 Replacement rear fender
3 posters
Theanos
Theanos
Replacement rear fender Empty
PostSubject: Replacement rear fender   Replacement rear fender Icon_minitimeThu Apr 04, 2013 12:02 am
So I've been searching, but I figured you guys would have the answer. Can a person replace the rear fender of a VZ800 Marauder with the rear fender of a C800 Intruder? I'm not a big fan of the flared fender!
PostSubject: Re: Replacement rear fender   Replacement rear fender Icon_minitimeThu Apr 04, 2013 12:38 am
Hmmmm that's a tricky one! I guess one critical factor would be the centres between the fender side rails. If you get chance, measure yours, post it here, then hopefully someone with the C800 will check if it's the same.
If it was compatible, you might have to extend the wiring to the rear light, which obviously sits quite high in the flared tail of the VZ (assuming thats the same as the M800 here), but would sit a little lower with the fender you prefer swooping downwards.
Just my 5c worth Wink
PostSubject: Re: Replacement rear fender   Replacement rear fender Icon_minitimeThu Apr 04, 2013 9:04 am
It can easily be done on the 2000+ models, it's is just a matter of swapping the plastic mudguard and internal frame over and then extending and splicing in the wires. However As you have a 98 VZ it is quite possible that there could be a difference between the rails as pointed out by Mal which we are unaware of. Again as Mal suggested, measure the space and I will do the same.
Theanos
Theanos
PostSubject: Re: Replacement rear fender   Replacement rear fender Icon_minitimeThu Apr 04, 2013 4:57 pm
Sounds great. When I get a chance, I'll get out there. Pretty busy day today.
» Bobber Rear Fender - How / where do i get one ?
» Modified rear fender ...... 2003 Suzuki Volusia
» removing rear fender.
» Completely clean rear fender
» front and rear fender trim
Replacement rear fender Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Replacement rear fender Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Replacement rear fender Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Replacement rear fender Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Replacement rear fender Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Replacement rear fender Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Replacement rear fender Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Replacement rear fender Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Replacement rear fender Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Replacement rear fender Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Replacement rear fender Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Replacement rear fender Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Replacement rear fender Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Replacement rear fender Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Replacement rear fender Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Replacement rear fender Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Replacement rear fender Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Replacement rear fender Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Replacement rear fender Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Replacement rear fender Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
