 Drive Shaft Lube
2 posters
Drive Shaft Lube Empty
PostSubject: Drive Shaft Lube   Drive Shaft Lube Icon_minitimeWed Aug 27, 2014 9:59 am
I am going to have a go at checking the drive shaft for grease.
I have had a search but I cant find details of the oil seal that has to be replaced when greasing the wheel end of the drive shaft.
I thought I saw somewhere on here details of the seal but cant find it again.
Is it a special seal...if I take the old one to a bearing supplier are they likely to have one or will it have to come from Suzuki.
PostSubject: Re: Drive Shaft Lube   Drive Shaft Lube Icon_minitimeWed Aug 27, 2014 11:30 am
Hi Alan, if you pour boiling water over the seal it should twist off and be reusable, I've got the part number at home which I'll post later if you want a spare just in case  ..
PostSubject: Re: Drive Shaft Lube   Drive Shaft Lube Icon_minitimeWed Aug 27, 2014 12:35 pm
Sim ...you are a star wagg
PostSubject: Re: Drive Shaft Lube   Drive Shaft Lube Icon_minitimeWed Aug 27, 2014 5:39 pm
Hi Alan, (again  Drive Shaft Lube 852880) It's part number 09283-30051, if you ring Robinsons Foundry on 01227-454366 they'll sort you out with one and confirm the part and number  Drive Shaft Lube 3498837457
PostSubject: Re: Drive Shaft Lube   Drive Shaft Lube Icon_minitimeWed Aug 27, 2014 7:53 pm
Thanks Sim...thats great
Drive Shaft Lube
» Nut's at the top and bottom of the shaft housing
» shaft drive
» Drive shaft grease
» Drive shaft warning
» drive shaft worring
Drive Shaft Lube Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Drive Shaft Lube Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Drive Shaft Lube Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Drive Shaft Lube Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Drive Shaft Lube Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Drive Shaft Lube Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Drive Shaft Lube Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Drive Shaft Lube Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Drive Shaft Lube Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Drive Shaft Lube Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Drive Shaft Lube Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Drive Shaft Lube Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Drive Shaft Lube Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Drive Shaft Lube Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Drive Shaft Lube Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Drive Shaft Lube Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Drive Shaft Lube Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Drive Shaft Lube Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Drive Shaft Lube Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
Drive Shaft Lube Icon_minitimeby Brim Wed Aug 07, 2024 12:28 pm
