| IGNITION | |
petetesch Member
| Subject: IGNITION Tue Apr 07, 2015 12:14 pm | |
| Hi all. A good ride yesterday up to Abergaveny, a round trip of about 180 miles. However, I had a small problem after a coffee stop. When trying to restart the bike, turning the key there was no ingnition/oil light, in fact nothing apart from parking and hazard warning lights. After turning the key a few times and checking that the kill switch was in the correct position and every thing else that I could think of eventually the speedo lights came on and she fired up. Has anyone had this problem and how was it resolved. This has happened three times now. HELP!!!! | |
| Subject: Re: IGNITION Tue Apr 07, 2015 12:44 pm | |
| Hi Pete, Sounds like a good ride out, certainly had the weather for it, first things of check would be the side stand switch and connections and the kill switch and connections, clean them and a dab of Vaseline, then see how it goes?. | |
| Subject: Re: IGNITION Tue Apr 07, 2015 11:04 pm | |
| to Sim's comments, remember to include checking contacts on starter switch when looking for clean connections/contacts. WD40, or similar, can be useful to clean plunger switches (such as side stand trip switches) | |
| Subject: Re: IGNITION Wed Apr 08, 2015 7:37 am | |
| This will definitely be a bad connection, sounds like ignition barrel contacts to me. I would say the contacts at the rear of the barrel need cleaning, to give them a proper connection & then slapping some Vaseline on them to keep them good. | |
| Subject: Re: IGNITION Thu Apr 09, 2015 9:52 am | |
| | | petetesch Member
| Subject: Re: IGNITION Thu Apr 09, 2015 10:39 am | |
| Hi Sim. I have taken the kill switch apart, seems pretty clean, removed the side stand switch which is a sealed unit and used WD40 around the plunger. I will be buying a tin of electrical cleaner and working this into the ignition barrel soon. As this is a problem that only happens now and again I feel that it could take a little time to sort out. | |
| Subject: Re: IGNITION Sat Apr 18, 2015 1:23 pm | |
| I have now done mine and the write-up is below.
Thread for cure of issue, as described by Pete. ( LINK ) | |
| | | rossmofo Member
| Subject: Re: IGNITION Sat Apr 25, 2015 11:41 pm | |
| Check the wiring at the fuse box ,mine had rubbed through the insulation against the fusebox bracket , causing all sorts of intermittent problems... | |
| Subject: Re: IGNITION | |
| | | | IGNITION | |
