 Taildragger winter project
a4ebh
twenty2
DaveC
Jimmyboy
14 posters
Go to page : Previous  1, 2
Taildragger winter project - Page 2 Empty
PostSubject: Re: Taildragger winter project   Taildragger winter project - Page 2 Icon_minitimeMon Dec 02, 2013 11:34 am
SHIT that's hot hahahahahha
PostSubject: Re: Taildragger winter project   Taildragger winter project - Page 2 Icon_minitimeMon Dec 02, 2013 11:49 am
A bit... that's why it's good practice to wait in between layers for it to cool down, otherwise you have stacked effect.
Might try expanding foam, overlay with something like fibre clay, let that harden and then crack on with fibreglass.
I think that whole discovery process will be more interesting than the actual project haha
PostSubject: Re: Taildragger winter project   Taildragger winter project - Page 2 Icon_minitimeMon Dec 02, 2013 1:42 pm
how about if you covered the foam with fiberglass filler then did your layers on top of that just an idea good luck
PostSubject: Re: Taildragger winter project   Taildragger winter project - Page 2 Icon_minitimeMon Dec 02, 2013 1:56 pm
That might be just the right thing to do mate!
PostSubject: Re: Taildragger winter project   Taildragger winter project - Page 2 Icon_minitimeMon Dec 02, 2013 2:30 pm
cool glad to help as they say upstairs for thinking and all that when your rich give me a job or a free mudguard Taildragger winter project - Page 2 852880
PostSubject: Re: Taildragger winter project   Taildragger winter project - Page 2 Icon_minitimeMon Dec 02, 2013 5:39 pm
I think thats how they make surfboards marcin.... a foam blank with resin over the top.  Not sure if epoxy or polyester resin but maybe google that Taildragger winter project - Page 2 184121345
PostSubject: Re: Taildragger winter project   Taildragger winter project - Page 2 Icon_minitimeMon Dec 02, 2013 7:16 pm
Dry wall adhesive built up in layers?
PostSubject: Re: Taildragger winter project   Taildragger winter project - Page 2 Icon_minitimeMon Dec 02, 2013 7:21 pm
Plastic is very easy to bend into any shape required, I would be inclined to get a sheet of it and make what I wanted and then just connect them together before filling and smoothing them out to look like a complete single fender. More than one way to skin a cat.
PostSubject: Re: Taildragger winter project   Taildragger winter project - Page 2 Icon_minitimeMon Dec 02, 2013 7:29 pm
If you can cut it, sand it, and overall shape it after it hardens, then why not.
PostSubject: Re: Taildragger winter project   Taildragger winter project - Page 2 Icon_minitimeMon Dec 02, 2013 7:30 pm
Not sure I follow boss.
PostSubject: Re: Taildragger winter project   Taildragger winter project - Page 2 Icon_minitimeMon Dec 02, 2013 7:58 pm
Do you mean take a quick template of the shape and use that as a guide for heating the plastic up for pliability and bending into that shape. Then cutting a piece off to be attached that is the correct shape or form?
PostSubject: Re: Taildragger winter project   Taildragger winter project - Page 2 Icon_minitimeMon Dec 02, 2013 8:00 pm
yes I do, sort of.Taildragger winter project - Page 2 3498837457
PostSubject: Re: Taildragger winter project   Taildragger winter project - Page 2 Icon_minitimeMon Dec 02, 2013 9:22 pm
Yeah mate, It's good stuff for things like that, you could mix it and let it go off for a bit and then smear it inside the fender, then once it's dry it sets like rock too! plus it's a fine powder so you'd get a good smooth finish, Plus it's only about a fiver a bag, and 1 should be enough.
PostSubject: Re: Taildragger winter project   Taildragger winter project - Page 2 Icon_minitimeMon Dec 02, 2013 11:54 pm
Right...just to make sure we're on the same page.
I'll have to cut away the foam to remove the bits in red.
I'll have to build the foam up significantly to form the low blue bit.
Taildragger winter project - Page 2 Shape_fender_rear_zps38a5a5e2
However, I have to admit...once drawn, I keep looking at it and that's not the shape I'd like...
There's a thought in the back of my mind that I should ditch taking the cast from old fender and come up with other means of making it.
I need sleep...that's certain.
New ideas tomorrow :]
PostSubject: Re: Taildragger winter project   Taildragger winter project - Page 2 Icon_minitimeTue Dec 03, 2013 9:39 am
Marcin, I can see & understand the bottom but why are you changing the flow of the top, is it because of another mod you have planned?
PostSubject: Re: Taildragger winter project   Taildragger winter project - Page 2 Icon_minitimeTue Dec 03, 2013 9:49 am
Erm...don't know what I meant actually.
Done late and tired. Not much better now..overslept and looking at the screen with one good eye ;D
Looks like I didn't like the curvature there.... Need to do a proper drawing.
azcam
azcam
PostSubject: Re: Taildragger winter project   Taildragger winter project - Page 2 Icon_minitimeTue Dec 03, 2013 11:07 pm
Marcin. Just looked at your drawing. Could you (if you had them) get two fenders. Cut them I'm half nearer the tail. Then join them together to get your mold? You would get a full semicircle then. Then just shape then end by the floor. ? Or make to half molds and join them. Then make your one complete mold? Just a thought.
PostSubject: Re: Taildragger winter project   Taildragger winter project - Page 2 Icon_minitimeTue Dec 03, 2013 11:31 pm
Rather than cut the fender, just fill up to the start of the red line, then release the fender and move it round further to create a bigger semi circle without using the tail of the fender that protrudes out?.
PostSubject: Re: Taildragger winter project   Taildragger winter project - Page 2 Icon_minitimeWed Dec 04, 2013 12:16 am
Arron,
I have two rear fenders but there's no way I'm cutting both up Very Happy
Sim,
That's BLOODY BRILLIANT!
Either that or fill and swap/turn around and fill... Head's buzzin now :]
It'll wait a bit though... getting busy with speedos now...
oh...and I sent you an email...probably ended up in spam box as usual :/
azcam
azcam
PostSubject: Re: Taildragger winter project   Taildragger winter project - Page 2 Icon_minitimeWed Dec 04, 2013 8:23 am
Thats what i said, do two half molds..Good lucK Taildragger winter project - Page 2 2343124779
PostSubject: Re: Taildragger winter project   Taildragger winter project - Page 2 Icon_minitimeWed Dec 04, 2013 9:09 am
Darn it! I really need to stop replying at night.... you did say that indeed!
I'm losing it slowly Very Happy
azcam
azcam
PostSubject: Re: Taildragger winter project   Taildragger winter project - Page 2 Icon_minitimeWed Dec 04, 2013 11:40 am
No probs, been on the net looking at these and you can buy them for around $200 front and back.
But i know thats not the point with you. For me its ideal, but then i dont have the skills or the means to knock out such good work.
Keep it up chap!
PostSubject: Re: Taildragger winter project   Taildragger winter project - Page 2 Icon_minitimeWed Dec 04, 2013 12:08 pm
Don't worry Marcin, I have to be careful any time of day or night that I reply because I read back through my own posts and often have to edit or delete them as the can read as a load of old shit. Sometimes it takes me so long responding and re-editing my own posts before I am finally happy with them & submit, that someone else has responded. Good thing about this site is we all quickly learn other peoples habits and personalities and take that into consideration when responding at times, not always though. Taildragger winter project - Page 2 852880
I think the main thing is that you are taking your time and considering all the options before attacking it. You will find it easier because you will of had time to think and asses all the different ways of doing it.  Taildragger winter project - Page 2 3005623951
PostSubject: Re: Taildragger winter project   Taildragger winter project - Page 2 Icon_minitimeWed Dec 04, 2013 12:29 pm
Mr I,  I agree with what you say as I too sometimes spend more time rewriting a mail than needed. It doesn't seem to match what I want to say then it says too much then it seems just right.
Marcin, do what you think is the right thing for you & it'll be right then.lol!
PostSubject: Re: Taildragger winter project   Taildragger winter project - Page 2 Icon_minitimeWed Dec 04, 2013 1:26 pm
Since we all do it, I reckon it's because we're getting old LOL Taildragger winter project - Page 2 18617 Taildragger winter project - Page 2 2343124779 Taildragger winter project - Page 2 1993399755
PostSubject: Re: Taildragger winter project   Taildragger winter project - Page 2 Icon_minitimeWed Dec 04, 2013 7:43 pm
speak for your self Marcin my brain still thinks it's 25 unfortunately my body feels like I'm an Taildragger winter project - Page 2 855947
Page 2 of 2Go to page : Previous  1, 2
» Winter Project (which one)
» What to do this winter?
» My new project! (89 VS-750)
» New Project
» Apehanger project
Taildragger winter project - Page 2 Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Taildragger winter project - Page 2 Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Taildragger winter project - Page 2 Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Taildragger winter project - Page 2 Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Taildragger winter project - Page 2 Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Taildragger winter project - Page 2 Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Taildragger winter project - Page 2 Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Taildragger winter project - Page 2 Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Taildragger winter project - Page 2 Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Taildragger winter project - Page 2 Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Taildragger winter project - Page 2 Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Taildragger winter project - Page 2 Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Taildragger winter project - Page 2 Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Taildragger winter project - Page 2 Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Taildragger winter project - Page 2 Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Taildragger winter project - Page 2 Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Taildragger winter project - Page 2 Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Taildragger winter project - Page 2 Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Taildragger winter project - Page 2 Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
Taildragger winter project - Page 2 Icon_minitimeby Brim Wed Aug 07, 2024 12:28 pm
