 Back Wheel Removal using home-made jack (or equivalent)
4 posters
ippikin
ippikin
Back Wheel Removal using home-made jack (or equivalent) Empty
PostSubject: Back Wheel Removal using home-made jack (or equivalent)   Back Wheel Removal using home-made jack (or equivalent) Icon_minitimeSun Mar 11, 2012 7:43 pm
Have just finished some maintenance this weekend; have managed to get the back wheel off from my VZ800 (M800) using only the basic bike lift ( such as Mr I has just made) LINK.
I had to remove the number plate (2 bolts) and also let the tyre down, and this just gives you enough space to wiggle the wheel out from under the rear mudguard. This has allowed me to lubricate the drive shaft as discussed in this section of this forum.
Wiggle the wheel back in, raise it with a suitable bit of wood and slide it back onto the splines of the drive shaft; refit everything, refit number plate and inflate tyre. Job done. No need for a hydraulic bike lift now!
PostSubject: Re: Back Wheel Removal using home-made jack (or equivalent)   Back Wheel Removal using home-made jack (or equivalent) Icon_minitimeSun Mar 11, 2012 8:09 pm
Those wooden lifts really are worth there weight in gold it would seem & so easy to use.
Good to here you had no problem lubricating the drive shaft it gives piece of mind when you here of the odd issue that has been reported even tho they are rare. wood be good if a member did a write up with pics at some point to show how its done. Grob did you find it easy or was there any dificulty with it at all?
admin
The Final Say!
admin
PostSubject: Re: Back Wheel Removal using home-made jack (or equivalent)   Back Wheel Removal using home-made jack (or equivalent) Icon_minitimeSun Mar 11, 2012 8:15 pm
link
PostSubject: Re: Back Wheel Removal using home-made jack (or equivalent)   Back Wheel Removal using home-made jack (or equivalent) Icon_minitimeSun Mar 11, 2012 10:12 pm
Cheers Admin very handy to keep a hard copy.
ippikin
ippikin
PostSubject: Re: Back Wheel Removal using home-made jack (or equivalent)   Back Wheel Removal using home-made jack (or equivalent) Icon_minitimeSun Mar 11, 2012 10:38 pm
Not at all. Undid the 3 chrome capped nuts that attach the drive shaft hub to the drive shaft cover and it literally falls out. Lube up the splines and slip it back in (oo-err! sounds a bit rude). Then do up the nuts again ... I used a bit of Loctite as well.
Really it's easy-peasy.
» VL 800 Rear wheel removal
» Vs800 rear wheel removal please help
» ...the piece of cake rear wheel removal
» Home Made Aluminum Lowers
» Rear Wheel Removal, Suzuki C800 / M800
Back Wheel Removal using home-made jack (or equivalent) Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Back Wheel Removal using home-made jack (or equivalent) Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Back Wheel Removal using home-made jack (or equivalent) Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Back Wheel Removal using home-made jack (or equivalent) Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Back Wheel Removal using home-made jack (or equivalent) Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Back Wheel Removal using home-made jack (or equivalent) Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Back Wheel Removal using home-made jack (or equivalent) Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Back Wheel Removal using home-made jack (or equivalent) Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Back Wheel Removal using home-made jack (or equivalent) Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Back Wheel Removal using home-made jack (or equivalent) Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Back Wheel Removal using home-made jack (or equivalent) Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Back Wheel Removal using home-made jack (or equivalent) Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Back Wheel Removal using home-made jack (or equivalent) Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Back Wheel Removal using home-made jack (or equivalent) Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Back Wheel Removal using home-made jack (or equivalent) Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Back Wheel Removal using home-made jack (or equivalent) Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Back Wheel Removal using home-made jack (or equivalent) Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Back Wheel Removal using home-made jack (or equivalent) Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Back Wheel Removal using home-made jack (or equivalent) Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
Back Wheel Removal using home-made jack (or equivalent) Icon_minitimeby Brim Wed Aug 07, 2024 12:28 pm
