 Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y
Steen G
9 posters
AmericanJambo
AmericanJambo
Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Empty
PostSubject: Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y   Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeWed May 29, 2013 7:53 pm
I installed my Spaan forward controls today. Unfortunately it was missing the linkage for the shifter side. So I got creative and made a temporary linkage while I'm waiting for the missing one to arrive. Also, after installing I noticed that the controls were about an inch closer in to the bike than the stock controls. So I purchased some longer bolts and moved them out about .5"-.75". That helped quite a bit with the feel. The stretch on them is perfect now. The bike handles so much better for me. It feels like a new bike. Even the shifter feels more solid with a shorter throw. Great upgrade.
Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Img_2021
Here's how I made the linkage adapter. I first cut a piece of threaded bar to the proper length and test fit it.
Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Img_2023
The threaded bar by itself was far too flimsy and flexible to work by itself. So I got a piece of aluminum tubing and cut it short. Then I used split washers and standard nuts to hold the tubing in place. This also distributes the force to the tubing and not the threaded bar.
Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Img_2025
Here's a shot of how I used washers to move the controls out from the frame a bit. Just longer bolts and stainless steel wahsers. Nothing too fancy. Although I would like to find some stainless steel spacers to replace the washers with.
Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Img_2026
PostSubject: Re: Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y   Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeWed May 29, 2013 8:08 pm
Good thinking. In the same line of thinking as what you have already done, you could cut and polish up a couple of segments of steel tube that is the right size to go over the washers and the welded nut, then it would look like big fat steel spacers and nobody would know any better
PostSubject: Re: Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y   Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeWed May 29, 2013 8:35 pm
Nice job! Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y 2170595768 I like those forward controls Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y 210272711
AmericanJambo
AmericanJambo
PostSubject: Re: Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y   Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeWed May 29, 2013 8:42 pm
That is a brilliant idea! That's exactly what I'm going to do. Thanks for the idea brother.
PostSubject: Re: Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y   Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeWed May 29, 2013 8:52 pm
Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y 2170595768 and your bike just keeps getting better
PostSubject: Re: Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y   Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeWed May 29, 2013 10:39 pm
Brilliant job done there Jambo and an excellent write up to Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y 3322349030
PostSubject: Re: Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y   Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeThu May 30, 2013 12:15 am
Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y 3498837457No problem mate. I'd like to see what it looks like when its done.
Steen G
Steen G
PostSubject: Re: Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y   Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeThu May 30, 2013 5:23 am
Is that Cobra slip-on pipes you've got on your bike?
AmericanJambo
AmericanJambo
PostSubject: Re: Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y   Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeThu May 30, 2013 5:49 am
Yep. Cobra slip on drag pipes. No baffles.
PostSubject: Re: Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y   Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeThu May 30, 2013 7:32 am
just looked at your pics again your crome's silly shiney . Keep em cleen ride em mean he he
PostSubject: Re: Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y   Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeThu May 30, 2013 11:52 am
Good job Jambo.
AmericanJambo
AmericanJambo
PostSubject: Re: Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y   Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeThu May 30, 2013 5:26 pm
The funny thing is that I'm about to powder coat or paint most of the chrome gloss black. The top part of the pipes, the chain guard, the rear sprocket, and the wheels are getting gloss black powder coat. The bottom part (slip on part) of the exhaust is getting re-chromed. The big chrome covers under the seat on both sides are getting painted gloss black too.
PostSubject: Re: Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y   Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeThu May 30, 2013 11:30 pm
Well you are clever! I have some very similar looking Highway Hawk forward controls fitted, and with my long legs and the wide tank, I sometimes feel as if the pegs would feel more natural if they were positioned wider, so I shall add to my list of 'mods to do'. Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y 184121345
PostSubject: Re: Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y   Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeFri May 31, 2013 8:59 am
paint away mate i'm not a huge fan of crome
AmericanJambo
AmericanJambo
PostSubject: Re: Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y   Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeFri May 31, 2013 1:31 pm
Do it. Made a big difference in the comfort. Without the extensions i couldn't get enough of my feet on the pegs and i had to squeeze my legs to ride. With the extension i have plenty of peg and i can relax my legs.
AmericanJambo
AmericanJambo
PostSubject: Re: Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y   Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeFri May 31, 2013 1:32 pm
Me either. I like a little bit as an accent but that's it.
PostSubject: Re: Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y   Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeSat Jun 01, 2013 6:59 pm
Very nicely done, looks great. Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y 2170595768
» Forward controls complete - 2000 Marauder VZ800Y
» Removed pair valve *pic* 2000 Marauder VZ800Y
» Painted some parts ....... 2000 Suzuki Marauder VZ800Y
» Moved the headlight on 2000 Suzuki Marauder VZ800Y
» forward controls Fitted to VZ800
Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
Forward controls - homemade shifter linkage - 2000 Marauder VZ800Y Icon_minitimeby Brim Wed Aug 07, 2024 12:28 pm
