| Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion | |
+11azcam Ken1964 typan doobie alfie92 smart captain crash fat intruder Bunso Steel simbo Mr Intruder 15 posters |
Author | Message |
| Subject: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Sun Jan 13, 2013 7:51 pm | |
| If you search "air cleaner kit M109" on Ebay, you will find the kit I have used for this modification. I have done it slightly differently to those who have gone before me, so I thought an independent write up was in order. Firstly I bought this kit because it was cheap at £128.00 delivered to the door from the USA but also because it has two complete filters. I have at present only installed the active filter to the right side of the bike but in time I will install the second filter as a dummy on the left, which should make the bike look amazing. The kit comprises of 3 main parts that will be used on the right side of the bike The first thing I did was to cut off the lug pictured below, this ideally needs to be removed as it will hit on the head when fixed in position. It is very easy to cut off as this kit is chromed aluminium. Next I drilled 2 holes to except the air temperature sensor, again very easy as this is aluminium Here you can see it fitted. You will need to increase the external size of the connector that excepts the hose for the PAIR valve, as the M109 has a smaller hose. All I did was to use 4 short lengths of heat shrink over each other for a perfect fit. The next issue you will come across is that the above part is slightly smaller than the air tube that goes up under the tank that it connects too. If you have a fat rubber band such as the type used for pegging down whilst camping you will use one of these. However I did not and couldn't find anything suitable, so I made a gasket to assist in the fit. Necessity caused me use use a bit of ingenuity on this one and make my own gasket/seal. All I did was cut a piece of rubber matting approximately 5mm x 10mm and then wrapped it & subsequently joined it together with rubber heat shrink. Gotta be honest, it was a bitch to get it all in place but did make for a nice tight fit & seal, which you do need My next issue was how to mount it. Previous modders have used a mounting hole at the bottom of the head but I decided not to use it as this is far to visible for me and I wanted to make less of a feature of the mounting. I decided to use the two mounting holes at the top of the heads as this would be far less visible to the eye and probably more rigid due to how short the mounting brackets are. Firstly I cut two short lengths of metal and did a mock up with a spacer that was in the kit, to see how it would hold up. I did have to bend the metal bracket afterwards to make it fit properly but that wasn't an issue. Here are 2 pictures of the brackets before they were cleaned up and sprayed black. As you can see from this mock up, it is much tidier to go to the 2 mounting points at the top of the head, rather than the single mounting point at the bottom of the head Here is a close up of the filter with the mounting points I used. And a few more pics from different angles. I will shortly be fitting the spare filter from this kit as a dummie filter on the other side. Hope this helps anyone wishing to do this mod & if I can be of any help with any queries, please ask. Cheers Dave | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Sun Jan 13, 2013 9:14 pm | |
| Looks brilliant Dave and for that price an absolute bargain Excellent write up as per usual are they black chrome ? some pics look like silver chrome and some black chrome :what1: | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Sun Jan 13, 2013 9:19 pm | |
| Cheers Sim, they are all chrome mate. I think its just my camera and reflection that's making some look black & some pics chrome. | |
Bunso Steel Valued Member
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Sun Jan 13, 2013 9:32 pm | |
| Your bike truly is looking ace now, Love it. Thanks for the detailed instructions | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Sun Jan 13, 2013 9:53 pm | |
| Thanks Joe, I am really happy with how she is turning out. Still got lots I want to do yet though. | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Sun Jan 13, 2013 10:04 pm | |
| Excellent write up Mr I, great job done as usual & expected. Your bike is totally smoking, you and Great idea to run the holding brackets to to the top holes rather than the bottom one, much cleaner looking. Can't work out why it wasn't originally done like that when this mod was first thought of? Can't wait till you do the dummy one on the other side, that will look absolutely brilliant & will be yet another first for suzuki800.com. | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Mon Jan 14, 2013 12:23 pm | |
| may be silly but is it possible to fit led lights in the cone be able to do it on the dummy side but could you do it both sides ? would look frickin nice | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Mon Jan 14, 2013 1:40 pm | |
| Not so silly Morgan, I have already thought of it & it is very easy to do with this filter. I should have it done by the weekend. | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Mon Jan 14, 2013 3:30 pm | |
| Good thinking Morgan and Dave, that would look very cool indeed. | |
smart Valued Member
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Mon Jan 14, 2013 10:32 pm | |
| Excellant as usual Dave,those white led,s look well,they sure stand out.Going to clean my bike tomoz now,yours puts mine to shame.nice one m8.Dave are you going to depair or just blank the pipes?. | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Tue Jan 15, 2013 6:34 am | |
| - smart wrote:
- Dave that looks bloody brill i've been looking at these for a while now was'nt brave enough to take plunge will have to seriously think about it now you've shown the way again would i need to rejet if i fitted one of these??
Thanks for the nice comment. This is a very controversial subject, where many opinions come into play but the larger group of opinions would say that in an ideal world a re-jet would be in order but as long as you are adding only the hi-flow filter & are still running a stock exhaust, your bike should be absolutely fine. - alfie92 wrote:
- Excellant as usual Dave,those white led,s look
well,they sure stand out.Going to clean my bike tomoz now,yours puts mine to shame.nice one m8.Dave are you going to depair or just blank the pipes?. Cheers Alfie, much appreciated mate. I will try to move the PAIR valve to an alternative location if I can but I have not looked into it yet, so I do not know if that is a reasonable train of thought or not. I will de-pair if I have too, simply as I need the location to mount the dummy filter. | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Tue Jan 15, 2013 2:02 pm | |
| Just shove it under the tank Dave,this stops any FI problems showing up aswell.Then if you go for the 109 bike in the future it will be easier to put back. | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Tue Jan 15, 2013 2:42 pm | |
| Yeah I was thinking along the same lines & I will never buy a 109. | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Tue Jan 15, 2013 5:15 pm | |
doobie Valued Member
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Tue Jan 15, 2013 5:46 pm | |
| Glad you got around to it dave, the ride is smoother to. Took mine out last Sunday for a blast but I must say that you've done a brilliant right up | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Tue Jan 15, 2013 6:13 pm | |
| Cheers guys. The good thing about these filters is that the are red, so putting a 24 red LED strip inside really helped it glow in a big way. For the money spent this has gotta be one of the best mods I have done as far as looks go. | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Tue Jan 15, 2013 6:59 pm | |
| That looks absolutely amazing Mr I, almost like it is on fire . I wonder how long it will be before lighting up this kind of filter from the inside rather than the outside becomes a common mod. Not long me thinks Thats gotta be yet another first for suzuki800.com | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Tue Jan 15, 2013 10:13 pm | |
| Looks brilliant Dav,be careful of your mates though (red lights facing forward.)Take it you are not going to progress to a 109 then. | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Tue Jan 15, 2013 11:11 pm | |
| Might be worth putting them on a switch | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Wed Jan 16, 2013 6:19 am | |
| - alfie92 wrote:
- Looks brilliant Dav,be careful of your mates though (red lights facing forward.)Take it you are not going to progress to a 109 then.
Good point on the forward facing red light Alfie, I will scratch that idea. As for the 109, never! | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Wed Jan 16, 2013 12:08 pm | |
| looksg ood lit up dave pic another coulor and your of on your next mod | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Wed Jan 16, 2013 7:10 pm | |
| Yeah I might try one of my old blue LED inside it, as reed facing forward is a bad idea. That may create a green glow. Either way if I do add an LED to it, I will put it on a separate switch. | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Wed Jan 23, 2013 9:06 pm | |
| Dave, I've got one of these now, Have you sprayed your filter with K&N filter oil or is it not necessary ?
If anyone wants one of these filters at half the cost of the kit PM me as I'll only be fitting one.
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Wed Jan 23, 2013 10:46 pm | |
| Sim, Mr I is off Line for a few days while he is in Europe tramping in his truck, he will not be back in the UK until the end of the week, so he might not respond to your message straight away.
Last edited by captain crash on Wed Jan 23, 2013 11:38 pm; edited 1 time in total | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Wed Jan 23, 2013 11:11 pm | |
| OK Cheers Crash Your in charge till he gets back then | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Thu Jan 24, 2013 12:16 am | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Sat Jan 26, 2013 5:48 pm | |
| Welcome back Dave, Is the air flow sensor necessary or can it be removed ? | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Sat Jan 26, 2013 6:34 pm | |
| Cheers Sim, good to be back on home soil. It's not an air flow sensor, it is an air temperature sensor. Ideally this should be fitted & is very easy to do as it is very soft metal. | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Sat Jan 26, 2013 8:12 pm | |
- it is an air temperature sensor. Ideally this should be fitted & is very easy to do as it is very soft metal.
Hmmmm Mine fell off the seat today and I stood on it Does anyone know where I can buy a new one? | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Sat Jan 26, 2013 8:21 pm | |
| You require part # 13650-41F10 Here is one link I have found at £41.57, although I am sure there are plenty of others LINK See how your bike runs without it, might be fine? | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Sat Jan 26, 2013 8:34 pm | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Sat Jan 26, 2013 8:52 pm | |
| Cheers Dave I'll give it a go without first and see what it's like. | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Sun Jan 27, 2013 2:02 pm | |
| Quick update, I've sold the spare chrome filter.I also ordered a air temp sensor for an sv650 which looks identical to the Intruders I've noticed in the past that a lot of sensors and plugs look same on the sv as the Intruder. | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Sun Jan 27, 2013 2:22 pm | |
| I remember someone needed an o2 sensor and sourced it from a completely different Suzuki bike range. Makes sence really for suzuki to have as many parts that are as cross bike usable as possible. good point tho simbo for members to remember to look at other suzukis when they need a part and then just cross reference the part number to be sure it is the same. good way of keeping cost down often | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Sun Jan 27, 2013 8:33 pm | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Sun Jan 27, 2013 8:39 pm | |
| You have done an excellent job Sim, very tidy mate and at that price it feels nicer on the wallet too & Kerching! | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Mon Jan 28, 2013 10:26 pm | |
| Looking neat,looks like it is the way to go. | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Thu Jan 31, 2013 8:04 pm | |
| nice work sim i new there would be skulls on the way but a real tidy placement good job mate looks great keep em comeing | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Fri Feb 01, 2013 6:45 am | |
| Like it | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Fri Feb 01, 2013 4:53 pm | |
| Its always the little touches that make the difference | |
typan Member
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Fri Feb 01, 2013 6:28 pm | |
| great looking mod sim excellent job | |
smart Valued Member
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Thu Feb 14, 2013 9:48 pm | |
| Hi guys fitted the spiked air filter looks great, only trouble is engine runs shite looks like i need to rejet missfiring & back fireing presume its running lean any idea's which jet kit & where from | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion Thu Feb 14, 2013 10:53 pm | |
| Surprised that you are having an exaggerated running issues when only the filter has been installed due to you still running the stock pipes. Looks bloody great by the way. Every bike can be jetted differently, even identical ones. Your setup will require something like this, either a 150 or 155 main, 37.5 pilot jet, dyno spring, dyno needle on 3rd notch, mix screw at 2.5 - 3 turns. Don't quote me though, just a guess.
Last edited by Mr Intruder on Wed Jan 29, 2014 11:47 am; edited 1 time in total | |
| Subject: Re: Chromed Spiked Cone Air Filter From Suzuki M109 - C800 Conversion | |
