 water temp light and ignition light
5 posters
dougr1411
dougr1411
water temp light and ignition light Empty
PostSubject: water temp light and ignition light   water temp light and ignition light Icon_minitimeTue Mar 03, 2015 9:08 pm
hi folks I'm pulling my hair out with this fault , the blue water temp and red ignition light come on when I hit a bump ,this is on a 2000 usa imported marauder 800 , it also runs like a bag of crap when these lights are illuminated , if I leave the bike overnight it won't start as something seems to be draining the battery , the battery is only a month or two old  any help will be apprieciated , thanks in advance
PostSubject: Re: water temp light and ignition light   water temp light and ignition light Icon_minitimeTue Mar 03, 2015 9:29 pm
Hi, Does the Fan come on and stay on when the lights illuminate?, even after switching the ignition off, sounds like something shorting out if it only does it when going over bumps.
dougr1411
dougr1411
PostSubject: Re: water temp light and ignition light   water temp light and ignition light Icon_minitimeTue Mar 03, 2015 9:44 pm
the fan only comes on when  bike gets hot not when the lights illuminate , it has got to be a short somewhere but that is the problem I cannot find it lol,,,,, the fan seems to be coming on as it should ..it all started after I had the tank off
PostSubject: Re: water temp light and ignition light   water temp light and ignition light Icon_minitimeTue Mar 03, 2015 9:56 pm
Take tank back off, check all the connections for arcing then clean them and give them a daub of vaseline and see if the problem persists?, Not sure why the battery would go flat though if nothings on? does it stay charged overnight when you avoid bumps and the warning lights don't illuminate?.
PostSubject: Re: water temp light and ignition light   water temp light and ignition light Icon_minitimeWed Mar 04, 2015 12:34 am
Can't quite picture your model of bike, but on my m800 the warning lights are in a little housing which sits on the tank, so you have to unbolt it from the tank, then tie it up out of the way, while you remove the tank. If you have the same type of housing, Maybe the wires to that housing have got strained or pinched in the process?
G.Terence
G.Terence
PostSubject: Re: water temp light and ignition light   water temp light and ignition light Icon_minitimeWed Mar 04, 2015 10:05 am
To establish if you have a short circuit to earth with the ignition OFF disconnect the battery positive and connect a Milliamp meter IN LINE (Meter positive on the battery terminal meter negative on to the disconnected lead ) If you have any reading at all that proves you have a short circuit to earth that is draining your battery. Your reading should be zero.
G,Terence
dougr1411
dougr1411
PostSubject: Re: water temp light and ignition light   water temp light and ignition light Icon_minitimeWed Mar 04, 2015 10:09 am
bigmal my bike has the light cluster on the top of the yoke system by the headlight , unlike yours ,
g Terence I will try that later on today , thanks
rossmofo
rossmofo
PostSubject: Re: water temp light and ignition light   water temp light and ignition light Icon_minitimeFri Mar 06, 2015 9:24 am
My M800 had arcing wires down by the fuse box bracket (down low on left side frame rail) that caused similar symptoms to yours, they had worn through on sharp edge of bracket, could your wiring be getting chaffed/caught around headstock area .
dougr1411
dougr1411
PostSubject: Re: water temp light and ignition light   water temp light and ignition light Icon_minitimeSun Aug 23, 2015 1:09 pm
thanks ross I found the problem , as you say wiring chaffing
» temp light
» IGNITION
» My brake light works, but my tail light does not function..
» HT Ignition Lead
» Temp sensor replacement & cooling fluid
water temp light and ignition light Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
water temp light and ignition light Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
water temp light and ignition light Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
water temp light and ignition light Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
water temp light and ignition light Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
water temp light and ignition light Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
water temp light and ignition light Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
water temp light and ignition light Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
water temp light and ignition light Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
water temp light and ignition light Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
water temp light and ignition light Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
water temp light and ignition light Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
water temp light and ignition light Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
water temp light and ignition light Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
water temp light and ignition light Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
water temp light and ignition light Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
water temp light and ignition light Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
water temp light and ignition light Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
water temp light and ignition light Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
water temp light and ignition light Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
