 Horn on M800 stopped working
3 posters
ippikin
ippikin
Horn on M800 stopped working Empty
PostSubject: Horn on M800 stopped working   Horn on M800 stopped working Icon_minitimeWed Dec 28, 2011 1:18 am
My horn seems to have stopped working; so I need to test it and the wiring. It looks a pig to remove from behind the radiator; has anyone got any tips?
PostSubject: Re: Horn on M800 stopped working   Horn on M800 stopped working Icon_minitimeWed Dec 28, 2011 8:25 am
The horn itself is a bitch to get to, when I installed my Stebel horn I left the stock one in place partly because it was so awkward to get to & just pulled the wires off.
You can still easily test if the actual stock horn is OK or not though by pulling the wires off it and popping them on another one or on to a 12v light. Lots of easy ways to test without using a meter, if something else works off the wires then you know the horn is down.
ippikin
ippikin
PostSubject: Thanks!   Horn on M800 stopped working Icon_minitimeWed Dec 28, 2011 9:17 am
Will give it a try!
ippikin
ippikin
PostSubject: Horn problems   Horn on M800 stopped working Icon_minitimeWed Dec 28, 2011 11:47 am
Have managed to get the horn out.... you can just about get access from the L side of the bike if you move the radiator hose up out of the way and tie it back. The wiring is fine and there is continuity at the switch, but the horn unit is knackered (what a shame!)
I will not be bothering getting a new stock horn, looking at the Stebel instead.
Dave...... did you hide the relay up under the steering column cover? And what size in-line fuse did you use from the battery?
PostSubject: Re: Horn on M800 stopped working   Horn on M800 stopped working Icon_minitimeWed Dec 28, 2011 2:55 pm
Yeah relay is behind neck cover and I used a 30amp fuse
Have a look in the link in my above post, that should explain a little.
PostSubject: Re: Horn on M800 stopped working   Horn on M800 stopped working Icon_minitimeThu Dec 29, 2011 8:30 am
These horns are cheap and you will be shocked at how loud they are affraid Horn on M800 stopped working 249703
» Horn Not working on M800
» Horn Change on M800
» Fitted new horn under Right Side Panel - M800
» Horn and distribution box
» Brake light not working.
Horn on M800 stopped working Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Horn on M800 stopped working Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Horn on M800 stopped working Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Horn on M800 stopped working Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Horn on M800 stopped working Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Horn on M800 stopped working Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Horn on M800 stopped working Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Horn on M800 stopped working Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Horn on M800 stopped working Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Horn on M800 stopped working Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Horn on M800 stopped working Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Horn on M800 stopped working Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Horn on M800 stopped working Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Horn on M800 stopped working Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Horn on M800 stopped working Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Horn on M800 stopped working Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Horn on M800 stopped working Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Horn on M800 stopped working Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Horn on M800 stopped working Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Horn on M800 stopped working Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
