 RR/Battery second opinion
4 posters
RR/Battery second opinion Empty
PostSubject: RR/Battery second opinion   RR/Battery second opinion Icon_minitimeThu Sep 10, 2015 7:52 am
Went to start the VX last night and it was dead so I went out on the GPZ instead. When I got home I put the battery on charge. Just popped out to the garage and it was still dead, so I started it off a car battery. I connected my multi-meter up to the battery and at 4000rpm it was showing 18v affraid
I know what the answer is going to be but I thought I would ask anyway, I am thinking it is new R/R and battery time :(
PostSubject: Re: RR/Battery second opinion   RR/Battery second opinion Icon_minitimeThu Sep 10, 2015 7:21 pm
It should not go above about 14.4 max when charging. So I reckon your battery has been murdered. RR/Battery second opinion 852880
PostSubject: Re: RR/Battery second opinion   RR/Battery second opinion Icon_minitimeThu Sep 10, 2015 7:34 pm
I have just taken the battery off the bike and it was pretty much dry, for a laugh I put my multi-meter on it and it read 12.62v. Filled it up with de-mineralised water and its bubbling away quiet happily!!
With the battery disconnected and my multimeter on ohms, I connected it to the R/R terminals across the +ve wire and the wire from the ignition, with the ignition off it was open circuit and with it on it was a dead short which it what it should do, I did wonder if the voltage sense wire from the ignition switch was a bit flakey which would cause the R/R to ramp up its output and cook everything, so it looks like the R/R is fubared.
Ebay, here I come......again!!
Edit. I know the R/R on my bike is 6 wire (3-phase stator, +ve. Ground and Voltage sense) but most of the replacement R/R on ebay are 5 wire (3-phase stator, +ve and Ground). I'm thinking that I should just convert it to 5 wire. The R/R on my GPZ is 6wire, the voltage sense wire from the ignition switch had a dodgy connection and it cooked itself because the R/R kept upping the voltage because it was getting a low reading back, so I am thinking its not a good idea or necessary.
PostSubject: Re: RR/Battery second opinion   RR/Battery second opinion Icon_minitimeThu Sep 10, 2015 9:01 pm
How much do they work out at Andrew?
PostSubject: Re: RR/Battery second opinion   RR/Battery second opinion Icon_minitimeThu Sep 10, 2015 9:41 pm
One from China £20, Second hand £30-£50, Patten £50-£80 and genuine Suzuki over £100. I am considering a 5wire Mosfet R/R but they are about £80 but then again I may just go second hand to keep it original. I can not afford genuine new Suzuki.
PostSubject: Re: RR/Battery second opinion   RR/Battery second opinion Icon_minitimeThu Sep 10, 2015 9:58 pm
Too risky getting a used one it could be knackered after a few months? got a pattern one on the R6 and it works a treat, half the price of Yamaha's too  Very Happy  Bike manufacturers don't make these parts? they buy them off the people who make them, already rebadged with their logo on it and charge double.
PostSubject: Re: RR/Battery second opinion   RR/Battery second opinion Icon_minitimeThu Sep 10, 2015 10:03 pm
Due the fact that the VX is not that common I am trying to cross reference R/R part numbers to see what else fits, so fat it looks like the VZ800 has the same R/R, but I want to get it right so the GPZ is getting a work out, did 80 miles on her last night.
PostSubject: Re: RR/Battery second opinion   RR/Battery second opinion Icon_minitimeThu Sep 10, 2015 10:24 pm
Seems to be the same part number for the VZ R/R as the VX, not uncommon to share parts throughout the range.
Doc Cox
The Nutty Professor
Doc Cox
PostSubject: Re: RR/Battery second opinion   RR/Battery second opinion Icon_minitimeSat Sep 12, 2015 8:36 am
When I built my first Virago back in "84"  wheelie No Ebay then, needed a voltage regulator so looked at the part no,s and found the LC 250 had the same part no. but with the prefix "LC" whereas the Virago was XV and bought one secondhand from our local bike breakers and it worked perfectly, shame the guy had removed the cam followers and not told me !!!
PostSubject: Re: RR/Battery second opinion   RR/Battery second opinion Icon_minitimeSat Sep 12, 2015 12:58 pm
She's alive. The battery survived being boiled dry, after topping it up and charging it started first time. I got given a R/R of a Honda 1000, chopped the plugs off and Spliced/Soldered the wires. Job done, I am now in the pub having a pint of XXXB waiting for my dinner :)
» Battery Died
» Battery
» Flat Battery Help
» New Battery For C50T
» Lithium battery
RR/Battery second opinion Icon_minitimeby MTB59 Yesterday at 6:29 pm
RR/Battery second opinion Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
RR/Battery second opinion Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
RR/Battery second opinion Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
RR/Battery second opinion Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
RR/Battery second opinion Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
RR/Battery second opinion Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
RR/Battery second opinion Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
RR/Battery second opinion Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
RR/Battery second opinion Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
RR/Battery second opinion Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
RR/Battery second opinion Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
RR/Battery second opinion Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
RR/Battery second opinion Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
RR/Battery second opinion Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
RR/Battery second opinion Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
RR/Battery second opinion Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
RR/Battery second opinion Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
RR/Battery second opinion Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
RR/Battery second opinion Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
