| C800 air filter housing - modification | |
snooser Member
| Subject: C800 air filter housing - modification Fri Jul 01, 2011 2:56 am | |
| hi there Im new in here a nd hope to add some small news: As I know that the worst thing for a bike is not breathing and I wanted to mount a K&N filter element, I made this modification: The C800 (C50) has two 25 mm air intake holes on the backside of the housing - MUCH to little, but these are made to meet the european laws. I took the chrome cover and cut a sqare hole at 10 by 10 cm. im front. I did buy a small cover, can be seen here LINK cut two bushes for distance and mounted the small new cover upon the original. The small cover was originally ment to sit tight to the original, but the two bushes holds the cover with a space on app. 1 cm. from original. Now the motor can take all the air it needs, a bit more sound but MUCH more power without any adjustments. And by the way - the bike runs more smooth
| Subject: Re: C800 air filter housing - modification Sat Jul 02, 2011 3:40 pm | |
| Welcome to the site snooser, always great to welcome a newbie especially ones such as yourself that come straight in with a modification If you get a chance to post some pictures of your bike in the showroom or the your modification in this post, it would be great!! I also did a K&N mod which can be seen here LINK I also opened up & lighted up the airbox which can be seen here LINK | |
| Subject: Re: C800 air filter housing - modification Sat Jul 02, 2011 5:20 pm | |
| Welcome Snooser | |
| | | snooser Member
| Subject: Re: C800 air filter housing - modification Sun Jul 03, 2011 12:34 pm | |
| Well, I took a couple of pic's, but cand find out how to show them on this site! I did upload to host ... help an old man, pls! | |
| | | Spike Member
| Subject: Re: C800 air filter housing - modification Sun Jul 03, 2011 12:59 pm | |
| Subject: Re: C800 air filter housing - modification Sun Jul 03, 2011 2:28 pm | |
| - snooser wrote:
- Well, I took a couple of pic's, but cand find out how to show them on this site! I did upload to host ... help an old man, pls!
Not a problem LINK | |
| | | snooser Member
| Subject: Re: C800 air filter housing - modification Tue Jul 05, 2011 3:20 am | |
| here goes: | |
| | | snooser Member
| | | snooser Member
| Subject: Re: C800 air filter housing - modification Tue Jul 05, 2011 3:21 am | |
| | | snooser Member
| Subject: Re: C800 air filter housing - modification Tue Jul 05, 2011 3:22 am | |
| | | snooser Member
| Subject: Re: C800 air filter housing - modification Tue Jul 05, 2011 3:23 am | |
| Subject: Re: C800 air filter housing - modification Tue Jul 05, 2011 9:48 am | |
| Tidy job snooser Beautiful looking bike | |
| | | snooser Member
| Subject: Re: C800 air filter housing - modification Tue Jul 05, 2011 12:19 pm | |
| ... and I just demounted my Vance & Hines Cruzers. Was stopped both in Germany and Denmark (more times) for being too loud. Tryed the "extra" DB-killers, which can be put into the original V&H bafflers. Did try to re-pack the muffler with dampning-cloth - bu they still had to use the blue light and a nasty pointing finger. So, boys and girls: Hanging from the ceiling - a pair of Cruzers, who only have 1000 km on the road. I succeeded in mounting the Lambda-sonde in the upper muffler, by drilling out and tig a nut on. Had the bike on tester and runs much better with the sonde mounted - must have big influence on the comp. aboard | |
| Subject: Re: C800 air filter housing - modification Tue Jul 05, 2011 1:16 pm | |
| Out of curiosity did you have an aftermarket fuel processor fitted as well? | |
| | | snooser Member
| Subject: Re: C800 air filter housing - modification Sun Jul 24, 2011 8:54 am | |
| sorry for not answering sooner, but just had a fouthnight at the westcoast. As for your last quest. fule process. No, in fact its nor nessecary as the C800 has incejtion and the controlbox has 15 steps to be adjusted in - and in each step, u have 3 diff. choises. But it can only be made by the autorized shop. They have a program in a laptop, which they connect to the bike and are able to adjust the "computer" on board. Well, only 5 mins drive from here I found a guy, who is into these things. He also have a ... whats it called in english .... Roling band on whinch he can test the bike. He tested the standard set-up, did a adjustment, rolled, adjustment, rooled, adjustment ... and here goes! Stock exhaust K&N filter with the modificated housing and slight mod. on comp = 8 more HP measured on the rear wheel!!! ... and I got it printed out. After this nobody follows from green light - smother engine turns a bit more at the top and still 18-20 km/liter. APP.: The 2. gear is a devil! So - mods can be made on a standard c800 without powercommand. see http://www.mccruisecontrol.dk/ | |
| | | BottleCap Prospect
| Subject: Re: C800 air filter housing - modification Wed Oct 19, 2011 11:38 pm | |
| Snooser! You are who I need to be talking to!
That after market air filter box cover you bought, is it the same height and width as the stock cover? It looks shallower, not as deep. The stock cover is about 2 inches (5.08 centimeters) deep.
Is it meant to be a direct replacement for the stock cover or just something to bolt on top of the stock cover? I want something to replace the stock, not just cover it.
Thanks. | |
| | | snooser Member
| Subject: Re: C800 air filter housing - modification Thu Oct 20, 2011 6:52 am | |
| Sorry Bottlecap, but the "outer" cover is just a shell, original sold for mounting on top of the original cover. Same design can be bought for the cover down on the side of gearbox. As you can see, I lifted it from the original cover with a spacer 3/4 of an inch. The Idea was to modifi without changing the original look. The big issue with the 800 is AIR. They are taken down because of pollusion. Its not only taking power from the engine, it takes years of the poor engines lifetime.
PS: As I see Mr. Intruder has been trying the extra baffler on the V&H Cruisers. Well, I did give up! Both mine are covered by WD40, crapped and are hanging from the seiling. Nor danish or german police are allowing them. The dB are way too high. I made a cruise together with friends for 'bout 2x600 kilometers and nobody wanted to ride behind me, closer than 50 meters. That stinks. PS: My wife is back on the rear seat now. The funny is that I nearly have lost no power, changing back to stock. So big boys .... AIR! | |
| Subject: Re: C800 air filter housing - modification | |
