 Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard
6 posters
qqn40z
qqn40z
Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard Empty
PostSubject: Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard   Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard Icon_minitimeMon Sep 16, 2013 3:23 pm
Hi all,
I'm glad I found this forum earlier today, I have been looking on the internet for information about fitting a gear selected indicator to my C50 (2006).  No matter where you look, there is only basic info, no technical info available.  One big problem that I needed to overcome was where to pick up the neutral switch sensor from, yes the system works fine without this, but the only time it shows neutral (0) is at switch on.  Reading what info there is about the problem other riders have encountered, it is necessary to get the signal from the gear indicator (neutral switch) or as close as possible, this is due to diodes in the circuit.  Within 10 minutes of joining this great forum I had the info I needed, I found where the sensor (switch) is located (beneath the secondary gear cover), and which wire to tap into, (BLUE).  Great all's well.  Not a big modification, but a worth while one for less than £10.
qqn40z
qqn40z
PostSubject: Re: Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard   Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard Icon_minitimeMon Sep 16, 2013 4:06 pm
By the way, total time for fitting, just over 1 hour, not counting the fabrication of the bracket.  +ve, -ve available behind headlamp (spare socket).   Run leads up from the two supplied sensors, extend white wire to reach gear (neutral sensor) and make all joints behind headlamp, in the dry!
I made a bracket to hold the two sensors on from aluminium, this is shaped like a reverse "C" with a kink in the upright section to bring the top plate where the sensors are fitted a little closer to the gear linkage rod, bolted using the foot board rear bolt.  The supplied magnet is mounted to the gear change linkage rod, epoxied and cable tie.  Even though I say so myself, a very neat job.  The display is mounted on the right bar, tucked up tightly against the brake fluid reservoir and mirror stalk, this only needs to be cable tied only to the bar using the cable where it exits the display.
I will post pictures when I'm able.
I've not worked that easy bit out yet!!!!
PostSubject: Re: Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard   Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard Icon_minitimeMon Sep 16, 2013 6:22 pm
glad your enjoying the bike and the site Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard 184121345
PostSubject: Re: Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard   Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard Icon_minitimeMon Sep 16, 2013 6:32 pm
Thats great well done to you on doing this, well impressed Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard 184121345
PostSubject: Re: Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard   Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard Icon_minitimeMon Sep 16, 2013 6:48 pm
Good job mate Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard 2170595768 £10 for a gear indicator is very cheap!
qqn40z
qqn40z
PostSubject: Re: Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard   Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard Icon_minitimeTue Sep 17, 2013 9:25 pm
It's just a matter of shopping around on ebay, they're all as near as hell the same, it's just a case of how many gears your box has.  They range from under a tenner to well over forty quid, unless you want a fancy electronic computerised all singing, dancing gizmo, so as far as I can tell they all do the same thing.  Just a matter of thinking the installation out first, if I change my mind with mine, there's nothing drilled, cut, or permanently added.
PostSubject: Re: Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard   Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard Icon_minitimeWed Sep 18, 2013 10:09 pm
Good points made there John.
qqn40z
qqn40z
PostSubject: Re: Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard   Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard Icon_minitimeThu Oct 10, 2013 7:42 pm
Gear indicator now fitted, tried and tested, and works a treat.  If any one fits one, please make sure the magnet sensors are as far apart as possible.  If not you will not get 1st, and 2nd showing on the display, but 3rd shows as 2nd, 4th as 3rd, 5th as 4th.  This baffled my for ages, then the penny dropped, the neutral sensor switch was still grounded until the very last mm of travel then the switch goes open circuit.  To solve this, I put it in 1st and propped the lever in that position and moved the sensor towards the magnet until it gave 1st, then repeated for 2nd.  Gave it a few tries, all good neutral = 0, 1 through to 5 both ways, I then epoxied them in place to my home made bracket.  I've found the easiest way to get the ground (blue) wire, was to open the plug, strip about 1 1/2" off the wire for the gear sensor (neutral), inset it into the socket end of the plug (blue wire) and keep it close to the side of the plug, and push the plug together.  No cutting, or joining and it's weather proof.
PostSubject: Re: Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard   Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard Icon_minitimeThu Oct 10, 2013 7:45 pm
Excellent mod done John, thanks for the brilliant write up. Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard 3322349030
PostSubject: Re: Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard   Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard Icon_minitimeThu Oct 10, 2013 8:07 pm
Good Job John Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard 2170595768
» Indicator Warning Buzzer fitted to C800
» Gear indicator
» Gear Indicator
» Won't change gear
» gear change pedal adjustment
Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Gear change indicator fitted ............... 2006 Suzuki C50 Boulevard Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
