Subject: Re: Installing coolant/water temperature gauge . . . . . . (Now Done) Sat Apr 12, 2014 7:30 pm
I have enjoyed watching this thread evolve and will definitely be doing it, thanks for all the hard work guy's. I will refer back to this thread ASAP for inspiration.
Subject: Re: Installing coolant/water temperature gauge . . . . . . (Now Done) Sun Apr 13, 2014 7:48 pm
I would also like to thank Jose and Sim for all their hard work,well done lads.
Subject: Re: Installing coolant/water temperature gauge . . . . . . (Now Done) Sun Apr 13, 2014 8:17 pm
Ken1964 Valued Member
Subject: Re: Installing coolant/water temperature gauge . . . . . . (Now Done) Sun Apr 13, 2014 8:25 pm
I must also agree and say that some members really are an asset and deserve praise, very well done Sirs.
TaurusTuga Member
Subject: Re: Installing coolant/water temperature gauge . . . . . . (Now Done) Sun Apr 13, 2014 9:49 pm
Thanks Team for you are always here, ok? But i sincerely hope that this was not the end but a pointing start to go ahead with
Subject: Re: Installing coolant/water temperature gauge . . . . . . (Now Done) Sun Apr 13, 2014 10:00 pm
Did I mention I'm off work for 10 days? The devil makes work for idle hands as they say
The Gauge and Adapter arrived today I'm impressed with the size of the gauge, It's smaller than I'd imagined so it'll give me more options for placement, I'm quite pleased with the adapter too Not that I get excited about adapters or anything pervy? I'd read somewhere that a 22mm adapters size was taken from the internal measurements, which would have been too large, anyway, the measurements are external so it should be a good fit. bloody typical I'm back in work now! so I'll crack on with fitting it as soon as I get a minute.
Subject: Re: Installing coolant/water temperature gauge . . . . . . (Now Done) Wed Apr 23, 2014 8:45 am
Nice one Sim, will look forward to your findings & Install.
Subject: Re: Installing coolant/water temperature gauge . . . . . . (Now Done) Sat Apr 26, 2014 8:40 pm
The installation didn't go to plan, after close inspection of hose 22 I didn't feel the adapter would be suitable in that position, It's too short to get the adapter in before the bend in the pipe and I got a feeling the hose might kink?, I've gone back to the idea of fitting an adapter in the bypass hose and ordered one of suitable size so that's all I'm waiting for now, I've wired the gauge in and had it working with a sensor in some warm water and it works well, I'm impressed with it's novelty factor too!
TaurusTuga Member
Subject: Re: Installing coolant/water temperature gauge . . . . . . (Now Done) Sat Apr 26, 2014 9:05 pm
…I've gone back to the idea of fitting an adapter in the bypass hose and ordered one of suitable size so that's all I'm waiting for now, I've wired the gauge in and had it working with a sensor in some warm water and it works well, I'm impressed with it's novelty factor too!
First step: didn't go well, but of course you didn't give a chance to give up: I WANT ANOTHER ONE WITH OTHER SIZE!! And if the Koso works well on warm water it's only a matter of time to install all and the "temperature will rock it"
Sim……i am watching very heedful with this and the other "bypass the redline tacho"
I am still waiting for the reply about the "later models having dual coils":7348:
Subject: Re: Installing coolant/water temperature gauge . . . . . . (Now Done) Sun Apr 27, 2014 2:02 pm
That looks even better now we have seen it twinkle Will be great to see the final installation with a from Simbo on top
Subject: Re: Installing coolant/water temperature gauge . . . . . . (Now Done) Tue Apr 29, 2014 6:43 am
Looks bloody good. We all know if anyone can get it to run perfectly & work out any hiccups, it will be you Sim. Looking forward to your final install thumbs up.
TaurusTuga Member
Subject: Re: Installing coolant/water temperature gauge . . . . . . (Now Done) Tue Apr 29, 2014 10:34 am
Fitted and working! Fan kicks in just as the gauge is about to hit 102C that's 3C before it's supposed to? whether that's due to the sensor being slightly away from the cylinders or the gauge is slightly inaccurate? or even the fan sensor being inaccurate? who knows lol, To fit the sensor adapter I just used two G clamps to squash the pipe either side of the Joint in the bypass hose to lose minimal coolant while I took the plastic joint out and slipped the adapter in.
This is what it replaced
Here's the fan kicking in
It's an 8mm 1/8 npt fuel pressure gauge adapter (internal diameter) but there's various types on eBay that could be used for the same thing, I chose this because it's solid (just seal the sensor with PTFE tape) as opposed to having 3 seals (either end + sensor) to make up. http://www.ebay.co.uk/itm/110950968481?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Thanks Sim for your kindly attention to share with all your knowledge and experience.
The author of this message was banned from the forum - See the message
Hi Yeah I can't see why not if you can find somewhere suitable for the temperature sensor boss to be fitted? I can't see a By-pass pipe for the water pump on the VX schematic? Is there one? so I presume it would have to be fitted on one of the flow pipes somewhere between the cylinder and and water pump to give a reasonably accurate reading.
hello dear buddy manythanks for the answer - will try to get it done!
keep up the great project - it rocks
sayhello Member
Subject: Re: Installing coolant/water temperature gauge . . . . . . (Now Done) Sun May 21, 2017 8:14 pm
howdy well where to buy this in Germany - plz help me... i am not on ebay - need your help where to fix this part !? Help !! simbo wrote:
sayhello Member
Subject: Re: Installing coolant/water temperature gauge . . . . . . (Now Done) Sun May 21, 2017 8:25 pm
well what is aimed: - i run the vx 800 - and i am pretty happy with it...
I wanted a baseline reading to get a feel for what a typical temp was.
Also I wanted to be able to see temp rises, especially at traffic lights or peak hour traffic. The benefit will be to see and act on the temp increasing rather than wait for an overtemp redlight condition. I only found this out once as the steam was hitting my right boot.
This install proved to be a relatively easy way to achieve this, and I may try the drill and tap method for accuracy in future mods.
well
Subject: Re: Installing coolant/water temperature gauge . . . . . . (Now Done) Sun May 21, 2017 8:29 pm
You'll probably be able to get one from car spares shop or they might order one in? I'm not sure where you'd mount it on the VX as it doesn't seem to have a by pass hose on the thermostat?
butcherman Prospect
Subject: Wow - Simbo - this is juswt a great posting - i love it Tue May 22, 2018 10:14 pm
Wow - Simbo - this is juswt a great posting - i love it - i really like your posting and all what you describe.many thanks for sharing your ideas and experience. simbo wrote:
I've had a look at the Cooling system today to get an idea of what goes where and where things might fit? The best place to fit the sensor adaptor would be on hose '19' as near to the rear cylinder as possible, But it's 'metal' and would mean cutting the pipe and getting a sensor adaptor the same diameter as the pipe and fitting hose over each joint so seal it, Pipe '22' is to short and has a bend in it, so that's not really an option, hose '7' only gets warm after the thermostat has opened so wouldn't give a true reading, especially if the thermostat was faulty, Hose '6' is to short and would only give the temperature of water after it's been cooled by the radiator once the thermostat has opened, Hose '4' would only give the temperature of the coolant in the radiator, So basically that leaves the thermostat By-Pass hose at the bottom (under 7) That would give a true reading of the coolant temperature at all times, There's a joint in the by-pass hose near the left foot peg which would be a ready made place to put a sensor adaptor without it being to visible, that would also allow the wiring to be run along the larger pipe up towards the headstock where the gauge would be situated, These are the hose diagrams again for reference (saves scrolling) and below is what you would need to fit it.
Temperature gauge and sensor http://www.ebay.co.uk/itm/271423794107?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 ###many many thanks - i am going to follow you and do the same on my bike. Again - thanks to you buddy - for sharing your ideas and experience. Have a great day. Greetings the butcher -
