| | Heater Grips for VL800 | |
lepidge Member
| Subject: Heater Grips for VL800 Sun Jan 03, 2016 6:36 pm | |
| Still got a wee bit of money left over from unwanted Christmas pressy and have always fancied heated grips. I have found the following 2 types and would like anyone's opinion or other options
1. Heat Demon External Grips
http://www.windingroads.co.uk/shop/product.php/896/heated-grips-heat-demon
https://www.youtube.com/watch?v=6Qtzh8vC-dk
2. Oxford Premium Heated Grips
https://www.sportsbikeshop.co.uk/motorcycle_parts/content_rev/101831
https://www.youtube.com/watch?v=qxZV7fDAIyE | |
| Subject: Re: Heater Grips for VL800 Sun Jan 03, 2016 6:57 pm | |
| I've got the Oxford touring ones on my Bandit (same as those probably) and they work well, they switch off automatically after 10 mins if you forget and leave them on, Mick & Alan have the Oxford Cruiser heated grips and they suit the cruiser better imo because they have chrome ends and a chrome roller wheel for the varying temps. http://www.ebay.co.uk/itm/Oxford-Cruiser-25mm-HOT-GRIPS-Motorbike-Motorcycle-Heated-HotGrips-/401013760490?hash=item5d5e4861ea:g:fq8AAOSw5VFWJgMC | |
| Subject: Re: Heater Grips for VL800 Mon Jan 04, 2016 4:48 pm | |
| I have used Oxford and found the excellent. | |
| | | Ken1964 Valued Member
| Subject: Re: Heater Grips for VL800 Mon Jan 04, 2016 7:34 pm | |
| I would love heated grips but don't want to remove my fancy looking grips. | |
| | | lepidge Member
| Subject: Re: Heater Grips for VL800 Sat Jan 09, 2016 1:55 pm | |
| Subject: Re: Heater Grips for VL800 Sat Jan 09, 2016 10:48 pm | |
| - Ken1964 wrote:
- I would love heated grips but don't want to remove my fancy looking grips.
If you go with the internal fitment Heat Demons, they fit inside the bars so you wouldn't need to bin your fancy grips mate. Martin ( Smart ) has these fitted to his bike and raves about them. Lepidge - The Oxford Cruiser grips are a larger diameter than the touring ones .... suitable for 1" bars. Sim is right, they have a chrome rotary controller which is very easy to use with a gloved hand. Wouldn't be without mine ! | |
| | | ippikin Member
| Subject: Re: Heater Grips for VL800 Sat Jan 09, 2016 11:13 pm | |
| | | lepidge Member
| Subject: Re: Heater Grips for VL800 Tue Jan 12, 2016 6:15 pm | |
| - ippikin wrote:
- Might want to consider these....... I fitted them a few years ago and they are great, a really easy fit and you can keep your original grips. Wired to the 12v output in the headlight shell. heated grips - Symtec Heated Grips Fitted To VZ800
Hi Grob Thanks for your detailed install guide. It is really helpful. I think I am going to go for the new version of the Heat Demon as per link below from `Windingroads`. I think the only difference is the new 4 setting controller switch for the handle bar thus not needing the high/low switch! http://www.windingroads.co.uk/shop/product.php/896/heated-grips-heat-demon | |
| Subject: Re: Heater Grips for VL800 Tue Jan 12, 2016 8:24 pm | |
| Hi lepidge, will you let us know how they are for fitting under the grips? I quite fancy some on the hd if I can retain the stock grips. | |
| | | lepidge Member
| Subject: Re: Heater Grips for VL800 Wed Jan 13, 2016 5:06 pm | |
| - simbo wrote:
- Hi lepidge, will you let us know how they are for fitting under the grips? I quite fancy some on the hd if I can retain the stock grips.
Hi Simbo, will do but not on my urgent list. When I do get & fit them on I will let you know! | |
| | | TaurusTuga Member
| Subject: Re: Heater Grips for VL800 Thu Jan 14, 2016 2:41 pm | |
Hi Sim, now it's my turn to give you a hand : http://www.revzilla.com/motorcycle/symtec-heat-demon-metric-internal-heated-grips http://www.ebay.com/itm/Symtec-211056-Heat-Demon-H-D-Grip-Warmers-/231792791012 http://www.ebay.com/itm/New-2015-Heat-Demons-Grip-Heater-Harley-Black-Right-Mount-All-Models-Bar-Sizes-/371119436719 Or one of this must cheaper and i think will do the job, of course not so "technical pro functions, wires, cables and good looking" : http://www.ebay.co.uk/itm/Universal-Motorcycle-ATV-Handlebar-Grips-Heated-Wrap-Hand-Warmer-W-Rocker-Switch-/361106978341?hash=item5413a73625:g:up8AAOSwBP9UXHjK | |
| | | | lepidge Member
| Subject: Fri Mar 25, 2016 8:50 am | |
| | | lepidge Member
| Subject: Re: Heater Grips for VL800 Fri Mar 25, 2016 8:56 am | |
| I have finally found time to fit the heaters. Quite straight forward to install but a few little amendments made,
The heaters are great and I now think I will use heated grips from now on. Level 3 out of 4 is just about right as level 4 can be a bit too warm! | |
| Subject: Re: Heater Grips for VL800 Fri Mar 25, 2016 9:14 pm | |
The heaters are great and I now think I will use heated grips from now on. Level 3 out of 4 is just about right as level 4 can be a bit too warm! Good to hear you're liking them Lepidge they're certainly worth the money in the cooler months | |
| Subject: Re: Heater Grips for VL800 | |
Latest topics | » Hello by PETE.MARTIN Mon Sep 02, 2024 12:19 pm
» New Member by LordSweeteffall Fri Aug 23, 2024 1:58 am
» Howdy by Philly_pa800 Fri May 24, 2024 8:16 pm
» VZ 800 K7 by Barwise92 Tue May 21, 2024 2:53 pm
