 * Suzuki C800, X-TRE Timing Retard Eliminator * Healtech *
2 posters
* Suzuki C800, X-TRE Timing Retard Eliminator * Healtech * Empty
PostSubject: * Suzuki C800, X-TRE Timing Retard Eliminator * Healtech *   * Suzuki C800, X-TRE Timing Retard Eliminator * Healtech * Icon_minitimeFri Mar 04, 2011 7:27 pm
The one I used was a TRE by Healtech the makers of the gipro and lots more, however there are other manufacturers that make similar products.
My bike was the first of the new model 2010 C800 Intruder's to have an X-TRE by Healtech Electronics fitted. Because the fitting that was done on my bike by myself with the XT-SO1 and the many emails sent back and forth from myself to a very helpful man at Healtech in Hungary called Norbert, extra parts were sent via airmail at no cost to myself.
Basically what the t.r.e. does is it bypasses some of the restriction placed on a lot of modern bikes
It gives a smother throttle response
Improves full throttle response and acceleration
Removes top speed limiter
Automatically switches off in neutral for a smooth idle operation
Simple operation that works out of the box
Low power consumption with automatic standby
works with or without tuning modules
Installs in about 30 minutes
I definitely noticed a difference after fitting this little box, well worth it * Suzuki C800, X-TRE Timing Retard Eliminator * Healtech * 29160
collo
collo
PostSubject: Re: * Suzuki C800, X-TRE Timing Retard Eliminator * Healtech *   * Suzuki C800, X-TRE Timing Retard Eliminator * Healtech * Icon_minitimeMon May 02, 2011 4:45 pm
where did you get your switch live from (on the TRE)? thanks
PostSubject: Re: * Suzuki C800, X-TRE Timing Retard Eliminator * Healtech *   * Suzuki C800, X-TRE Timing Retard Eliminator * Healtech * Icon_minitimeMon May 02, 2011 6:18 pm
To be totally honest I cant remember. it was quite a while ago that I did mine & unfortunately it was a mod I did not do a full write up on, so I cant remember but if you get really stuck I will check where all my wires ect!
Did you specify to the retailer that the TRE was for an M800 & what year it was?
The reason I ask is because I was the first person to put the Healtech TRE on to one of our bikes & Norbert informed me at the time that a slight modification was going to be made to the TRE to make it an easy fit as mine had extra bits flown to me from Hungary (no cost to me) and rather than the XT-S01 standard fit Suzuki TRE that I fitted to my bike with a few modifications done, they would release a direct fit for a fast install
I would advise you to E-mail Norbert and point him in the direction of this post as a reminder just in case yours is not a direct fit
collo
collo
PostSubject: Re: * Suzuki C800, X-TRE Timing Retard Eliminator * Healtech *   * Suzuki C800, X-TRE Timing Retard Eliminator * Healtech * Icon_minitimeMon May 02, 2011 7:20 pm
All sorted one thinks!! every wire we tested when the bike was off was live!!! so attached the device to something near the fuse box!! Also, fitted the FI Tuner instructions were a little hard to follow re actually sending the software to the bike, just emailed Norbert as not 100% it went accross I clicked send and save map and it looked correct, however it is not something im 100% confident FI light is still staying on?? least Im back on the road now.!!
PostSubject: Re: * Suzuki C800, X-TRE Timing Retard Eliminator * Healtech *   * Suzuki C800, X-TRE Timing Retard Eliminator * Healtech * Icon_minitimeMon May 02, 2011 8:22 pm
I could be wrong because I have got nothing I need in front of me but from what I remember all you need to do is
1,.... download and open maps
2,.... Tps - throttle position sensor calibration when asked (simply roll the throttle to fully open and close)
3,.... rpm calibration, rpm is set in the bottom right corner at 000 if I remember rightly. mine had to be set to 22 if I recall properly to be correct at 1100rpm (tickover)
4, ....send maps
all done
» * Suzuki C800, Healtech FI Pro (Installation video and instructions) *
» Suzuki C800 Bobber kit
» * Suzuki C800, De-badge *
» * Suzuki C800, Air Filter Mod * k&N *
» * I Want Apes For Suzuki C800 - Help! *
* Suzuki C800, X-TRE Timing Retard Eliminator * Healtech * Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
* Suzuki C800, X-TRE Timing Retard Eliminator * Healtech * Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
* Suzuki C800, X-TRE Timing Retard Eliminator * Healtech * Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
* Suzuki C800, X-TRE Timing Retard Eliminator * Healtech * Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
* Suzuki C800, X-TRE Timing Retard Eliminator * Healtech * Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
* Suzuki C800, X-TRE Timing Retard Eliminator * Healtech * Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
* Suzuki C800, X-TRE Timing Retard Eliminator * Healtech * Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
* Suzuki C800, X-TRE Timing Retard Eliminator * Healtech * Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
* Suzuki C800, X-TRE Timing Retard Eliminator * Healtech * Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
* Suzuki C800, X-TRE Timing Retard Eliminator * Healtech * Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
* Suzuki C800, X-TRE Timing Retard Eliminator * Healtech * Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
* Suzuki C800, X-TRE Timing Retard Eliminator * Healtech * Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
* Suzuki C800, X-TRE Timing Retard Eliminator * Healtech * Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
* Suzuki C800, X-TRE Timing Retard Eliminator * Healtech * Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
* Suzuki C800, X-TRE Timing Retard Eliminator * Healtech * Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
* Suzuki C800, X-TRE Timing Retard Eliminator * Healtech * Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
* Suzuki C800, X-TRE Timing Retard Eliminator * Healtech * Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
* Suzuki C800, X-TRE Timing Retard Eliminator * Healtech * Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
* Suzuki C800, X-TRE Timing Retard Eliminator * Healtech * Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
* Suzuki C800, X-TRE Timing Retard Eliminator * Healtech * Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
