 10" Apes
5 posters
azcam
azcam
10" Apes Empty
PostSubject: 10" Apes   10" Apes Icon_minitimeThu Mar 13, 2014 11:13 am
Gents
Need you advice. I want some apes and have been looking at 10" apes.
Reason being, I am hoping that there will be no need to extend any of the cables.
I'm trying to keep the cost down as the Mod fund is getting a bit low.
Does any one know if i would be able to get away with it.
Cheers Gents.
10" Apes Empty
PostSubject: Re: 10" Apes   10" Apes Icon_minitimeThu Mar 13, 2014 1:34 pm
Someone will confirm but I think you can get away with 14" without cable extensions.
Saying that, you got a new model that has shorter cables.
I'd risk saying that 10" will be more than fine. That's hardly going up.
10" Apes Empty
PostSubject: Re: 10" Apes   10" Apes Icon_minitimeThu Mar 13, 2014 7:00 pm
Hi Arron, You'll get away with the Clutch cable by re routing it, You'd have to get longer Throttle cables unless they can be re routed, but I doubt there'd be enough length even then , You'd need a longer brake hose and extend your wiring for 10" Apes.
azcam
azcam
10" Apes Empty
PostSubject: Re: 10" Apes   10" Apes Icon_minitimeThu Mar 13, 2014 7:21 pm
Bugger.
Thanks Sim.
10" Apes Empty
PostSubject: Re: 10" Apes   10" Apes Icon_minitimeThu Mar 13, 2014 7:27 pm
 :what1:  Oh dear, I am not happy to dismiss what other members have said but for clarity I will do it anyway:  10" Apes 804997
I'm not saying I know everything but the following is what I believe to be true.
You will never get away with a 14" ape hanger bars in a million years without massive changes, I have fitted 14" apes myself. Brake cables + Brake hose + throttle cables + will need to be changed + electrics on both sides will need splicing & extending + clutch cable will need re-routing .  (- LINK -)
As long as you are not putting on higher risers than stock or greater pull-back risers you will be able to fit 10" apes without any real issue.
10" Apes Empty
PostSubject: Re: 10" Apes   10" Apes Icon_minitimeThu Mar 13, 2014 8:41 pm
I thought you could fit 12" apes?
10" Apes Empty
PostSubject: Re: 10" Apes   10" Apes Icon_minitimeThu Mar 13, 2014 8:47 pm
Happy to be corrected.
10" Apes Empty
PostSubject: Re: 10" Apes   10" Apes Icon_minitimeThu Mar 13, 2014 8:50 pm
No worries Marcin.  10" Apes 3498837457
Crash you can't fit 12" apes on a 2013 model, that was just the very early models.
10" Apes Empty
PostSubject: Re: 10" Apes   10" Apes Icon_minitimeThu Mar 13, 2014 9:23 pm
Ooops well I was nearly right   10" Apes 474255
10" Apes Empty
PostSubject: Re: 10" Apes   10" Apes Icon_minitimeThu Mar 13, 2014 9:55 pm
I'm happy to be corrected  Very Happy But, lol I'm innocent until proven guilty  10" Apes 852880
Here's my explanation on my doubts of fitting 10" Apes, (theory, as I've never fitted them) Stock bars are roughly a 5" rise throw in 2" risers (as I've done) and the cable's,wiring, and brake pipe become pretty tight and at their maximum stretch for my own comfort. So with the 10" Apes with stock risers your needing another 3" of play, Clutch cable's fine, re route and alls good (proved by Dave) Brake pipe, Even run round the back of the triple tree would only give 2" more play, Throttle cables, They could be run on the right side of the headstock to give more free play but not something I'd like to play with due to safety reasons (throw the safety card  10" Apes 2740622253 ) Wiring, It's pretty stretched at 2", yes, gain a couple of Inches by going behind the triple tree again but it's a bit of a direct route and not very aesthetically pleasing IMO.
ps. I'd love some Apes on mine without doubt, so someone please prove me conclusively wrong so I can crack on with ordering some  Very Happy
10" Apes Empty
PostSubject: Re: 10" Apes   10" Apes Icon_minitimeThu Mar 13, 2014 10:39 pm
Can't do conclusive I am afraid, only know what people have said. Nothing from personal experience apart from  the extensive work I did to fit the 14" apes, well worth it though all the same.
I do believe that the cables got shorter twice in the mid 2000's. The problem we have is that one person will be happy with a cable at it's limit while another wants some slack. Each to their own though.
10" Apes Empty
PostSubject: Re: 10" Apes   10" Apes Icon_minitimeFri Mar 14, 2014 8:31 am
I got the long ass cables on mine but I reckon I'll replace all the cables anyway.
They're 10 years old now... and don't look so nice overall.
10" Apes Empty
PostSubject: Re: 10" Apes   10" Apes Icon_minitimeFri Mar 14, 2014 10:23 am
OK well I have just been out to the workshop & taken some measurements from my now knackered (since my crash) 14" rise ape hanger bars. I also took some measurements from my now replaced stock C800 cruiser bars & I still stand by what I said. Measuring from riser clamps to the end of the bars when a reduction of 4" was taken into account for the higher rise over Arron's proposed 10" raised ape hanger bars. My calculations have worked out that the cables will be stretched 2-3/4" more than they currently are on the stock bars due to shape changes between the bars. Anyway from my calculations it means that the cable differences would be equalised by doing no more than adding only an extra 2-3/4" over stock riser to the triple tree compared to adding 10" apes.
I am not trying to convince you to do anything, just making my findings known. (Could be wrong though)  10" Apes 852880
azcam
azcam
10" Apes Empty
PostSubject: Re: 10" Apes   10" Apes Icon_minitimeFri Mar 14, 2014 11:02 am
This all sound promising. Thanks Gents for all you input.
If i had to extend everything, then i may as well get bigger Apes.
I could get 1" Risers, but this would raise the cost and im not sure if i would get any benifit from the Apes.
The reason im going for Apes is because at the mo, when I'm ridding my arms are fully extended
and can get quite uncomfortable after a lond ride. So im hoping that the 10" Apes will cure this. My 125 Virago had 10" Apes as standard and i know there not masive but I found it very comfortable, as the position om my wrists was more relaxed (set myself up for wankers cramp jokes there i think).
Will do a bit more digging around i think, to see how much off a difference there will be with 10". i.e rise and rake ect.
Or could all this be solved with new risers. Which for some reason are more expensive than new Bars???
5" Risers? would these fit and need cables extended. This are well cheap and I'm a bit dubious about there quality, would hate to be ridding down the road and then relise my handle bars are not attached to the bike.
http://www.amazon.co.uk/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=suzuki%20intruder%20risers
Again all your help is welcomed. TY
10" Apes Empty
PostSubject: Re: 10" Apes   10" Apes Icon_minitimeFri Mar 14, 2014 11:32 am
I think they (risers) are the ones you mentioned before = LINK
10" Apes Empty
PostSubject: Re: 10" Apes   10" Apes Icon_minitimeFri Mar 14, 2014 12:18 pm
Quote :
Go big or go home LOL Very Happy
I'll be going apeshit..I mean ape  10" Apes 852880 because when I do a U turn I'm burrying the handlebar in my knees and that hurts....and because it looks badass  Twisted Evil
We all like badass  10" Apes 50610
What has happened to me!  10" Apes 215375  It's all you guys and bad influence! Curse you Very Happy
10" Apes Empty
PostSubject: Re: 10" Apes   10" Apes Icon_minitimeFri Mar 14, 2014 12:24 pm
I agree with Marcin, 14" or 16" would look like the proper jobby.  Small apes can look just that, small.
It's a big bike so big after-markets are required.
10" Apes Empty
PostSubject: Re: 10" Apes   10" Apes Icon_minitimeFri Mar 14, 2014 5:32 pm
Aha this could get interesting, 2 of the site gurus have a difference of opinion. Never seen that before  10" Apes 2343124779
Okey Dokey don't start without me I have my 10" Apes 230572241  just gotta go and get my 10" Apes 433108758 Wink
Ding Ding Round 2  10" Apes 852880
10" Apes Empty
PostSubject: Re: 10" Apes   10" Apes Icon_minitimeFri Mar 14, 2014 6:15 pm
Here we go yet again Crash, WASH YOUR MOUTH OUT WITH SOAP.  10" Apes 852880
Me & Sim haven't disagreed, we just haven't agreed. Neither of us have actually fitted the 10" apes so it is just our opinions.
10" Apes Empty
PostSubject: Re: 10" Apes   10" Apes Icon_minitimeFri Mar 14, 2014 7:37 pm
Agreed Dave  10" Apes 3498837457
Arron, I have some of those risers but in 4", your welcome to have them FOC if you pay the postage, You could give them a try and see how much wiring and cable you have to play with? If you feel there's enough free play then go ahead and order the 10" Apes and fit them, Then I get to know for certain whether I can order some 10" for my bike  Very Happy
ps. does anyone have a link for 10" Apes?
azcam
azcam
10" Apes Empty
PostSubject: Re: 10" Apes   10" Apes Icon_minitimeFri Mar 14, 2014 8:22 pm
Sim
http://www.amazon.co.uk/Low-Ape-Hanger-Motorcycle-Handlebars/dp/B002Q00HO6/ref=sr_1_1?ie=UTF8&qid=1394827976&sr=8-1&keywords=10%22+ape+hanger+handlebars
A bit on the expensive side to me.
http://www.ebay.co.uk/sch/i.html?_odkw=suzuki+intruder+800+10%22+ape+hangers&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.X+10%22+ape+hangers+1%22&_nkw=+10%22+ape+hangers+1%22&_sacat=0
Loads on here.
What does it mean, with or with out dimple.
Sim that is a very gracious offer, how comes you havnt got them fitted?
But i will gladly take you up on your offfer, if you PM me your details I'll square it away.
The generosity of the plp on this site never fails to amaze me. Just hope one day ill be in a postion to help someone out.
Also seen these, just as a throw in. Not an option????
http://www.ebay.co.uk/itm/Chrome-Custom-10-Smooth-Top-Handlebar-Risers-for-Harley-Models-Bobber-Chopper-/131133967959?pt=Motorcycles_Parts_Accessories&hash=item1e88318e57
Although there luuuvly
10" Apes Empty
PostSubject: Re: 10" Apes   10" Apes Icon_minitimeFri Mar 14, 2014 9:15 pm
Cheers for those  Arron  10" Apes 3498837457 , I think the dimples are to allow the wiring to come out underneath the switch clusters on the bars? could be wrong though.
The reason I've never fitted them is because they touched the speedo housing at full lock, only slightly but I couldn't be bothered trying to alter or ajust them as I'd already ordered some spiked risers which I preferred and fitted instead.
PM me you address, I'm going to the Post Office tomorrow to renew my photo card licence so I'll send them at the same time, we'll sort the postage at a later date as I've no idea what it will be lol.
10" Apes Empty
PostSubject: Re: 10" Apes   10" Apes Icon_minitimeSat Mar 15, 2014 6:59 am
Looking at those pictures in your links Arron kinda makes sense of the difference of opinions by Mr Intruder and Simbo on fitting 10" apes. The difference in shapes could really make a difference on fitment, fitting one of those could be fine where as fitting another could possibly not be due to the huge differences
10" Apes Empty
10" Apes
» 12inch apes
» * I Want Apes For Suzuki C800 - Help! *
» I fancy some badass apes on C800
» * 9" Clutch Cable Modification For Use With Apes on Suzuki C800 / C50*
10" Apes Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
10" Apes Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
10" Apes Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
10" Apes Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
10" Apes Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
10" Apes Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
10" Apes Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
10" Apes Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
10" Apes Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
10" Apes Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
10" Apes Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
10" Apes Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
10" Apes Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
10" Apes Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
10" Apes Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
10" Apes Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
10" Apes Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
10" Apes Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
10" Apes Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
10" Apes Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
