 Help & Advice please cause I've an Oil leak
3 posters
devaduo
devaduo
Help & Advice please cause I've an Oil leak Empty
PostSubject: Help & Advice please cause I've an Oil leak   Help & Advice please cause I've an Oil leak Icon_minitimeSat Jun 21, 2014 8:24 am
Riding the bike yesterday I heard like a pop or spurt then noticed when home that there was oil leaking from the top of the rear cylinder
Can't see anything obvious as under the tank and wondering if there is maybe an oil seal around there
Any advice/help would be gratefully received
Graham
PostSubject: Re: Help & Advice please cause I've an Oil leak   Help & Advice please cause I've an Oil leak Icon_minitimeSat Jun 21, 2014 9:47 am
Is the bike running alright is there a loss of power? Can you see any coolant leaking from the same area? Has the coolant level dropped?
Which could indicate the head gasket has failed.
devaduo
devaduo
PostSubject: Re: Help & Advice please cause I've an Oil leak   Help & Advice please cause I've an Oil leak Icon_minitimeSat Jun 21, 2014 10:30 am
The engine runs and sounds fine so I don't suspect a head gasket
PostSubject: Re: Help & Advice please cause I've an Oil leak   Help & Advice please cause I've an Oil leak Icon_minitimeSat Jun 21, 2014 10:38 am
Well that's good, hopefully it will be something simple. I am surprised nobody else has answered your post this is the kind of problem our more knowledgeable members may be able to offer better advice on.
devaduo
devaduo
PostSubject: Re: Help & Advice please cause I've an Oil leak   Help & Advice please cause I've an Oil leak Icon_minitimeSat Jun 21, 2014 11:49 am
Hopefully someone can offer advice and guidence before I try and find someone to fix it
Thank's for replying
Graham
PostSubject: Re: Help & Advice please cause I've an Oil leak   Help & Advice please cause I've an Oil leak Icon_minitimeSat Jun 21, 2014 2:24 pm
It seems very odd that nobody has offered any thoughts on this, it is normally something certain members like to get their teeth into, give it time someone may come up with an something that may help you.
PostSubject: Re: Help & Advice please cause I've an Oil leak   Help & Advice please cause I've an Oil leak Icon_minitimeSat Jun 21, 2014 2:36 pm
Hi Graham, have you had the tank off to see where the oil is coming from? There's the valve cover at the back of the rear cylinder with a seal on it? there's also a breather pipe of some description going into the head on the rear cylinder, sorry for the delayed reply, I've been at work until 2pm and my phones not much use for typing on, I'll re word that? I'm shit at typing on my phone.
PostSubject: Re: Help & Advice please cause I've an Oil leak   Help & Advice please cause I've an Oil leak Icon_minitimeWed Jun 25, 2014 8:29 am
Hi,Graham. Have you any updates on your oil leak problem?
» vs 750 oil leak ?
» M800 Oil Leak
» Clutch advice
» Oil leak from 1994 VS800 Intruder - right side, but only while running
» Bit of advice please.
Help & Advice please cause I've an Oil leak Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
Help & Advice please cause I've an Oil leak Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Help & Advice please cause I've an Oil leak Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Help & Advice please cause I've an Oil leak Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Help & Advice please cause I've an Oil leak Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Help & Advice please cause I've an Oil leak Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Help & Advice please cause I've an Oil leak Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Help & Advice please cause I've an Oil leak Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Help & Advice please cause I've an Oil leak Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Help & Advice please cause I've an Oil leak Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Help & Advice please cause I've an Oil leak Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Help & Advice please cause I've an Oil leak Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Help & Advice please cause I've an Oil leak Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Help & Advice please cause I've an Oil leak Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Help & Advice please cause I've an Oil leak Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Help & Advice please cause I've an Oil leak Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Help & Advice please cause I've an Oil leak Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Help & Advice please cause I've an Oil leak Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Help & Advice please cause I've an Oil leak Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Help & Advice please cause I've an Oil leak Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
