 Valave Clearances VZ800 M800 2008
4 posters
ippikin
ippikin
Valave Clearances  VZ800 M800 2008 Empty
PostSubject: Valave Clearances VZ800 M800 2008   Valave Clearances  VZ800 M800 2008 Icon_minitimeSun Apr 14, 2013 12:49 pm
HAve spent the morniung in the workshop with the idea of checking the valve clearances on my VZ800. What a bastard of a job; I got so far as getting the tank off, the air filter housing off, the front cylinder chrome trim off the top of the front cyclinder R side, and by lots of fiddling (and praying that I wasn't going to drop the inner (cos you can hardly get to it) bolt), the exhaust tappet cover on the front cylinder. Peering in to the hole, the tappet clearances are so deep that I could not see them, let alone check them. The idea of doing this another 3 times did not appeal so I have chickened out and put it all back together again.
It looks like to get any sort of access to this one you would need to remove the radiator..... but then what about the inlet valves? And the rear cylinder.
In the Haynes manual it says "engine removed for clarity" which is highly useful.
I can't believe this is so difficult!
HAs anyone done the job on this bike? Does anyone have any tips about getting this done or shall I bite the bullet and find a friendly mechanic (but I don't really trust anyone else with my bikes).
Frustrated. Valave Clearances  VZ800 M800 2008 1090754380
PostSubject: Re: Valave Clearances VZ800 M800 2008   Valave Clearances  VZ800 M800 2008 Icon_minitimeSun Apr 14, 2013 7:53 pm
I will be doing this job myself over the next few weeks, so will be able to give real insight into any issues and how to get around them.
PostSubject: Re: Valave Clearances VZ800 M800 2008   Valave Clearances  VZ800 M800 2008 Icon_minitimeSun Apr 14, 2013 9:22 pm
I read somewhere it's easier to do the valves with a bent feeler gauge to gain access.
ippikin
ippikin
PostSubject: Re: Valave Clearances VZ800 M800 2008   Valave Clearances  VZ800 M800 2008 Icon_minitimeMon Apr 15, 2013 12:03 am
Thanks Dave. I will be very interested to hear how you get on. In cool reflection I may have given up too soon and better light required!
ippikin
ippikin
PostSubject: Re: Valave Clearances VZ800 M800 2008   Valave Clearances  VZ800 M800 2008 Icon_minitimeMon Apr 15, 2013 9:29 am
Thanks Simbo....... it looks like it is almost essential!
ippikin
ippikin
PostSubject: Re: Valave Clearances VZ800 M800 2008   Valave Clearances  VZ800 M800 2008 Icon_minitimeWed Apr 24, 2013 8:20 pm
Getting somewhere now; I have had to remove the rubber thing that goes from the top of the air filter to the top of the engine, and disconnected lot of hoses and wires and have actually managed to get all the inspection covers off now. The intake cover of the rear cylinder is the worst!
~Went to take out the spark plugs but haven't got a spanner in the tool kit. Saturday morning ear marked for checking clearances now if I can get the plugs out!
This is not an easy job; leave yourself plenty of time...... you do not want to be rushing this!
ippikin
ippikin
PostSubject: Re: Valave Clearances VZ800 M800 2008   Valave Clearances  VZ800 M800 2008 Icon_minitimeFri May 03, 2013 3:35 pm
After much head scratching and cursing I have come to the conclusion that the only way to get to the intake valves is to remove the throttle body. What a pain! Also access with the feeler gauges is so crap that I think the only way to do it is to loosen the lock nut and adjuster off, slide the appropriate size feeler gauge under and then adjust to snug with the feeler gauge in situ.
~Will be attempting this at the weekend I hope. Valave Clearances  VZ800 M800 2008 880307
ippikin
ippikin
PostSubject: Re: Valave Clearances VZ800 M800 2008   Valave Clearances  VZ800 M800 2008 Icon_minitimeMon May 06, 2013 12:08 am
Just finished putting my bike all back together after finally adjusting the valve clearances and feeling rather pleased with myself at finally having done it....... thought I had set the exhaust clearances to 0.2mm and the intake ones to 0.09mm ......... went to put the feeler gauges away and found that the 0.1mm gauge had (just for badness) stuck to the back of the 0.09mm gauge!! Thus meaning that my intake clearances are now 0.19mm....... suggested range is 0.08mm to 0.13mm. Arrrrghhh! Valave Clearances  VZ800 M800 2008 410694
~So .... it looks like I shall have to redo the intake ones... actually not too bad a job now I know the trick is to remove the throttle body.... this gives you easy access to the intake valves.
~I just can't believe it... what a stupid mistake. Still we all learn by experience!
PostSubject: Re: Valave Clearances VZ800 M800 2008   Valave Clearances  VZ800 M800 2008 Icon_minitimeMon May 06, 2013 10:16 am
Glad you've sorted it Grob, good tip on the throttle bodies Valave Clearances  VZ800 M800 2008 2170595768 I bet finding the gauges stuck together was a spanner throwing moment Valave Clearances  VZ800 M800 2008 410694
PostSubject: Re: Valave Clearances VZ800 M800 2008   Valave Clearances  VZ800 M800 2008 Icon_minitimeMon May 06, 2013 11:11 am
Good on you Grob, great tip. What a shitter about the gauge but at least you will do that one quickly Valave Clearances  VZ800 M800 2008 2170595768
PostSubject: Re: Valave Clearances VZ800 M800 2008   Valave Clearances  VZ800 M800 2008 Icon_minitimeMon May 06, 2013 8:10 pm
Glad your nearly there mate, we all learn by these little hiccups, although it would be nice if sometimes we didn't have too.
ippikin
ippikin
PostSubject: Re: Valave Clearances VZ800 M800 2008   Valave Clearances  VZ800 M800 2008 Icon_minitimeWed May 08, 2013 3:49 pm
Finally all done and yes, it's much quicker the second time round. New plugs as well.... and there is a definite improvement in her perfomance! Had a really fun ride just now..... not sure what's made the difference but what the hell! Happy days! Valave Clearances  VZ800 M800 2008 3629380964
I will post a few tips discovered on this journey later, along with some pics when I get the time.
PostSubject: Re: Valave Clearances VZ800 M800 2008   Valave Clearances  VZ800 M800 2008 Icon_minitimeWed May 08, 2013 5:08 pm
Good man. Valave Clearances  VZ800 M800 2008 3498837457
» My Girl .......... 2008 Suzuki M800/M50 VZ800 K8
» My new ride .......... 2008 VZ800 Intruder M800 K8
» Where do your Crash Bars mount? for Suzuki M800 2008 (VZ800)
» 19/21’’ front wheel on 2008 vz800
» Viper1242's 2008 Suzuki VZ800
Valave Clearances  VZ800 M800 2008 Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Valave Clearances  VZ800 M800 2008 Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Valave Clearances  VZ800 M800 2008 Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Valave Clearances  VZ800 M800 2008 Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Valave Clearances  VZ800 M800 2008 Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Valave Clearances  VZ800 M800 2008 Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Valave Clearances  VZ800 M800 2008 Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Valave Clearances  VZ800 M800 2008 Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Valave Clearances  VZ800 M800 2008 Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Valave Clearances  VZ800 M800 2008 Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Valave Clearances  VZ800 M800 2008 Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Valave Clearances  VZ800 M800 2008 Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Valave Clearances  VZ800 M800 2008 Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Valave Clearances  VZ800 M800 2008 Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Valave Clearances  VZ800 M800 2008 Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Valave Clearances  VZ800 M800 2008 Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Valave Clearances  VZ800 M800 2008 Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Valave Clearances  VZ800 M800 2008 Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Valave Clearances  VZ800 M800 2008 Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Valave Clearances  VZ800 M800 2008 Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
