| Need new tyres | |
hmac Member
| Subject: Need new tyres Sun Mar 01, 2015 11:47 pm | |
| After yesterdays puncture adventure I have decided to treat my bike to a pair of new tyres. Any recommendations, Bike is 97 VZ800 Marauder sizes are 150/90 15 rear and 130/90 16 front. Also wondered if a 170/80 15 would fit on the rear? Have seen a pair of Conti milestones for £200. | |
| Subject: Re: Need new tyres Sun Mar 01, 2015 11:53 pm | |
| www.oponeo.co.uk I have just bought a set of Avon Storm 3D for my VX, but as yet have not been out on them | |
| | | Two-Bears * VZ Guru *
| Subject: Re: Need new tyres Mon Mar 02, 2015 2:19 am | |
| Hello Harry, The VZ800 Marauder does not have a lot of spare clearance under the rear wheel arch area,, the tyre rubbing through the cable for the rear indicator and sidelight/number plate light ( often on the near side ) is fairly common,,, put some weight on the rear and have a look/ try get your fingers in between the wheel arch and tyre,,, with a pillion or rally kit weighing the rear down or if your a fat sod like me, tends to cause wire rubbing with every pot hole/bump you hit .,, most VZ Marauders I worked on I put a scissor jack between the fram cover mountings and wound the jack out gently to force them apart as much as possible when replaceing the rear tyre. so I wouldn't go larger,, some people say they have with no problems so good luck to them,,, I never did. METZELER ME 880 MARATHON,, are the tyres for me,, they transform the handling of the bike and you should be able to grind the pegs on every corner/ rounderbout when you feel like it,, I most certainly did.. I got a price of £189 the pair with free delivery for METZELER and a price of £169 for continental CM2`s & free delivery,, try look here:- http://www.tyrecomp.co.uk/tyres-motorcycle/tyres-all/150-90-r15.htm
Hope this is of some help mate. | |
| | | hmac Member
| Subject: Re: Need new tyres Mon Mar 09, 2015 9:42 am | |
| Based on advice given by Two-Bears and V-Twin I have decided against going for a wider rear tyre and have ordered a pair of Conti Milestones from www.oponeo.co.uk for £164 delivered. Could fit them myself but will probably get my local tyre man to do it. | |
| Subject: Re: Need new tyres Mon Mar 09, 2015 3:48 pm | |
| Wide rear A wide rear tyre means more tread on the road, making the motorcycle want to push through turns instead of go around them. This can lead to a dangerous under-steer condition.
Wide front Wider front tyres will have the opposite effect of a wide rear, and can make the bike more responsive in the corners (over-steer). Caution is advised, however, because a wide front tyre combined with a motorcycle's short wheelbase can make for a twitchy and dangerous ride.
Both narrow Some bikers prefer a narrower tyre on both the front and back, because the tread of the tyre is more pointed and handling is a little more crisp. This can, however, lead to serious instability problems at high speed.
Both wide The best solution is to go wide on both ends, since overall grip will be increased and the handling balance retained. | |
| Subject: Re: Need new tyres | |
| | | | Need new tyres | |
