| Apehanger project | |
+8peardrop3 katsd alfie92 Mr Intruder captain crash simbo MarcinG Bluesman 12 posters |
Author | Message |
| Subject: Apehanger project Sat Jan 16, 2016 7:42 pm | |
| Took the plunge today and ordered 16" apehanger bars for my C800. That's the easy bit! I read Dave's thorough write up ( LINK ) of extending wiring a while back and whilst I could handle that myself, the rest of the cables will be out of my comfort zone. So I've found a highly recommended localish bike mechanic who does all sorts of customisations. The work will need to be done in one place so I shall ask him to do the lot! He recons on 2 hours once the cables have arrived but with the electrical work I recon longer. Anyway, we have spoken and the first stage will be to go over with bike and bars to be measured up for the cables. Going to cost I know but I did plan doing this when I bought the bike. One question, the mirrors will be very high up - any ideas for mounting underneath maybe? | |
MarcinG Valued VIP Member
| Subject: Re: Apehanger project Sat Jan 16, 2016 7:54 pm | |
| John, Having mirrors so high - at your head level - is the best thing you can have. Glancing left and right to check them will be so much easier and quicker.
I've been riding with 16" ones for quite a while now and I'd never have the mirrors lower. | |
| Subject: Re: Apehanger project Sat Jan 16, 2016 8:39 pm | |
| - MarcinG wrote:
- John,
I've been riding with 16" ones for quite a while now and I'd never have the mirrors lower. That's good to know Marcin - one less thing to worry about! | |
| Subject: Re: Apehanger project Sat Jan 16, 2016 8:46 pm | |
| Be good to see these when they're fitted | |
| Subject: Re: Apehanger project Sun Jan 17, 2016 7:34 pm | |
| John, Dave (Mr Intruder took one of the chrome arms out of the stock mirrors or shortened it (not sure which) and then remounted them. looks good. Not sure if there is a pick of it like that on here tho? | |
| Subject: Re: Apehanger project Sun Jan 17, 2016 9:25 pm | |
| Is this is the image?: Thanks Crash. Dave, did you cut and re tap? | |
| Subject: Re: Apehanger project Mon Jan 18, 2016 6:40 pm | |
| Subject: Re: Apehanger project Tue Jan 19, 2016 8:00 pm | |
| - simbo wrote:
Here they are still wrapped in protective sleeve. I Went to see my man. He wants me to get clutch and throttle cables. Hmmm I was hoping he would do that. If I have to get them, I might do some of it myself. I Wonder if Dave's re-routing of clutch cable method will work as these are 16" rise plus standard bar clamps? | |
| Subject: Re: Apehanger project Tue Jan 19, 2016 9:53 pm | |
| Yes it would John because I had 14" bars on 2" riser extentions. I no longer have riser extentions but have 16" bars. So simply put, yes it would, as long as the clutch cable is still the same length as 2010 models.
Sorry but I aint got time to cross reference the cable # maybe Sim has? | |
| Subject: Re: Apehanger project Tue Jan 19, 2016 10:04 pm | |
- Yes it would John because I had 14" bars on 2" riser extentions. I no longer have riser extentions but have 16" bars. So simply put, yes it would, as long as the clutch cable is still the same length as 2010 models.
Sorry but I aint got time to cross reference the cable # maybe Sim has? I have a 2013 so assuming the cables are the same it may be worth having a shot. | |
| Subject: Re: Apehanger project Wed Jan 20, 2016 12:10 am | |
| - simbo wrote:
Same cables Thanks for confirming. | |
| Subject: Re: Apehanger project Wed Jan 20, 2016 3:04 pm | |
| Cheers Sim. | |
| Subject: Re: Apehanger project Thu Jan 21, 2016 6:24 pm | |
| Took off the tank today helped by Sim's 'how to do' thread a while back (thanks!). Could see clearly how the clutch cable will be re-routed so that will be OK when the time comes. Went to Maplins and had a look at heat shrink sleeve and heat gun - I will be ok with the electrical splicing! Now the only fly in the ointment is the throttle cable. I could see the mechanism clearly and although the bar end cable removal would be easy enough, the push pull wheel would not be something I'd want to mess with. I apparently need to take the cables from the bike to get them copied but longer. Don't want to leave the bike anywhere so I will either get someone to take off the cables for me at home or buy a duplicate pair just to leave with the cable maker about 45 minutes from here. Complicated! Still, now I'm clear what I can and can't do myself. | |
| Subject: Re: Apehanger project Fri Jan 22, 2016 7:49 pm | |
| Fitted the bars on the bike today to see what they will be like - wow brilliant; felt so comfy. Thought of buying a throttle cable pair from Suzki dealer today so I could send away to have lengthened cables made. But they wanted £60! So found a new pair on EBay for £30 so ordered those. Might start re- routing the clutch cable and lengthening the electrics. I don't see why I can't ride with floppy cables on the original bars if I have to take down the road to have brake hose done and maybe lengthened throttle cables. Hope to have the new bars on in February some time for all the lovely weather! | |
| Subject: Re: Apehanger project Fri Jan 22, 2016 9:49 pm | |
| Good luck on this project John, I can see your going to love it. I am over 6" and rode Mr Intruders (Daves) Bike with the ape hangers fitted and felt so comfortable, gotta say, not really my thing but it felt and made me feel as cool as a cucumber. I have a feeling that what ever happens with you buyng other bikes (as you do) this ones going to be staying with you | |
| Subject: Re: Apehanger project Fri Jan 22, 2016 10:10 pm | |
| - captain crash wrote:
- Good luck on this project John, I can see your going to love it. I am over 6" and rode Mr Intruders (Daves) Bike with the ape hangers fitted and felt so comfortable, gotta say, not really my thing but it felt and made me feel as cool as a cucumber. I have a feeling that what ever happens with you buyng other bikes (as you do) this ones going to be staying with you
Yep Crash, this one is going to be my add-to play thing for many rears to come! Shitting myself a bit about cutting wires etc but with my friends on here standing behind me, I'm secretly having a ball! | |
| Subject: Re: Apehanger project Sat Jan 23, 2016 4:15 pm | |
| Hi John re wires: remember to stagger the cuts by approx. 1" so you don't have a big clump were they are joined up. If you can not get the same colour wires write down what colour goes with what so not to confuse yourself, these are simple things but sometimes overlooked. | |
| Subject: Re: Apehanger project Sat Jan 23, 2016 4:22 pm | |
| John a good tip I use is, center punch the handlebar and triple tree bar clamp were they are, so if you want to change them you can replace the in the same spot. | |
| Subject: Re: Apehanger project Sat Jan 23, 2016 8:05 pm | |
| - alfie92 wrote:
- Hi John re wires: remember to stagger the cuts by approx. 1" so you don't have a big clump were they are joined up. If you can not get the same colour wires write down what colour goes with what so not to confuse yourself, these are simple things but sometimes overlooked.
Cheers, I will remember that.. I've just been practising soldering wires and heat shrinking. I had one joint that broke after the heat shrink was on but then I realised I had applied too much heat and the solder had melted through the heat shrink sleeve - I will have to watch that! | |
| Subject: Re: Apehanger project Sun Jan 24, 2016 1:17 pm | |
| John heat the wire you are going to solder first and apply some solder to it (tinning) then when you join them it will make a stronger joint. | |
| Subject: Re: Apehanger project Sun Jan 24, 2016 7:28 pm | |
| - alfie92 wrote:
- John heat the wire you are going to solder first and apply some solder to it (tinning) then when you join them it will make a stronger joint.
Good tip - I've seen that done on a You Tube video. On the subject of wire, I'm wondering what gauge to get. Dave (Mr.I) used 8amp on his install as it was what he had handy. I don't want to buy thicker than necessary. Maplins has some 6amp which looks about right. Any ideas on this? I suppose I ought to check the specs to make sure sufficient load is handled. | |
| Subject: Re: Apehanger project Mon Jan 25, 2016 7:39 pm | |
| Made good progress today. Re routed the clutch cable and tried it in position on the new bars....it works! Put the stock bars back but left the outsize clutch cable in position. Should be OK to ride like this at least to keep the battery charged. Spare throttle cable may arrive tomorrow so I can send it to be modified. I'm getting more confident to do the work myself. I had a look at the throttle connection - seems fairly straight forward. This way I can keep the bike in my garage rather than some service premises for all to prod and poke. I may well do the electrics myself and if I'm very brave, the extended brake line and bleed. If I get stuck at any stage, I can take it somewhere or even transported. But for the moment getting satisfaction being in charge! | |
| Subject: Re: Apehanger project Mon Jan 25, 2016 7:53 pm | |
| Sounds like your confidence is building with every step John, keep up the good work | |
| Subject: Re: Apehanger project Mon Jan 25, 2016 8:08 pm | |
| Subject: Re: Apehanger project Mon Jan 25, 2016 8:10 pm | |
| Nice one John | |
katsd Very Valued VIP Member
| Subject: Re: Apehanger project Mon Jan 25, 2016 8:52 pm | |
| Gotta say, I'm with John on this. I'd touch very little on the Katana, but I've managed all the mods on mine myself (apart from specialist jobs such as engineering, fabrication, powder coating). To be honest, if it wasn't for the forum, I wouldn't have had the bottle to do it myself. I've found that being able to ask for advice & bouncing ideas off the rest of you guys has been a real confidence builder.
Thanks | |
| Subject: Re: Apehanger project Mon Jan 25, 2016 9:31 pm | |
| Subject: Re: Apehanger project Mon Jan 25, 2016 9:39 pm | |
| Sound well in John, just think all the extras you can buy now with the money you save. Win/Win | |
| Subject: Re: Apehanger project Mon Jan 25, 2016 9:50 pm | |
| - alfie92 wrote:
- Sound well in John, just think all the extras you can buy now with the money you save. Win/Win
It's true! Fancy a fuel processor next! | |
| Subject: Re: Apehanger project Tue Jan 26, 2016 10:32 am | |
| Good man | |
| Subject: Re: Apehanger project Tue Jan 26, 2016 4:42 pm | |
| Coming along nicely can you not disconnect the throttle cables to give you a measurement of how much extra length you'll require? same with the front brake hose too. | |
| Subject: Re: Apehanger project Tue Jan 26, 2016 4:57 pm | |
| - simbo wrote:
- Coming along nicely can you not disconnect the throttle cables to give you a measurement of how much extra length you'll require? same with the front brake hose too.
Yes that should not be a problem but I do have another one now as one of the housing screw heads is stripped . I have posted in another thread asking for advice! | |
| Subject: Re: Apehanger project Fri Jan 29, 2016 3:17 pm | |
| Things moving along slowly. Throttle cables arrived today. They are duplicate new stock items I found on eBay. These go locally next week to be lengthened using the end bits. I ordered my extended brake cable today and should have it end of next week. I have fixed the apes temporarily so I could measure accurately for cable extensions - 10" I have settled on. The bike is still rideable with the long clutch cable as hopefully it will be with 'floppy' throttle and brake. Final job will be the electrics. I've been prcatising soldering and heat sealing. Luckily this time of year the Intruder would hardly be out anyway so good time for a project. Oh what fun! | |
| Subject: Re: Apehanger project Fri Jan 29, 2016 9:00 pm | |
| Slowly but surely is good, sounds like it'll be a thorough job when it all comes together | |
| Subject: Re: Apehanger project Mon Feb 01, 2016 2:43 pm | |
| Hey John, nice to see your cracking on with this. This bike and mod will suit you | |
| Subject: Re: Apehanger project Mon Feb 01, 2016 7:57 pm | |
| Subject: Re: Apehanger project Wed Feb 03, 2016 9:20 pm | |
| - Bluesman wrote:
- mount the new bars and fix each item in turn on to those. The wires - do I need to disconnect the battery when working on them and/or is there a loom connector I can unplug maybe?
I'd mount the bars and fix each item as you get them, No need to disconnect the battery (although it won't harm disconnecting it) just don't switch the ignition on, I'd cut the wires so you have plenty of length either end so as to stagger the joints (as per Alfie's comment) and still give plenty of wire to work with, don't forget to put the fatter shrink wrap over loom before you start soldering, then when you've soldered each joint and shrink wrapped it, you can slide the fat one up to bridge the gap in the outer sheath hiding the whole caboodle. | |
| Subject: Re: Apehanger project Wed Feb 03, 2016 9:28 pm | |
| Cheers Sim - sound advice | |
| Subject: Re: Apehanger project Fri Feb 05, 2016 6:12 pm | |
| John I just cut the wires where I thought I would find them easiest to work on, So it was sought of in the middle of what I could see. | |
| Subject: Re: Apehanger project Sat Feb 06, 2016 10:59 am | |
| Thanks Dave! Now, I had a thought today about splicing the electrical cables on the bike....I'd like to be able to work in the house at a table to do the soldering/heatshrinking, rather than standing up in a cold garage. So I opened up the headlamp where I could see the loom connectors quite clearly: A bit rusty so will give a bit of lubrication! Anyway seems easy to disconnect the cables and feed back through here: Then all I need to do is take off the switch gear and take the cables inside to work on! Off to get my extended throttle cables today so then I will have everything I need. Bought a one man bleed kit yesterday (Little Bleeder £4.99 from M&P) so hopefully the brake line swap should be ok. | |
| Subject: Re: Apehanger project Sat Feb 06, 2016 1:07 pm | |
| Good thinking with the Light bucket, dam why didn't I do that . | |
| Subject: Re: Apehanger project Sat Feb 06, 2016 7:08 pm | |
| Ah Dave, you were the pioneer, I'm just following in your footsteps with a few tweaks! Anyway, voila - the left wiring loom! Next stage, is the snip! | |
| Subject: Re: Apehanger project Sat Feb 06, 2016 7:36 pm | |
| Subject: Re: Apehanger project Sun Feb 07, 2016 4:17 pm | |
| Had quite a good day today. My throttle cables won't be ready now until tomorrow so I decided to crack on with the brakes. Drained the front system, removed old cable and master cylinder/lever assembly. Removed right hand switchgear and bars. Installed new apehanger bars - bloody hell they look tall but I'm sure I'll get used to them. Put the master cylinder on to the new bars. Remembering where the clamps and toggles went, I fitted the lengthened brake cable and tightened up the banjos (remembering the two washers per bolt) when everything was lined up. Pleased with the length - the cable play was exactly right, top and bottom. Bleeding next - not a job I'm looking forward to but the one-way valve kit I have means I can leave open the nipple valve whilst I keep an eye on the master cylinder level. Well, that's the theory anyway - my You Tube Little Bleeder tutorial hopefully should get me there. If I can't get rid of all the air I might come running here for advice! It's all going too smoothly at the moment! | |
| Subject: Re: Apehanger project Sun Feb 07, 2016 5:36 pm | |
| This great, you are cracking on Blues. can't wait for your first ride with them on. The smile on your face will nearly chop your head in half. | |
| Subject: Re: Apehanger project | |
