 * False Swing Arm Removal ........................... By Mistress K *
6 posters
* False Swing Arm Removal ........................... By Mistress K * Empty
PostSubject: * False Swing Arm Removal ........................... By Mistress K *   * False Swing Arm Removal ........................... By Mistress K * Icon_minitimeTue Jan 03, 2012 5:50 pm
Thread reproduced with the express permission of Mistress K
False Swing Arm Removal Mod
For this mod I removed the left side swingarm, which is fake!
It only takes 5 bolts to remove.
* False Swing Arm Removal ........................... By Mistress K * 7
Time: 15 minutes
Tools needed: 10mm socket, 10mm box wrench, i think it's like a 7mm or 8mm hex key
instructions:
Remove big black bolt w/allen key from back of swingarm @ final drive and the two bolts that go through swingarm from front to back at front of final drive unit
(see photo below w/acorn nuts)
The bottom bolt shown here behind that strut is the biggest pain in my arse ever!
No way to get a socket in there, and you only have an inch of play with a 10mm box wrench! Aaargh!
* False Swing Arm Removal ........................... By Mistress K * 8
instructions:
Remove the left side lower frame cover, and get after these with the 10mm box wrench, being careful to watch your knuckles!
Doesn't it look nice an clean now?
* False Swing Arm Removal ........................... By Mistress K * 9
I used the chrome acorn nuts from the license plate bracket and some new nickel plated bolts to fill the holes by the final drive unit.
* False Swing Arm Removal ........................... By Mistress K * 10
* False Swing Arm Removal ........................... By Mistress K * 35
Next I fitted my new rear bolt that replaces that big ugly black one!
time: 1 minute
Tools
needed: the same 7mm or 8mm hex key used to remove the original bolt
when removing the swingarm, the oil drain bolt from a BMW 1200
instructions:
Thread the big black ugly bolt out, thread the new bolt in.
PostSubject: Re: * False Swing Arm Removal ........................... By Mistress K *   * False Swing Arm Removal ........................... By Mistress K * Icon_minitimeTue Jan 03, 2012 10:05 pm
Good Job
PostSubject: Re: * False Swing Arm Removal ........................... By Mistress K *   * False Swing Arm Removal ........................... By Mistress K * Icon_minitimeWed Jan 04, 2012 7:17 pm
Excellent write up and it looks much better with the BMW12OO drain plug where that big ugly bolt was
PostSubject: Re: * False Swing Arm Removal ........................... By Mistress K *   * False Swing Arm Removal ........................... By Mistress K * Icon_minitimeWed Jan 04, 2012 8:41 pm
Yeah that one to remember with the drain plug
shwb01
shwb01
PostSubject: Re: * False Swing Arm Removal ........................... By Mistress K *   * False Swing Arm Removal ........................... By Mistress K * Icon_minitimeTue Feb 14, 2012 8:21 pm
How much weight does this mod save? what is the point in Suzuki fitting it in the first place, is it just for style/appearance or does it serve a purpose?
CycleBiker
CycleBiker
PostSubject: Re: * False Swing Arm Removal ........................... By Mistress K *   * False Swing Arm Removal ........................... By Mistress K * Icon_minitimeTue Feb 14, 2012 8:45 pm
It is actually for style/appearance. The earlier ones were made of plastic. The metal ones are fastenend with rubber bushings so they can't do anything anyway. The right side swingarm is harder to remove - that takes an angle grinder!
PostSubject: Re: * False Swing Arm Removal ........................... By Mistress K *   * False Swing Arm Removal ........................... By Mistress K * Icon_minitimeTue Feb 14, 2012 8:53 pm
They were originally made of plastic many years ago (2001 & 2) and were there for no other reason than cosmetic symmetry and to give a hard tail look.
Gotta be honest I have no idea what it weighs tho'
PostSubject: Re: * False Swing Arm Removal ........................... By Mistress K *   * False Swing Arm Removal ........................... By Mistress K * Icon_minitimeWed Feb 15, 2012 4:24 pm
To answer Steve the weight for the false swing arm is 1.73kgs.Also if anyone is interested the weight of the standard exhausts is cans x 2 = 9.53 kgs headers x 2 = 3.65 kgs.Hope this helps in some way.
» * False Swing Arm Removal Instruction - Suzuki C800 / C50 *
» False swing arm mod... a possible problem ???
» false air filter cover
» False air filter mod / 2002 Suzuki Volusia
» * Removing False Swingarm for Suzuki C800 C50 M800 M50 *
* False Swing Arm Removal ........................... By Mistress K * Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
* False Swing Arm Removal ........................... By Mistress K * Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
* False Swing Arm Removal ........................... By Mistress K * Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
* False Swing Arm Removal ........................... By Mistress K * Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
* False Swing Arm Removal ........................... By Mistress K * Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
* False Swing Arm Removal ........................... By Mistress K * Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
* False Swing Arm Removal ........................... By Mistress K * Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
* False Swing Arm Removal ........................... By Mistress K * Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
* False Swing Arm Removal ........................... By Mistress K * Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
* False Swing Arm Removal ........................... By Mistress K * Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
* False Swing Arm Removal ........................... By Mistress K * Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
* False Swing Arm Removal ........................... By Mistress K * Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
* False Swing Arm Removal ........................... By Mistress K * Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
* False Swing Arm Removal ........................... By Mistress K * Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
* False Swing Arm Removal ........................... By Mistress K * Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
* False Swing Arm Removal ........................... By Mistress K * Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
* False Swing Arm Removal ........................... By Mistress K * Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
* False Swing Arm Removal ........................... By Mistress K * Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
* False Swing Arm Removal ........................... By Mistress K * Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
* False Swing Arm Removal ........................... By Mistress K * Icon_minitimeby Brim Wed Aug 07, 2024 12:28 pm
