 Gear Indicator
doobie
ippikin
9 posters
ippikin
ippikin
Gear Indicator Empty
PostSubject: Gear Indicator   Gear Indicator Icon_minitimeSun Jul 08, 2012 1:35 am
Has anyone fitted one of these? I think I would find one useful as always trying to change into 6th!
PostSubject: Re: Gear Indicator   Gear Indicator Icon_minitimeSun Jul 08, 2012 8:49 am
Healtech are one of the biggest sellers of these products.
The one I have linked you to comes with either blue or red display & is also a timing retard eliminator too.
LINK
Gear Indicator GIprobox&unit_pc43_2
ippikin
ippikin
PostSubject: Re: Gear Indicator   Gear Indicator Icon_minitimeSun Jul 08, 2012 10:31 am
Thanks Dave, it sounds good. Just got to save the pennies now!
PostSubject: Re: Gear Indicator   Gear Indicator Icon_minitimeSun Jul 08, 2012 2:42 pm
think there not a bad idear i quite often look for a 6 gear thats not there lol
doobie
doobie
PostSubject: Re: Gear Indicator   Gear Indicator Icon_minitimeSun Jul 08, 2012 4:28 pm
4 years ive been looking and i still aint found it yet......hahaha
PostSubject: Re: Gear Indicator   Gear Indicator Icon_minitimeSun Jul 08, 2012 4:33 pm
I might get one of those for the SV coz I'm always looking for seventh on that one Gear Indicator 852880
PostSubject: Re: Gear Indicator   Gear Indicator Icon_minitimeSun Jul 08, 2012 8:35 pm
Aren't we all .......... Gear Indicator 17537562 ...
ippikin
ippikin
PostSubject: Re: Gear Indicator   Gear Indicator Icon_minitimeMon Jul 09, 2012 7:14 pm
Dave.... is the connector block (I think it's meant to be the diagnostics connector block ??) that the GI Pro plugs into easy to identify? Do you know? Thanks.
PostSubject: Re: Gear Indicator   Gear Indicator Icon_minitimeMon Jul 09, 2012 7:19 pm
Yes mate, you will no issues at all, the kit does come with easy to follow instructions as well. Also if you have any tech questions need a quick answer, you can email Healtech direct and a guy called Norbert will respond almost instantly.
coffeescoffer
coffeescoffer
PostSubject: Re: Gear Indicator   Gear Indicator Icon_minitimeFri Feb 15, 2013 7:17 pm
Sorry to drag up from the dead, but I am considering one of these and am wondering about fitting it to my 2012m50. Could you make a pdf(?) of the fitting instructions so I can work out if it will fit/work. I think the one for the c is the same one recommended for the m, but it doesn't say 2012 model , so your info should be helpful. I did ask them but have not received a reply.
PostSubject: Re: Gear Indicator   Gear Indicator Icon_minitimeFri Feb 15, 2013 7:43 pm
Hi Chris, From what I can gather from reading about them, they just plug into the existing wiring sockets,
http://www.healtech-electronics.com/docs/GIpro-S0x_UsersGuide_en.pdf
coffeescoffer
coffeescoffer
PostSubject: Re: Gear Indicator   Gear Indicator Icon_minitimeFri Feb 15, 2013 9:06 pm
Thanks simbo, I have ordered one. I hope this cures my twitchy left foot/hand. Gear Indicator 433968
ippikin
ippikin
PostSubject: Re: Gear Indicator   Gear Indicator Icon_minitimeSat Feb 16, 2013 12:10 am
Where will you/have you* (delete as appropriate) mounted it?
coffeescoffer
coffeescoffer
PostSubject: Re: Gear Indicator   Gear Indicator Icon_minitimeSat Feb 16, 2013 12:29 am
Not sure yet, I'll post up a pic when done.
JJW
JJW
PostSubject: Re: Gear Indicator   Gear Indicator Icon_minitimeSat Feb 16, 2013 1:01 am
Bought it last year and it has been great.
Simple installation, just ran the wire and then plugged it right in.
Velcro mounted it to the tripple tree.
+1
coffeescoffer
coffeescoffer
PostSubject: Re: Gear Indicator   Gear Indicator Icon_minitimeMon Feb 25, 2013 8:57 pm
If you look at the bike at the side stand side, there are three chrome panels that can be removed. Is this under the middle one?
I want to minimize the amount of chromed stuff I take off as I usually end up scratching it. :)
Were are the wires mentioned?
coffeescoffer
coffeescoffer
PostSubject: Re: Gear Indicator   Gear Indicator Icon_minitimeMon Feb 25, 2013 10:03 pm
I found it.
The guys at Healtech sent me these pics.
Gear Indicator C800_gps_b
Gear Indicator C800_gpsa
coffeescoffer
coffeescoffer
PostSubject: Re: Gear Indicator   Gear Indicator Icon_minitimeTue Feb 26, 2013 2:37 am
I did it.
Gear Indicator P2260005 This is it.
Gear Indicator P2260006 Separated.
Gear Indicator P2260007First lot of wires out.
Gear Indicator P2260008 All wires out.
Gear Indicator P2260009 New connectors on.
Gear Indicator P2260010-1 All plugs in.
Then wired to battery and mount point chosen, as well routing of wires.
PostSubject: Re: Gear Indicator   Gear Indicator Icon_minitimeTue Feb 26, 2013 3:39 am
Brilliant, glad you sorted it so easily. Nice easy installation then, Having a gear indicator is so much nicer.
The guys at Healtech are really good, I usually deal with Norbert and he really goes the extra mile when needed.
Good job done mate. Gear Indicator 3498837457
PostSubject: Re: Gear Indicator   Gear Indicator Icon_minitimeTue Feb 26, 2013 1:19 pm
Nice one Chris, great that you have fitted that & your infomation posted will really healp other members Gear Indicator 276246
coffeescoffer
coffeescoffer
PostSubject: Re: Gear Indicator   Gear Indicator Icon_minitimeTue Feb 26, 2013 9:03 pm
Thanks guys. The most difficult bit was getting the wires out of the connectors, without damaging them or the connectors too much. I ended up using a Stanley knife to cut the plastic a bit so i could use a precision screwdriver to pry the little lever out the way. Took me ages to get the wires out! Everything else went smoothly.
The button you press to set the thing is almost impossible to use and I will be having another go at setting it this am, as it wanted to tell me I was in 6th! See I found it after looking for it so long..... Gear Indicator 2037161312
PostSubject: Re: Gear Indicator   Gear Indicator Icon_minitimeSat May 11, 2013 10:48 pm
Hi, Does anyone know if the GIpro fit the 2005 C800? I can't see why not, but I'd just like to double check before advising to a mate to buy one.
ps, Worthy, you could ask this question if you had the ability to use a keyboard Gear Indicator 852880
PostSubject: Re: Gear Indicator   Gear Indicator Icon_minitimeSun May 12, 2013 8:37 am
The link that Mr I has here would indicate that they do, they are for 2005 bikes and onwards Gear Indicator 184121345
LINK
Gear Indicator
» Gear indicator
» Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard
» Indicator issues
» Rear indicator
» Indicator Install
Gear Indicator Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Gear Indicator Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Gear Indicator Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Gear Indicator Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Gear Indicator Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Gear Indicator Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Gear Indicator Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Gear Indicator Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Gear Indicator Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Gear Indicator Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Gear Indicator Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Gear Indicator Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Gear Indicator Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Gear Indicator Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Gear Indicator Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Gear Indicator Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Gear Indicator Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Gear Indicator Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Gear Indicator Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Gear Indicator Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
