 Lowers and Hand Guards Fitted M50
4 posters
Lowers and Hand Guards Fitted M50 Empty
PostSubject: Lowers and Hand Guards Fitted M50   Lowers and Hand Guards Fitted M50 Icon_minitimeSat Apr 07, 2012 2:49 pm
This is my attempt at Lowers and Hand Guards
Lowers and Hand Guards Fitted M50 2012-04-06143441
PostSubject: Re: Lowers and Hand Guards Fitted M50   Lowers and Hand Guards Fitted M50 Icon_minitimeSat Apr 07, 2012 5:28 pm
Sure look like those lowers would be doing a really good job Lowers and Hand Guards Fitted M50 3498837457
Have you noticed much difference Alfie?
Do you have the lowers perpendicular to the forks or angled back slightly?
With regards to the hand guards I have been wondering about shape and contemplated several things of which I think trial and error only will probably tell. Although Your input on how your guards are reacting would be great.
1st what shape would give the best deflection of wind? I wonder if angling it so the wind gets pushed to the side is the best way? The reason I am wondering this is because the wind has further to travel so would probably spill over the top anyway, although having the direct impact of the wind taken away from the hands should be dramatic in colder weather all the same! I was wondering if it would be better if the guards were the same size but shaped to curve over and under the hand, giving a tubular effect?
2nd I was wondering if it would be possible to gently heat the plexi glass over an extended period to allow it to curve both around your hand but also then slightly side to side without it buckling by making a wooden shaped jig for the plexi glass to fall into as it heats up.got
Maybe I'm over thinking this because I want to get on with it but don't have time at the moment but also because I know you are also one to try something just to see.
PostSubject: Re: Lowers and Hand Guards Fitted M50   Lowers and Hand Guards Fitted M50 Icon_minitimeSat Apr 07, 2012 5:50 pm
Have not been on a long enough run yet Dave to try the lowers out,I have at the moment set them with the flow of the forks(easy to tweek if ness)The hand guards, good idea making a jig of some kind I found by mistake that even though I used 6mm plexi placing them in hot water to take the protective cling film off started to warp them pretty fast.I used this to my advantage by putting a curve in from side to side,I have had them on for a week or so now and do find them ok,but I have some left over which I shall be experimenting with ie: different shapes,they look fairly big but to clear your gloves they have to be,you could always use chrome trim the u shape stuff they use on car doors to dress them up but I have found basicly the biggest I have found is 6mm which will fit 4mm down.
PostSubject: Re: Lowers and Hand Guards Fitted M50   Lowers and Hand Guards Fitted M50 Icon_minitimeSat Apr 07, 2012 6:32 pm
You really have done a great job alfie Lowers and Hand Guards Fitted M50 3498837457
On a side note I would like to add that I always enjoy reading any mods that in particular you or dave or john or farmboy have either done or had any input into because the engineer in you all comes out. Not that I am taking anything away from anyone else its just that you guys are prolific
Keep up the good work guys and thanks for consistantly coming up with something new Lowers and Hand Guards Fitted M50 881924
PostSubject: Re: Lowers and Hand Guards Fitted M50   Lowers and Hand Guards Fitted M50 Icon_minitimeSat Apr 07, 2012 8:23 pm
Kind words Crash Lowers and Hand Guards Fitted M50 3498837457
PostSubject: Re: Lowers and Hand Guards Fitted M50   Lowers and Hand Guards Fitted M50 Icon_minitimeSat Apr 07, 2012 9:25 pm
Cheers CC always nice to be nice.Lowers and Hand Guards Fitted M50 996187811
Farmboy
PostSubject: Re: Lowers and Hand Guards Fitted M50   Lowers and Hand Guards Fitted M50 Icon_minitimeFri Apr 13, 2012 11:11 am
thanx Crash, very nice of you.
PostSubject: Re: Lowers and Hand Guards Fitted M50   Lowers and Hand Guards Fitted M50 Icon_minitimeSun Apr 22, 2012 9:15 am
Alfie I am having trouble making a bracket that is smooth flowing with no right angles for my hand guards, the main reason is getting two identical ones that mirror each other. So I have given up on that Idea and will make some similar to how you made yours. What thickness have you used for your brackets and did you pick the metal up at a DIY store are you still happy with the brackets and thickness of the metal? (looks like it is well up to the job)
PostSubject: Re: Lowers and Hand Guards Fitted M50   Lowers and Hand Guards Fitted M50 Icon_minitimeSun Apr 22, 2012 2:53 pm
Hi Dave just out and measured the bracket it is 5mm thick, must admit like most of my prototypes it was a length os scap that I came across and thought I will have a job for this.It is well up for the job and does not bounce around at all.
PostSubject: Re: Lowers and Hand Guards Fitted M50   Lowers and Hand Guards Fitted M50 Icon_minitimeSun Apr 22, 2012 3:07 pm
Cheers for that Alfie, I have since writing last been out and tried something else out of desperation to crack on and made a bracket out of the plastic. We will have to see how it holds up but it seems to be fine at the moment.
» * Clear Plastic Home Made Hand Wind Deflectors On Suzuki C800 / C50 *
» Hand guards/wind deflectors
» Memphis Shades Lowers Installed
» M50 Lowers
» Alternative to lowers....windscreen extenders
Suzuki 800 Intruder Club & Forum :: The Garage :: Screens, Lowers & Wind deflectors.-
Lowers and Hand Guards Fitted M50 Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Lowers and Hand Guards Fitted M50 Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Lowers and Hand Guards Fitted M50 Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Lowers and Hand Guards Fitted M50 Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Lowers and Hand Guards Fitted M50 Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Lowers and Hand Guards Fitted M50 Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Lowers and Hand Guards Fitted M50 Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Lowers and Hand Guards Fitted M50 Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Lowers and Hand Guards Fitted M50 Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Lowers and Hand Guards Fitted M50 Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Lowers and Hand Guards Fitted M50 Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Lowers and Hand Guards Fitted M50 Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Lowers and Hand Guards Fitted M50 Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Lowers and Hand Guards Fitted M50 Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Lowers and Hand Guards Fitted M50 Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Lowers and Hand Guards Fitted M50 Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Lowers and Hand Guards Fitted M50 Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Lowers and Hand Guards Fitted M50 Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Lowers and Hand Guards Fitted M50 Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
Lowers and Hand Guards Fitted M50 Icon_minitimeby Brim Wed Aug 07, 2024 12:28 pm
