| Coolant Level 2002 volusia | |
PandS Member
| Subject: Coolant Level 2002 volusia Sun Jun 01, 2014 5:30 pm | |
| Hi all I may sound a bit on the simple side but how and where di I check and then fill coolant as just got back from a short trip out and Black Beauty got really hot making her stall and cough and splutter. Any help would be appreciated .... | |
| Subject: Re: Coolant Level 2002 volusia Sun Jun 01, 2014 6:02 pm | |
| Its checked by removing the rear Chromed case that sits below the plastic case below the seat on the left side of the bike with a lock in it. Keep the motorcycle upright, Check the engine coolant level by observing the full and lower lines on the engine coolant reservoir. If the level is below the lower line, add engine coolant to the full line from the engine coolant reservoir filler. Easy when you have found it the first time | |
| | | PandS Member
| Subject: Re: Coolant Level 2002 volusia Sun Jun 01, 2014 8:18 pm | |
| Cheers for that Captain. Found and checked. As you say its easy once done. | |
| Subject: Re: Coolant Level 2002 volusia Sun Jun 01, 2014 8:36 pm | |
| No worries Paul glad your sorted | |
| Subject: Re: Coolant Level 2002 volusia Sun Jun 01, 2014 9:59 pm | |
| - PandS wrote:
- Cheers for that Captain. Found and checked. As you say its easy once done.
Did it need topping up Paul? | |
| | | PandS Member
| Subject: Re: Coolant Level 2002 volusia Sun Jun 01, 2014 11:24 pm | |
| Level was only down slightly in between the two marks. Going to give her a service next week as the air filter looks a bit dirty | |
| Subject: Re: Coolant Level 2002 volusia Sun Jun 01, 2014 11:35 pm | |
| Just a thought Paul, check the cooling fan is working ... These bikes shouldn't really overheat, especially if the coolant level is OK.
Maybe it needs changing, often something that gets overlooked especially of people do their own servicing. Changed mine end of last year and it does seem to run a little cooler after it ( i.e - fan doesn't cut in as often as it used to ) | |
| Subject: Re: Coolant Level 2002 volusia | |
Latest topics | » Hello by Jack70 Yesterday at 4:35 pm
