 Project Virago
Sapper-JPD
azcam
Doc Cox
Jimmyboy
oiler
pledge
typan
Badger
Ian800
29 posters
Go to page : Previous  1, 2, 3 ... 6, 7, 8 ... 11, 12, 13  Next
Project Virago - Page 7 Empty
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeSun Feb 23, 2014 9:14 pm
I thought you had one Doc?
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeSun Feb 23, 2014 9:25 pm
I beieve Doc has one from a Hardly Davidson, not the Cambell Geometric one you earlier mentioned?
Doc Cox
The Nutty Professor
Doc Cox
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeSun Feb 23, 2014 9:38 pm
That,s right Dave, this is the exhaust diverter valve from a Harley Rocker along with the pipes chopped and modified.
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeSun Feb 23, 2014 9:44 pm
it ought to work in the same method surely Doc?
Doc Cox
The Nutty Professor
Doc Cox
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeMon Feb 24, 2014 7:32 am
I can,t see any problems Peter, should be pretty plain sailing, have been keeping my eyes open  :shock: for some more of these on Ebay, have found a couple, but, the frustrating  Project Virago - Page 7 291468  thing is they have been collect only and too far to go, still never mind, will keep on trying, regards Doc Cox.
Doc Cox
The Nutty Professor
Doc Cox
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeTue Feb 25, 2014 8:57 pm
Have just been looking through You Tube and found this Virago one, a good looking bike by Docs Chops
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeTue Feb 25, 2014 9:05 pm
Very Nice looking bike! Sounded nice too  Project Virago - Page 7 3498837457
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeWed Feb 26, 2014 3:41 pm
Thats a great bike  Project Virago - Page 7 184121345
Doc Cox
The Nutty Professor
Doc Cox
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeWed Feb 26, 2014 9:03 pm
Yes those guys turn out some nice bikes, more work on the exhaust today, starting with the restrictor valve to the exhaust, had to make a step down pipe as one end of the valve is smaller than the other, could have butt welded it but this means the joint would be more prone to cracking, the rest of the system will be sleeved in a similar manner,
Project Virago - Page 7 Viragoexhaust426-2-14001_zpse72139e7
Here is the valve assembly marked for welding
Project Virago - Page 7 Viragoexhaust426-2-14003_zps8612584b
First weld of the system, plenty more to go
Project Virago - Page 7 Viragoexhaust426-2-14004_zpse5e5f116
Started making  a strong clamp for the rear box, wanted to make sure it clamped evenly all around the pipe to avoid unsightly black moisture trickling from the gaps, this is the first step
Project Virago - Page 7 Viragoexhaust426-2-14006_zps5d4778fb
here is the collar on the pipe, knocked down carefully and beaten to death to swage the exhaust down
Project Virago - Page 7 Viragoexhaust426-2-14007_zpsa3e00dd3
Then up to the rear pipe, the tube had to go through a severe angle so an extra piece was put in to accomplish this, this is the tube and spacer
Project Virago - Page 7 Viragoexhaust426-2-14009_zpsa61e0457
the pipe prior to spot welding, will only put a small weld on just in case it has to be moved, the pipe is in a very tight spot and may need a bit of extra working
Project Virago - Page 7 Viragoexhaust426-2-14010_zpsf0c409da
At long last the system is coming together, doing these parts took me about three hours today but was well worth it, more tomorrow.
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeWed Feb 26, 2014 9:11 pm
Cracking on now Doc, starting to really come together now, the work you are doing is cool.  Project Virago - Page 7 184121345  I bet some of us are getting as keen to see this done and dusted as you are, ooooo the waiting is killing me  Project Virago - Page 7 2740622253
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeWed Feb 26, 2014 9:13 pm
Keep up the good work Doc, A very interesting thread this  Project Virago - Page 7 2170595768  Project Virago - Page 7 3322349030
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeWed Feb 26, 2014 9:17 pm
I am also keen to see what you have done every time I switch the computer on, work harder, work harder you slacker. There are 24 hrs in a day don't you know, sleeping is for wimps.  Project Virago - Page 7 852880
Doc Cox
The Nutty Professor
Doc Cox
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeThu Feb 27, 2014 8:58 am
                                Point taken Dave     Project Virago - Page 7 660750991
                                  " I WILL SLEEP WHEN I AM DEAD"
                                                        Project Virago - Page 7 144396
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeThu Feb 27, 2014 10:11 am
...sleeping is for wimps.  Project Virago - Page 7 852880
Amen to that  Project Virago - Page 7 2747638305  Project Virago - Page 7 666713
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeThu Feb 27, 2014 4:15 pm
Project Virago - Page 7 3213823784  Funny posts Project Virago - Page 7 852880   Also brilliant to see the job coming together with such a great walkthrough being done  Project Virago - Page 7 184121345
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeThu Feb 27, 2014 5:29 pm
You've clearly got some brilliant skills Nigel, I enjoy seeing all the photos of progress
Doc Cox
The Nutty Professor
Doc Cox
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeThu Feb 27, 2014 8:19 pm
Here we go again, "NO SLACKING" "CRACK ON", had a rethink on the rear pipe and have changed it for the better, as you can see space is a bit tight at the rear of the engine,
Project Virago - Page 7 Viragoexhaust427-2-14001_zps29f1f142
So a pair of hard drive magnets hold the exhaust flange in place while fitting the rear pipe
Project Virago - Page 7 Viragoexhaust427-2-14002_zps421d83c0
Instead of using the spacer have cut the pipe to allow it to go through a sharper bend
Project Virago - Page 7 Viragoexhaust427-2-14003_zps6f5c6dd0
This now allows the pipe to sit on the flange without trying to balance a spacer as well
Project Virago - Page 7 Viragoexhaust427-2-14004_zps7b21c709
Have then cut down the pipe and bent each piece into place cutting a small "V" so each flap can fit next to each other instead of overlapping to make a neater job
Project Virago - Page 7 Viragoexhaust427-2-14006_zps8bbd1859
This was then ground down and cleaned with a linishing disc for a smoother finish,
Project Virago - Page 7 Viragoexhaust427-2-14009_zpsecea2c7f
Still not completely smooth but will finish it off tomorrow with a file and emery tape
Project Virago - Page 7 Viragoexhaust427-2-14008_zpseb3cd1e7
Hopefully start on the bottom siamese joining piece tomorrow.
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeThu Feb 27, 2014 9:21 pm
So well thought out    Project Virago - Page 7 2170595768
Doc Cox
The Nutty Professor
Doc Cox
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeThu Feb 27, 2014 9:32 pm
Thanks Crash, seem to have gained momentum now after the initial planning and cutting stage.
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeThu Feb 27, 2014 9:56 pm
looking good now Doc!
Doc Cox
The Nutty Professor
Doc Cox
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeFri Feb 28, 2014 8:43 pm
Thank you Peter, have finished a couple more bits of the system, the rear pipe fitted a treat and looks like should be there, when making something for any of my projects I always try to make the item look as if was fitted from the factory or better
Project Virago - Page 7 Viragoexhaust428-2-14002_zps088325d0
Now the rear pipe is fitted I can go back to the siamese pipe joint  and fabricate the joining pipes starting with the back one, here it is after bit of filing and bending
Project Virago - Page 7 Viragoexhaust428-2-14003_zps1b5ec83c
This is the internal weld, will also be welding on the outside for extra strength
Project Virago - Page 7 Viragoexhaust428-2-14004_zps261e042c
Then on to front pipe, the cutout is to clear a part of the engine casing
Project Virago - Page 7 Viragoexhaust428-2-14006_zps1e64cd6d
Also had to make another pipe adapter for the system , used part of the front pipe that I had cut off
Project Virago - Page 7 Viragoexhaust428-2-14007_zpsc5a1feaa
So, that,s a bit more completed, more tomorrow folks,  Project Virago - Page 7 3005623951
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeFri Feb 28, 2014 9:02 pm
Keep up the good work Doc it's looking good  Project Virago - Page 7 2170595768
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeFri Feb 28, 2014 10:21 pm
Looking forward to it Doc.   Project Virago - Page 7 2170595768
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeFri Feb 28, 2014 11:01 pm
I wish i could weld as it would save me a lot of hassle sometimes.
Like the other day when i had to have a broken stud removed & it cost me £10- just to do it! bummer!
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeSat Mar 01, 2014 7:02 pm
WOW this is getting there  Project Virago - Page 7 184121345
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeSat Mar 01, 2014 11:57 pm
keep up the good work cant wait to see it finished
Doc Cox
The Nutty Professor
Doc Cox
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeSun Mar 02, 2014 8:58 am
Morning guys, good to see interest hasn,t dropped on the project yet, the encouragement is a real boost, had to revamp the system a bit but no real problems, had to notch the end of the pipe so it would clear the cutout piece
Project Virago - Page 7 Viragoexhaust1-3-14001_zpse9055a7a
Then a row of cuts on the end so they could be slightly splayed out so as not to be a restriction in the system
Project Virago - Page 7 Viragoexhaust1-3-14002_zps35dc8b8f
Here is the pipe in question after welding, grinding and linishing
Project Virago - Page 7 Viragoexhaust1-3-14011_zpsa2164b41
This is the outer pipe of the siamese joining box with its first location weld
Project Virago - Page 7 Viragoexhaust1-3-14013_zps602636a6
A closer shot just prior to welding
These are profile shots of the system all tack welded and ready for the full weld up
Project Virago - Page 7 Viragoexhaust1-3-14019_zps74da79f0
Project Virago - Page 7 Viragoexhaust1-3-14018_zpseaca9315
Project Virago - Page 7 Viragoexhaust1-3-14017_zps7d7505fa
Unfortunately couldn,t complete the weld up today, directly after the last weld the gas ran out, but, am not to bothered as there are still other bits that can be done in the meantime, so, here is a photo of the garage yesterday just after the Lister Diesel and large generator had been picked up by the buyers, and there is still room for improvement
Project Virago - Page 7 Viragoexhaust1-3-14021_zps6236df2f
So, have a good day everyone regards Doc Cox  Project Virago - Page 7 433968
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeSun Mar 02, 2014 10:35 am
looks great  Project Virago - Page 7 3498837457  will u be wrapping the down pipes? hehehe and the two into one straight through gunna let of a fantastic sound I just had standard pipes on my one with 8mm bit of metal rod banged through the baffles sounded a lot better and breathed better will you be rejetting the carbs if I remember right they do a kit for these bikes
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeSun Mar 02, 2014 1:32 pm
Looks ace Doc, really coming together matey, lovin it
Morgan I think it going to be really tidied up and the smoothed out and then he is having it ceramic coated from what Ive read. Should look flipppn ace and a real one off
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeSun Mar 02, 2014 2:56 pm
First time we have been able to properly visualise the finished pipe, excellent work so far Nigel.  Project Virago - Page 7 65147
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeSun Mar 02, 2014 3:10 pm
thats looking really good now Doc, should'nt take you long to do it all when you get the gas then?  Project Virago - Page 7 65147
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeSun Mar 02, 2014 5:00 pm
Excellent work Nigel.
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeSun Mar 02, 2014 7:21 pm
Very nice work Doc! The exhaust looks very professional  Project Virago - Page 7 65147
Doc Cox
The Nutty Professor
Doc Cox
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeSun Mar 02, 2014 8:00 pm
Thank you everyone, initially the pipes will be wrapped and ceramic coated at a later date, will be stripping the carbs first and cleaning them in a sonic cleaning tank, currently looking on ebay for one, will be getting the bike rolling road tuned by a firm in Bristol, this will save a lot of trial and error time and I will know that at whatever speed the bike is at the fuel mixture will be correct so no danger of overheating or burning anything out, and once I get the gas it won,t take too long to finish the system.
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeMon Mar 03, 2014 9:46 am
if I remember I think the head gets hot on them the one at back if your standing at the front of bike probably something to do with the oil getting to it or something not sure also have you considered fitting some sort of mesh to stop any shite coming through the frame into the carb then engine that happened on mine and balls it right up
Doc Cox
The Nutty Professor
Doc Cox
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeWed Mar 19, 2014 8:58 pm
Good evening everyone, haven,t done much to the project, have been busy but successfull, having a look through You Tube and found this one, it reminded me about the thread a while ago about the new Yamaha "V" twin, this was a competition run by Yamaha enlisting some of the top bike custom shops and I think these Guys have come up with a good interpretation of the original bike, and what surprised me is the run of the pipes on the engine and the size of the tubing....
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeWed Mar 19, 2014 9:26 pm
That looks like the exhaust your making! It'll look great  Project Virago - Page 7 3498837457  It looks like Marcin's done the decals too  Very Happy
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeWed Mar 19, 2014 9:52 pm
Great video  Project Virago - Page 7 184121345
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeWed Mar 26, 2014 9:17 pm
Should be very interesting to see your personally made and designed exhaust pipe ceramic coated.
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeThu Mar 27, 2014 8:39 am
I popped over to Nigel's yesterday with my wife & guess where Nigel was? Yep you got it, working on one of the angles with the exhaust he was not overly happy with in his garage. He's is like a Duracell bunny, he never stops.  Project Virago - Page 7 852880
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeThu Mar 27, 2014 1:54 pm
wonder where he puts the batteries Dave  Project Virago - Page 7 3213823784
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeThu Mar 27, 2014 4:21 pm
I reckon from what I have read from and about Nigel he will have a solar panel strapped to his head for power like any self respecting powered bunny  Project Virago - Page 7 2740622253
Doc Cox
The Nutty Professor
Doc Cox
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeThu Mar 27, 2014 8:42 pm
It was nice to see Dave and Margaret, funnily enough I have put the large solar panel on the shed and it will be wired in this weekend, also a big thank you to Dave for kicking the Viruses out of my laptop..... :cmate:  Again, they seem to like me, I have actually slowed down quite a bit from when I was younger, probably better at time management now  Project Virago - Page 7 3213823784
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeThu Mar 27, 2014 9:18 pm
Ha Ha many a thing said in jest  Project Virago - Page 7 2740622253
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeFri Mar 28, 2014 3:41 am
Good to see you & the sugar plumb fair as well Doc & no worries about the laptop, it was my pleasure to do something for you.
Good idea Crash to strap a solar panel to Nigel's head, although he might go from a blur to invisible if he had any more gusto.  Project Virago - Page 7 852880
Doc Cox
The Nutty Professor
Doc Cox
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeSat Mar 29, 2014 6:33 pm
My wife says I am like a battery... Ever Ready.... Project Virago - Page 7 3213823784
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeSat Mar 29, 2014 6:46 pm
You need connecting to the grid Doc, Frankenstein lives  Project Virago - Page 7 3213823784
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeSat Mar 29, 2014 9:38 pm
Oh yeah, I better phone DHL so the don't send you ta Wales in your Truck or the farmers could be moaning a bit.  Project Virago - Page 7 3895351029
Doc Cox
The Nutty Professor
Doc Cox
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeSun Mar 30, 2014 10:00 am
A friend of mine had a 50cc Ducati sport, and we used to call that the "Electric Sheep"  lol!
Doc Cox
The Nutty Professor
Doc Cox
PostSubject: Re: Project Virago   Project Virago - Page 7 Icon_minitimeSat Apr 26, 2014 7:13 am
At long last have done some more to the exhaust, wasn,t happy with the way the top pipe followed the line on the casing, so, have done some more cutting and feel it looks better now....
Project Virago - Page 7 Desulphater23-4-14019_zpsc59c7416
This is an insert to clear one of the casing bolts
Project Virago - Page 7 Desulphater23-4-14009_zps9542e682
Project Virago - Page 7 Desulphater23-4-14016_zpsc7c03d22
Haven,t done any welding for a while but the welds are improving, have been looking at buying a DC Tig welder as these give a much better result with minimum distortion
Project Virago - Page 7 I1<a href=Project Virago - Page 7 Desulphater23-4-14013_zps0673f162
A quick coat of paint to make it look better and give an idea of how it will look when Ceramic coated,
Project Virago - Page 7 Desulphater23-4-14017_zps290551a0
Project Virago - Page 7 Desulphater23-4-14030_zps42b09132
Here it is looking much better
Project Virago - Page 7 Desulphater23-4-14037_zpsf02b68c8
Project Virago - Page 7 Desulphater23-4-14039_zpsa8ced9b9
Project Virago - Page 7 Desulphater23-4-14036_zps53383c8f
The only sting in the tail is the Y piece distorted after welding and will have to be re-cut and welded to let the back pipe fit properly, that is one of this weekends jobs  Project Virago - Page 7 643587
Project Virago
Page 7 of 13Go to page : Previous  1, 2, 3 ... 6, 7, 8 ... 11, 12, 13  Next
» Another Virago based project.
» Mr Intruder's, Yamaha Virago Flat Tracker Box of Bit's Project.
» I would like another bike project to tinker with :)
» New Project
» Apehanger project
Suzuki 800 Intruder Club & Forum :: The Garage :: Non Suzuki-800 related Bikes, Mod's & Project's-
Project Virago - Page 7 Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Project Virago - Page 7 Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Project Virago - Page 7 Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Project Virago - Page 7 Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Project Virago - Page 7 Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Project Virago - Page 7 Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Project Virago - Page 7 Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Project Virago - Page 7 Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Project Virago - Page 7 Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Project Virago - Page 7 Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Project Virago - Page 7 Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Project Virago - Page 7 Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Project Virago - Page 7 Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Project Virago - Page 7 Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Project Virago - Page 7 Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Project Virago - Page 7 Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Project Virago - Page 7 Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Project Virago - Page 7 Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Project Virago - Page 7 Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
Project Virago - Page 7 Icon_minitimeby Brim Wed Aug 07, 2024 12:28 pm
