| M800 Oil Leak | |
collo Member
| Subject: M800 Oil Leak Mon Jul 04, 2011 6:26 pm | |
| Since removing the air filter box I have an oil leak somewhere! Anyone got any idea where I should start to look? Collo Sorry been away for 8 weeks, NEVER use talk talk as a provider, biggest bunch of lying **** ever. | |
| Subject: Re: M800 Oil Leak Mon Jul 04, 2011 7:44 pm | |
| If it definately wasn't there before I think you need to check your pipes and breathers, you may have knocked One loose | |
| | | snooser Member
| Subject: Re: M800 Oil Leak Tue Jul 05, 2011 2:45 am | |
| on your left side - between the cylinders, you see a crom cover. This is a valve, letting oil-steam from the crankshaft-housing into the airfilter-housing, to be "burn off" Have a look on the backside of the airfilterhousing. A little hose should be connected there. If you have made some modification and removed the original airfilter-housing, you have to disconnect the PIR-valve (in the little crom house). Can be made simpel by "plugging off" with something as simpel as an golf-tee and a hosestrap. Your motor dont care - the PIR-valve is for European Enviroment Laws only | |
| | | collo Member
| Subject: Re: M800 Oil Leak Wed Jul 13, 2011 7:41 pm | |
| thanks guys for the help, will let you know what the problem was when sorted. thanks again. Collo | |
| Subject: Re: M800 Oil Leak | |
| | | | M800 Oil Leak | |
