 HELP!! (oil leaking)
2 posters
HELP!!  (oil leaking) Empty
PostSubject: HELP!! (oil leaking)   HELP!!  (oil leaking) Icon_minitimeThu Jul 02, 2015 2:52 pm
Just got the bike out to clean it ready for a group ride to Boston Bike Night and its pissing oil out of one of the fork seals, pulled the gator up and that split as well. What make have you used and are they ok, I can get Suzuki ones but will take a few days, or are any ok from ebay etc. I need to get them ordered as soon as possible to get her back on the road.
PostSubject: Re: HELP!! (oil leaking)   HELP!!  (oil leaking) Icon_minitimeThu Jul 02, 2015 3:57 pm
My buddy Steve used some fork seals from Pyramid parts & they came with 'lubricant' - did the job nicely.
To dissemble/reassemble the fork legs we made a tool to hold the top of the piston using some large metric nuts on a length of threaded rod (All obtained from a local hardware store). Be careful - there is a copper washer on the bolt holding the bottom of the fork piston - don't loose it or you might get a leak there !
Also worth making some form of protective sleeve from thin poly sheet ore similar to protect the seal as you slide it down the fork-tube. (Prevents any premature damage to the seal if there is any pitting on the fork tubes)
Hope you get sorted Andrew HELP!!  (oil leaking) 184121345
Cheers ....   HELP!!  (oil leaking) 3005623951   Yam
» Leaking rear suspension
» Leaking brake caliper
» Help, bike leaking oily mixture from air intake
HELP!!  (oil leaking) Icon_minitimeby Jack70 Mon Nov 18, 2024 4:35 pm
HELP!!  (oil leaking) Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
HELP!!  (oil leaking) Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
HELP!!  (oil leaking) Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
HELP!!  (oil leaking) Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
HELP!!  (oil leaking) Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
HELP!!  (oil leaking) Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
HELP!!  (oil leaking) Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
HELP!!  (oil leaking) Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
HELP!!  (oil leaking) Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
HELP!!  (oil leaking) Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
HELP!!  (oil leaking) Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
HELP!!  (oil leaking) Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
HELP!!  (oil leaking) Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
HELP!!  (oil leaking) Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
HELP!!  (oil leaking) Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
HELP!!  (oil leaking) Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
HELP!!  (oil leaking) Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
HELP!!  (oil leaking) Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
HELP!!  (oil leaking) Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
