 Location of pannier brackets
5 posters
Location of pannier brackets Empty
PostSubject: Location of pannier brackets   Location of pannier brackets Icon_minitimeTue Jul 15, 2014 1:10 pm
Ok, I would like your views on how I’m planning to fit pannier brackets for my new heavy duty panniers, with the head scratcher being the fact I already have a sissy bar hung off the fender bolts. Viewed from above it currently looks like this:
Location of pannier brackets FENDERDIAG
As you can see on the M800 the chrome fender rail is quite curved,so after fitting the fender bolts you get quite a gap between the sissy bar and the fender rail. Previously I’d packed this out with washers...
I’ve got 2 sets of pannier brackets to play with... (one lot came with the bags, the others were scrounged off the excellent Mr Sim). They are almost identical and look like this:
Location of pannier brackets 20140715_112331
Option 1: fit extra long fender bolts, and mount the pannier brackets outside of sissy bar... the lugs are 30mm, and with extra wide bags, the whole thing would be quite wide.
Option 2: chop the lugs down to about 15mm... squeeze pannier bracket between the sissy bar and the fender rail, so it acts as a packer too instead of the washers. Wouldnt stick out as far (which is good) and may look neater.
I'm favouring option 2.... do you guys reckon this would be OK?
By the  way, I want the bags to be easily removeable, so dont want to bolt through them with the fender bolt. Instead I’m thinking of drilling a couple of holes in the sissy bar rail, then bolting the bag to it with either a quick release knurled nut or R pin...
Location of pannier brackets 1360309
I’m also going to fashion some find of spring clip to locate the bottom of the bag against the bottom on the pannier bracket.
PostSubject: Re: Location of pannier brackets   Location of pannier brackets Icon_minitimeTue Jul 15, 2014 1:20 pm
Location of pannier brackets 318167775   Just found an earlier post with Sim's ideas on demountable bags...
LINK
Now that's really smart!
To all those mechanical wizzos who have reversed the fender bolts, when drilling out the front retaining nut did you leave the drilled out nut in situ afterwards, or grind it off.? Not long before my hols.... fancy doing this, but don't want to start buggering around taking back wheel off to get in with an angle grinder!!
PostSubject: Re: Location of pannier brackets   Location of pannier brackets Icon_minitimeTue Jul 15, 2014 2:58 pm
More options the better Mal, good work & write up.  Location of pannier brackets 3498837457
PostSubject: Re: Location of pannier brackets   Location of pannier brackets Icon_minitimeTue Jul 15, 2014 5:13 pm
Option 2 sounds good Mal, I just drilled through the front nut and left it in place Mal  Location of pannier brackets 3498837457
PostSubject: Re: Location of pannier brackets   Location of pannier brackets Icon_minitimeTue Jul 15, 2014 5:56 pm
Excellent, thanks sim, I'll give that a go...
DaveC
DaveC
PostSubject: Re: Location of pannier brackets   Location of pannier brackets Icon_minitimeTue Jul 15, 2014 6:42 pm
Location of pannier brackets C13342B8-62FE-4CBD-8A66-84BD366D139E_zpsabvcedzq
This is my fastening Mal, it's the Klic-bag system, it does make it a wide load, using longer bolts!
PostSubject: Re: Location of pannier brackets   Location of pannier brackets Icon_minitimeTue Jul 15, 2014 6:58 pm
Thanks Dave that's helpful.
PostSubject: Re: Location of pannier brackets   Location of pannier brackets Icon_minitimeTue Jul 15, 2014 7:05 pm
Hmmm.. Option 2 rejected. Despite careful angle grinding, the lugs aren't  bang on square, so brackets sandwiched between sissy bar and fender rails aren't sitting right.
Think I'll order proper spacers to bridge the gap, and sit brackets on outside :(
Oh well, I'm not a big fan of filtering anyway, so doesn't matter if the bike with bags is 4 foot wide!!
PostSubject: Re: Location of pannier brackets   Location of pannier brackets Icon_minitimeTue Jul 15, 2014 10:19 pm
Hi Mal don't forget to get (Wide Load) stickers for your panniers.
PostSubject: Re: Location of pannier brackets   Location of pannier brackets Icon_minitimeTue Jul 15, 2014 10:21 pm
Thanks... Actually come to think of it I've already got one sewn on the arse of my jeans  hyst
» Kitting out the Suzuki VZ800
» pannier brackets
» Pannier locks
» pannier query
» Sissy bar & panniers refix / Suzuki Intruder
Location of pannier brackets Icon_minitimeby Jack70 Today at 4:35 pm
Location of pannier brackets Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Location of pannier brackets Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Location of pannier brackets Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Location of pannier brackets Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Location of pannier brackets Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Location of pannier brackets Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Location of pannier brackets Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Location of pannier brackets Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Location of pannier brackets Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Location of pannier brackets Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Location of pannier brackets Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Location of pannier brackets Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Location of pannier brackets Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Location of pannier brackets Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Location of pannier brackets Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Location of pannier brackets Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Location of pannier brackets Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Location of pannier brackets Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Location of pannier brackets Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
