| ...the piece of cake rear wheel removal | |
+4Bunso Steel captain crash Mr Intruder Farmboy 8 posters | Author | Message |
Farmboy Member
| Subject: ...the piece of cake rear wheel removal Fri Apr 13, 2012 12:04 am | |
| ...as I said, after doing the rear wheel on the GoldWing, the Boulevard's a piece of cake. Total time 45minutes, including searching for the 17mm socket that rolled unseen under the tool cabinet. I did have to remove the top muffler to drive the axle out with a drift punch (I used the extension from the socket set). A little wigglewigglewigglewiggle and she was free. Incidentally, the Metzler tire with 2" whitewall retailed at 168.00 cdn (equal right now with usd). Dunlop K55 (or KK5) was 205.00. Don't have my converter handy but is this on a par with uk? | |
| Subject: Re: ...the piece of cake rear wheel removal Fri Apr 13, 2012 6:03 am | |
| Glad to read the axle came out without an issue, we all know what a pain they can be. Love the white wall. | |
| Subject: Re: ...the piece of cake rear wheel removal Fri Apr 13, 2012 12:44 pm | |
| - Farmboy wrote:
- Total time 45minutes, including searching for the 17mm socket that rolled unseen under the tool cabinet.
A friend of mine was looking for a tool once and said "why is it that when you loose something its always in the last place you look?" I gave it a little thought and but didn't reply because I thought he must be having a Because if it wasn't in the last place you looked then why would you still be looking | |
| Subject: Re: ...the piece of cake rear wheel removal Fri Apr 13, 2012 2:49 pm | |
| using a converter, 168 cdn equates to about 106 pounds right now. I see the whitewall metzler marathons going for between £90 - £150 here, so it about par i'd say | |
| | | Farmboy Member
| Subject: Re: ...the piece of cake rear wheel removal Sat Apr 14, 2012 7:32 pm | |
| ...and buttoned back up and taken for a test ride. The entire job solo. Total re-install time about 20 minutes. I'll tell you it's a bugger to torque that nut! lol All in all not a tough job, just attention to detail and procedure. | |
| Subject: Re: ...the piece of cake rear wheel removal Sat Apr 14, 2012 7:43 pm | |
| - Farmboy wrote:
- All in all not a tough job, just attention to detail and procedure.
I think that is the key, most people have the ability to do their own maintenance but are often a little scared to go for it. The satisfaction of completing a job or some maintenance for ones self for me at least is immense. | |
| Subject: Re: ...the piece of cake rear wheel removal Sun Apr 15, 2012 4:54 pm | |
| At least when you do your own maintenance you know the jobs done properly. A lot of garages ain't got a clue, you would be better off letting a kid do it | |
| Subject: Re: ...the piece of cake rear wheel removal Sun Apr 15, 2012 5:20 pm | |
| - captain crash wrote:
- At least when you do your own maintenance you know the jobs done properly. A lot of garages ain't got a clue, you would be better off letting a kid do it
if you go in some garages it looks like sum of em are not much more than kids ooohh shit im getting old | |
| Subject: Re: ...the piece of cake rear wheel removal Sun Apr 15, 2012 5:23 pm | |
| You and me both Morgan, scary shit. | |
| | | churchy Member
| Subject: Re: ...the piece of cake rear wheel removal Fri Jan 06, 2017 2:23 pm | |
| I've just removed the rear wheel without removing the exhausts.Undone the torque arm and rear drum nuts, removed the axle nut and cover cap on left hand side. I then put a socket on the left hand side and tapped the axle with butt end of a hammer to get a start, after which I placed a screwdriver behind the bolt on the left and a rag to protect the frame. A little pressure on the screwdriver whilst turning the socket and out she came. worth its weight in gold to keep that axle maintained took about 15 mins in total. hope this helps some of you guys | |
| Subject: Re: ...the piece of cake rear wheel removal Sat Jan 07, 2017 12:00 am | |
| - churchy wrote:
- . worth its weight in gold to keep that axle maintained took about 15 mins in total.
hope this helps some of you guys Preventative maintenance is worth it on every bike Paul, keep up the good work | |
| Subject: Re: ...the piece of cake rear wheel removal Mon Jan 09, 2017 10:31 pm | |
| Subject: Re: ...the piece of cake rear wheel removal | |
