 Vance and Hines exhaust
slej
6 posters
slej
slej
Vance and Hines exhaust Empty
PostSubject: Vance and Hines exhaust   Vance and Hines exhaust Icon_minitimeSat Mar 23, 2013 10:12 pm
My bike is new (to me) and I went riding with a buddy who has a Honda 750 with Cobra pipes. I LOVE Betty (Ma bike) but I was definitely a little envious of his bikes sound. I did some youtube searching for exhaust (actually that's how I discovered this board) and decided on Vance and Hines. I pulled the trigger on Vance & Hines Twin Slash Staggered Full Exhaust Chrome 18293 and ready to start the install. I was wondering if there are any specific things I should look for or be careful of when doing it. Also, it sounds like it would be much easier with a second set of hands....should I do this solo or enlist a buddy to help?
PostSubject: Re: Vance and Hines exhaust   Vance and Hines exhaust Icon_minitimeSat Mar 23, 2013 10:24 pm
Always good to have a buddy on hand as the stock pipes are reasonably heavy but I changed my pipes on my own and found it very easy to do so. If a spare pair of hands are available then use them but you really do not need them.
slej
slej
PostSubject: Re: Vance and Hines exhaust   Vance and Hines exhaust Icon_minitimeSat Mar 23, 2013 10:28 pm
Hey Thanks man. much appreciated.
slej
slej
PostSubject: Re: Vance and Hines exhaust   Vance and Hines exhaust Icon_minitimeWed Mar 27, 2013 1:50 am
So I bought the new exhaust from eBay (Vance & Hines Twin Slash Staggered Full Exhaust Chrome 18293) and was fixin to install it this weekend, but it was brought to my attention that I might need to purchase a separate unit (fuel pack) to adjust the fuel injection system to make the bike (2009 C50T) run well. Does anyone know if this is a fact? Thanks in advance for any and all help.
~~Michael
PostSubject: Re: Vance and Hines exhaust   Vance and Hines exhaust Icon_minitimeWed Mar 27, 2013 2:14 am
Only if you upgrade the air filter to a high flow such as a K&N. If you do not touch the air filter and that is left as stock, no need to worry about a fuel injection module.
slej
slej
PostSubject: Re: Vance and Hines exhaust   Vance and Hines exhaust Icon_minitimeWed Mar 27, 2013 9:28 pm
Thanks Mr I. Talked to a buddy on the ship who rides sports bikes, and that makes perfect sense to him too.
PostSubject: Re: Vance and Hines exhaust   Vance and Hines exhaust Icon_minitimeWed Mar 27, 2013 10:37 pm
Nice pipes Michael Vance and Hines exhaust 3498837457 as Mr Intruder says, there's no problems running V&H pipes without the need for a fuel processor, I ran mine with an aftermarket pipe without issue and so have many others, Enjoy the sound my friend, you'll love it.
shadycowboy
shadycowboy
PostSubject: Re: Vance and Hines exhaust   Vance and Hines exhaust Icon_minitimeThu Mar 28, 2013 10:59 pm
I hope you don't like them and then go on to sell to me :-)
slej
slej
PostSubject: Re: Vance and Hines exhaust   Vance and Hines exhaust Icon_minitimeFri Mar 29, 2013 2:31 am
Lol
slej
slej
PostSubject: Re: Vance and Hines exhaust   Vance and Hines exhaust Icon_minitimeMon Apr 08, 2013 12:25 am
Got er done, and I LOVE it. https://youtu.be/GUkve8UAfxU The sound is MUCH better. I now wish I would have done a video of it going down the road before and after!! It she does seem to idle lower, and I now get "pops" when I let off of the gas.....any idea why that might be?
pledge
pledge
PostSubject: Re: Vance and Hines exhaust   Vance and Hines exhaust Icon_minitimeMon Apr 08, 2013 8:27 am
The popping you can hear has more than likely always been there but with baffles you could hardly hear it, I sure that was the case with mine. When I first had my Vance and Hines cruizers on I rode it around with no adjustments done for a while and it was fine, then I had a powercommder and a K and N air filter which made a massive differance, it smoothed the whole runnlng of the engine out and almost all the popping which is more like a rumbling now than popping.
As for the idle speed I think that might be something to do with the back pressure change not too sure on that, someone will tell you what has caused it.
PostSubject: Re: Vance and Hines exhaust   Vance and Hines exhaust Icon_minitimeMon Apr 08, 2013 10:34 am
Michael it is perfectly normal & you can pretty much eliminate the popping if you want to, I actually like it to pop. Either de-pairing the the bike (removing the PAIR valve) or blocking one of the breather tubes will stop the air being injected and igniting the un-burnt fuel in the header pipe that is causing the popping that you are hearing.
BigPunishure
BigPunishure
PostSubject: Re: Vance and Hines exhaust   Vance and Hines exhaust Icon_minitimeTue Apr 09, 2013 5:39 pm
My VZ800 with V & H pipes does quite a bit of popping depending on various factors (bike has a mind of its own in this department). However, I like the popping and burbling... kinda sounds sinister.
BigPunishure
BigPunishure
PostSubject: Re: Vance and Hines exhaust   Vance and Hines exhaust Icon_minitimeTue Apr 09, 2013 5:42 pm
I am curious as to how the other versions of the VZ800 engine sound. I understand that the US version has a 45* off-set dual pin crank and other European countries have a 75* off-set dual pin crank. This would definitely effect the exhaust note.
» fitting vance and hines pipes help!
» Vance & Hines Pro Pipes Fitted to C800
» * Vance & Hines Cruzers, C800 *
» Vance and Hines Cruzers review (Video)
» Vance & Hines Straight shots, fitted
Vance and Hines exhaust Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Vance and Hines exhaust Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Vance and Hines exhaust Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Vance and Hines exhaust Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Vance and Hines exhaust Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Vance and Hines exhaust Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Vance and Hines exhaust Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Vance and Hines exhaust Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Vance and Hines exhaust Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Vance and Hines exhaust Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Vance and Hines exhaust Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Vance and Hines exhaust Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Vance and Hines exhaust Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Vance and Hines exhaust Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Vance and Hines exhaust Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Vance and Hines exhaust Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Vance and Hines exhaust Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Vance and Hines exhaust Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Vance and Hines exhaust Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Vance and Hines exhaust Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
