject: Re: * False Swing Arm Removal Instruction - Suzuki C800 / C50 *   * False Swing Arm Removal Instruction - Suzuki C800 / C50 * Icon_minitimeSun Dec 22, 2013 9:14 pm
Yes the exposed diff was always part of a decorative plan that as of yet I still have not done or completed my thinking on. I did have a plan but that has now gone out of the window as Marcin has exposed his skills with decals. It will now be sprayed black as it was previously going to be but now have some Maraggie decals fitted on as well before finally being lacquered. I have been at times messing with some idea's for the exposed Diff from this false swing arm removal modification. When I have finally decided on what I want, I will discuss this with Marcin & let him make it better.  * False Swing Arm Removal Instruction - Suzuki C800 / C50 * 852880 However I need to take any diff contours into consideration when completing what I want which might be simpler than I have made it sound.
Badger
Badger
PostSubject: Re: * False Swing Arm Removal Instruction - Suzuki C800 / C50 *   * False Swing Arm Removal Instruction - Suzuki C800 / C50 * Icon_minitimeSun Sep 30, 2018 7:24 pm
I used a plastic, mushroom head button for the hex bolt, with a few spots of glue.
I sprayed it with Hammerite smooth silver, that, by a happy coincidence, is the exact colour match to our bike's drive casing.   nice.  * False Swing Arm Removal Instruction - Suzuki C800 / C50 * Dscf0410
PostSubject: Re: * False Swing Arm Removal Instruction - Suzuki C800 / C50 *   * False Swing Arm Removal Instruction - Suzuki C800 / C50 * Icon_minitimeSun Sep 30, 2018 10:17 pm
Nice work Badger! You should also win a prize for the longest gap between posts ever!
PostSubject: Re: * False Swing Arm Removal Instruction - Suzuki C800 / C50 *   * False Swing Arm Removal Instruction - Suzuki C800 / C50 * Icon_minitimeWed Oct 03, 2018 7:27 pm
looking good badger mate
» * False Swing Arm Removal ........................... By Mistress K *
» Decorative Swing Arm Add On Suzuki M800 / M50
» Swing arm mod..Suzuki VL800 / M800 / C800 / M50
» Rear Wheel Removal, Suzuki C800 / M800
» False swing arm mod... a possible problem ???
* False Swing Arm Removal Instruction - Suzuki C800 / C50 * Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
* False Swing Arm Removal Instruction - Suzuki C800 / C50 * Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
* False Swing Arm Removal Instruction - Suzuki C800 / C50 * Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
* False Swing Arm Removal Instruction - Suzuki C800 / C50 * Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
* False Swing Arm Removal Instruction - Suzuki C800 / C50 * Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
* False Swing Arm Removal Instruction - Suzuki C800 / C50 * Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
* False Swing Arm Removal Instruction - Suzuki C800 / C50 * Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
* False Swing Arm Removal Instruction - Suzuki C800 / C50 * Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
* False Swing Arm Removal Instruction - Suzuki C800 / C50 * Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
* False Swing Arm Removal Instruction - Suzuki C800 / C50 * Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
* False Swing Arm Removal Instruction - Suzuki C800 / C50 * Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
* False Swing Arm Removal Instruction - Suzuki C800 / C50 * Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
* False Swing Arm Removal Instruction - Suzuki C800 / C50 * Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
* False Swing Arm Removal Instruction - Suzuki C800 / C50 * Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
* False Swing Arm Removal Instruction - Suzuki C800 / C50 * Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
* False Swing Arm Removal Instruction - Suzuki C800 / C50 * Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
* False Swing Arm Removal Instruction - Suzuki C800 / C50 * Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
* False Swing Arm Removal Instruction - Suzuki C800 / C50 * Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
* False Swing Arm Removal Instruction - Suzuki C800 / C50 * Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
* False Swing Arm Removal Instruction - Suzuki C800 / C50 * Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
