 Has anyone got a wiring schematic for a VX800?
2 posters
Has anyone got a wiring schematic for a VX800? Empty
PostSubject: Has anyone got a wiring schematic for a VX800?   Has anyone got a wiring schematic for a VX800? Icon_minitimeSun Nov 16, 2014 11:07 am
10amp fuse blew yesterday while I was out, anyway, I have a pdf copy of the manual but the wiring schematic is not a good copy with lines missing and words blurred, has anyone got a schematic for a 1990 VX800, mine is an import from Switzerland (I think) but I think the UK ones are the same, I think its only the US and Jap versions that are different.
I have ordered some spare 10amp fuses but everything seems to be working ok but I just want to check a few things.
PostSubject: Re: Has anyone got a wiring schematic for a VX800?   Has anyone got a wiring schematic for a VX800? Icon_minitimeSun Nov 16, 2014 12:07 pm
Hi Andrew,
Here is the 'For the other models' wiring diagram scanned from my original Suzuki Workshop manual - which yours (& mine) will probably be. The other options being 'For USA & Canada Models' OR 'For W German Model'
Has anyone got a wiring schematic for a VX800? VX-Wirningdiagram_zpsccd329f5
You can pic up the image from photobucket & view it enlarged - you should be able to print it out in A3 format if you have access to such a printer.
Hope that helps !
Has anyone got a wiring schematic for a VX800? 3005623951 Yam
PostSubject: Re: Has anyone got a wiring schematic for a VX800?   Has anyone got a wiring schematic for a VX800? Icon_minitimeSun Nov 16, 2014 12:39 pm
Thanks. Just had a quick look at the drawing, its Fuse 4 that blew:
Fuse 4 (10Amp) - Indicators, Brake Light, Horn, Instrument lights and rev counter, number plate light and side light, I recon with lights on (front 5w, number pate 5w, rear 5w & instruments about 6w), brake light on (21w) and indicators on (2x21w) about 84w which is about 7amps.
Will keep an eye on it, it was p*****g it down so water could have got in I suppose, at least they are dead easy to get at, seat off and that's it.
PostSubject: Re: Has anyone got a wiring schematic for a VX800?   Has anyone got a wiring schematic for a VX800? Icon_minitimeSun Nov 16, 2014 3:58 pm
Hi Andrew,
Yep ... it might just be a 'one-off' fuse blowing - lets hope so.
As you say the fuses are easy enough to get to, but it the problem persists you will have to explore a bit more. Could just be corrosion on an odd connector that you might get away with a quick clean up. I'd guess at looking at the rear lights & indicators first (& would include a check on the rear brake switch).
Hope you've got things sorted for now - Bit worrying if you had lost both the rear & brake lights - as a dozy car driver could run into you !
» VX800 - Wiring issue colours & diagram?
» Led wiring.
» Spotlight Wiring
» wiring colours
» Help with wiring in led lights
Has anyone got a wiring schematic for a VX800? Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
Has anyone got a wiring schematic for a VX800? Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
Has anyone got a wiring schematic for a VX800? Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
Has anyone got a wiring schematic for a VX800? Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
Has anyone got a wiring schematic for a VX800? Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
Has anyone got a wiring schematic for a VX800? Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
Has anyone got a wiring schematic for a VX800? Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
Has anyone got a wiring schematic for a VX800? Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
Has anyone got a wiring schematic for a VX800? Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
Has anyone got a wiring schematic for a VX800? Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
Has anyone got a wiring schematic for a VX800? Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
Has anyone got a wiring schematic for a VX800? Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
Has anyone got a wiring schematic for a VX800? Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
Has anyone got a wiring schematic for a VX800? Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
Has anyone got a wiring schematic for a VX800? Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
Has anyone got a wiring schematic for a VX800? Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
Has anyone got a wiring schematic for a VX800? Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
Has anyone got a wiring schematic for a VX800? Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
Has anyone got a wiring schematic for a VX800? Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
Has anyone got a wiring schematic for a VX800? Icon_minitimeby Brim Wed Aug 07, 2024 12:28 pm
