 New Front Tire
2 posters
New Front Tire Empty
PostSubject: New Front Tire   New Front Tire Icon_minitimeThu Apr 17, 2014 8:33 pm
This is a conversation I had on a Trike forum: What do you think?
Originally Posted by ProudTexson New Front Tire Viewpost-right
Has anyone Tried putting a 130-90-16 Rear Tire on the front of a C50 Lehman Trike. I have heard it can be done.
Reply:
I have been selling the following for both Harley and Suzuki C-50 Trike applications. Remember to mount it in REVERSE.
Dunlop GT501 Sport Bias Rear Tire 130-90-16
Specify REAR TIRE when searching.
Lehman Tech since 1998
Champion Tech since 2005
Lehman & Champion Dealer Owner Operator
Jim Murphy
http://www.jpcycles.com/product/ZZ25099?utm_source=google&utm_medium=cpc&device=c&network=s&matchtype=b&gclid=CPqZoaKg6L0CFVFp7AoddUwAbA
This tire has more rubber in the center of tire,which where a Trike wears.
PostSubject: Re: New Front Tire   New Front Tire Icon_minitimeThu Apr 17, 2014 9:18 pm
I can understand fitting a rear tyre on the front of a trike, But why mount it in reverse? The tread pattern would force water to the centre of the tyre in wet conditions, resulting in aquaplaning  New Front Tire 249703
PostSubject: Re: New Front Tire   New Front Tire Icon_minitimeThu Apr 17, 2014 9:33 pm
Sim I am not sure about why. All the research I have done Thru different forums and Google searches say to run a rear tire in reverse to get proper water disbursement.  :what1:
Found this on a forum;
Compare the direction of the tread patterns of a front tire and a rear tire and you'll find that the tread patterns run opposite of each other. When a rear tire is used on the front, the tire needs to be reversed so that the tread pattern runs the correct direction, the same as a front tire would run, and whoever mounts it by the arrow mounts it backwards.
PostSubject: Re: New Front Tire   New Front Tire Icon_minitimeThu Apr 17, 2014 9:46 pm
Found this:
Tires Directional Arrows Explained By Avon Tyres
Published by Cyril Huze August 23rd, 2009 in Builders, Editorial and Wheels.
Before we can talk about directional arrows you must first understand a bit about tread patterns.
There are many different tread patterns but there is one main reason to have any tread and that
is to disperse water. (dust, dirt)
A tread pattern can be designed to disperse more water by making it rotate in only one direction.
Thus, the need for directional arrows. The arrow tells you which way to mount a tire for maximum
water dispersal. Another, less apparent reason for directional arrows is the tread splice.
What is a tread splice? When a tire is manufactured the tread portion of the tire starts out as
a long flat strip. This strip is wrapped around the tire and the two ends are cut on an angle
so one end overlaps the other rather than having square cut ends.
This overlapping point or splice offers a bigger surface area to bond together, rather than the
small surface area provided by square cut ends. (Imagine gluing your fingertips together, as
opposed to gluing along the entire length of your fingers laid on top of each other. Like an
angled splice, the overlapping fingers result in a much stronger bond).
To further ensure the strength of this bond along the tread splice the directional arrow will show
you which way to mount the tire so that when the rider is “on the gas”; the acceleration force on
the rear tire is pressing the splice together, rather than peeling it back.
As for braking, 80 % of the braking should take place in the front on most bikes. Therefore, the
front tread splice is run in the opposite direction than that of the rear, so when the rider is on
the brakes, he’s not peeling the tread splice back.
If you are using a tire that has a directional arrow for rear rotation only and for some reason you
want to put it on the front, make sure it is rotating in the opposite direction so you don’t
aggravate the tread splice.
Avon Tyres.
http://www.cyrilhuzeblog.com/2009/08...by-avon-tyres/ (http://www.cyrilhuzeblog.com/2009/08...by-avon-tyres/)
And This:
New Front Tire Triearrows
PostSubject: Re: New Front Tire   New Front Tire Icon_minitimeThu Apr 17, 2014 10:18 pm
Think I will just buy a good front tire.  New Front Tire 3660331482
New Front Tire
» Retro front tire fitted ......... Suzuki M50
» Tube type tire change
» Tire clearance issues with wider rear tire
» Increase tire width VS800
» Wider Rar Tire 200/70R15
New Front Tire Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
New Front Tire Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
New Front Tire Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
New Front Tire Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
New Front Tire Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
New Front Tire Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
New Front Tire Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
New Front Tire Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
New Front Tire Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
New Front Tire Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
New Front Tire Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
New Front Tire Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
New Front Tire Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
New Front Tire Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
New Front Tire Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
New Front Tire Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
New Front Tire Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
New Front Tire Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
New Front Tire Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
New Front Tire Icon_minitimeby Brim Wed Aug 07, 2024 12:28 pm
