| Horn and distribution box | |
coffeescoffer Member
| Subject: Horn and distribution box Sun Jun 02, 2013 9:52 pm | |
| As I wait for my new grips to arrive I am back to pondering the idea of a better horn, I have a Steibel dual set from a previous ride. I was looking at putting them on and saw that I would have to remove the radiator to get at the stock horn. That is something I don't want to get into doing. So I am pondering how wise it would be to add the horns and rewire the (stock)switch through the distribution box so i could unwire it if I wanted. So I am in need of suggestions on were to place the distribution box and the horns. Other items to go via the box will be gear indicator, power outlet, grip warmers and possibly a couple of other things not thought of yet. Ok so I need a head check too! The box will have it's own switch and fuse. | |
| Subject: Re: Horn and distribution box Sun Jun 02, 2013 10:25 pm | |
| I have a Stebel fitted which I love and am about to fit a second one on the other side just for the hell of it. Have a look here at my install ( LINK ) | |
| Subject: Re: Horn and distribution box Sun Jun 02, 2013 10:43 pm | |
| Thanks, very useful. I will be fitting two to start and the same place as you did. Now I need to work out the best place for the box. | |
| Subject: Re: Horn and distribution box Sun Jun 02, 2013 11:25 pm | |
| Glad to help, I fitted my relay behind the left neck cover. | |
| Subject: Re: Horn and distribution box Mon Jun 03, 2013 12:11 am | |
| This diagram shows how I will have it wired, so the relay will go close to the battery. I will have grips. gipro and power socket. vest would be nice.(image from http://www.canyonchasers.net/shop/generic/_img/relay/relay-diagram-final.jpg) | |
| Subject: Re: Horn and distribution box Mon Jun 03, 2013 9:16 am | |
| - coffeescoffer wrote:
- This diagram shows how I will have it wired, so the relay will go close to the battery.
This gives the impression that the wiring shown above is different to the wiring in the link Mr I gave, where in fact they are exactly the same bar the block. The position of the relay along the loom is neither here nor there. (pointed out so as not to confuse someone looking for advice)I would also advise that a small auxiliary fuse box rather than a simple block connector would be a much better way of wiring in your horn if it is as suggested being wired in with various other items. The stebel alone draws 18 amps, so to have that on the same tap as heated grips, gipro, power socket and heated vest would be potentially a massive power draw. | |
| Subject: Re: Horn and distribution box | |
