 Headwind making bike run like S!#T
5 posters
DANGERTASTIC
DANGERTASTIC
Headwind making bike run like S!#T Empty
PostSubject: Headwind making bike run like S!#T   Headwind making bike run like S!#T Icon_minitimeSat Oct 04, 2014 8:48 pm
01 Marauder running like garbage in any kind of strong headwind.
 Rejetted it last year. 145 Fr 150 RR  and K&N Pod filters
 Ive noticed it doing this before but its usually not SUPER windy.
 Popping and backfiring out of front carb, loses power and stutters.
 Anyone??
PostSubject: Re: Headwind making bike run like S!#T   Headwind making bike run like S!#T Icon_minitimeSun Oct 05, 2014 8:14 pm
Is the air getting channeled towards the carb and being forced in when in a head wind? bit like "Ram Air" causing it to run lean.
Doc Cox
The Nutty Professor
Doc Cox
PostSubject: Re: Headwind making bike run like S!#T   Headwind making bike run like S!#T Icon_minitimeMon Oct 06, 2014 7:56 pm
Good point Sim, had the same problem with a friends Honda 750 that had no airbox, the faster you rode the worse the misfire, was in the south of France at the time so no bike shops around, solved the problem by making some cardboard ram tubes, this was enough to stop the turbulence and misfiring.
PostSubject: Re: Headwind making bike run like S!#T   Headwind making bike run like S!#T Icon_minitimeMon Oct 06, 2014 9:38 pm
I too was wondering the same as Sim, if those conditions are causing 'lean' running .... it would be worth checking the plug colour in the front cylinder when this is happening (or just after).
It could be an issue with the disrupted air-flow around the headstock at higher speeds, where the front filter may be in turbulent flow ...... I'm afraid the 'standard airboxes' that are often hated by us bikers do have some elements of 'design consideration' in respect of airflow.
OR could there be other issues producing similar symptoms ..... such as are the carbs properly 'synched' or balanced ? ...... or any issues in the fuel supply ..... no obstructions .... fuel pump in GWO.
Headwind making bike run like S!#T 3005623951  Yam
PostSubject: Re: Headwind making bike run like S!#T   Headwind making bike run like S!#T Icon_minitimeTue Oct 07, 2014 8:10 am
I would temporarily block the air from being forced in from the front between the tank & frame & see what the result is.
» LUGGAGE RACK
» Will be making my own exhausts
» Foot controls, making them closer?
» Help! 99 Suzuki vz800 making clicking sound!
» Making 2 wire lights into Markers and flashers (3wire)
Headwind making bike run like S!#T Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Headwind making bike run like S!#T Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Headwind making bike run like S!#T Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Headwind making bike run like S!#T Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Headwind making bike run like S!#T Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Headwind making bike run like S!#T Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Headwind making bike run like S!#T Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Headwind making bike run like S!#T Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Headwind making bike run like S!#T Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Headwind making bike run like S!#T Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Headwind making bike run like S!#T Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Headwind making bike run like S!#T Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Headwind making bike run like S!#T Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Headwind making bike run like S!#T Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Headwind making bike run like S!#T Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Headwind making bike run like S!#T Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Headwind making bike run like S!#T Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Headwind making bike run like S!#T Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Headwind making bike run like S!#T Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
Headwind making bike run like S!#T Icon_minitimeby Brim Wed Aug 07, 2024 12:28 pm
