 is the finale drive correct for my bike
5 posters
ficus4p
ficus4p
is the finale drive correct for my bike Empty
PostSubject: is the finale drive correct for my bike   is the finale drive correct for my bike Icon_minitimeThu Mar 03, 2016 6:36 pm
I got a 2010 suzuki m 800, and Im thinking about doing the vs 1400 final drive mod as alot of my driving is at motorway speeds.
Found a guy selling this
is the finale drive correct for my bike Kopi_a10
https://servimg.com/view/19432258/1
will this fit my 2010 model an how much of this do I need.
He is selling the final drive for 130 punds fair price ?
PostSubject: Re: is the finale drive correct for my bike   is the finale drive correct for my bike Icon_minitimeThu Mar 03, 2016 6:54 pm
yes it will fit & all you really need is the diff section & the spacer which if you read the section about fitting will explain what else needs to be done etc ok?
PostSubject: Re: is the finale drive correct for my bike   is the finale drive correct for my bike Icon_minitimeThu Mar 03, 2016 7:03 pm
Good price! make sure it's not a 750 or 800 drive and is definitely from a 1400, you can tell from looking at the plate with the big seal in it on the other side.
ficus4p
ficus4p
PostSubject: Re: is the finale drive correct for my bike   is the finale drive correct for my bike Icon_minitimeThu Mar 03, 2016 7:10 pm
just wanted to be sure before I spend the cash =)
ficus4p
ficus4p
PostSubject: Re: is the finale drive correct for my bike   is the finale drive correct for my bike Icon_minitimeThu Mar 03, 2016 7:12 pm
like this ?
https://servimg.com/view/19432258/2
he is only selling me the final drive for 130 the swing arm is not a part of the deal.
PostSubject: Re: is the finale drive correct for my bike   is the finale drive correct for my bike Icon_minitimeThu Mar 03, 2016 7:16 pm
Yes look at the back plate, I should talk eh Sim? Look at the section here about the diff & look at a certain picture that contains a number printed into the alloy back plate as this is the way you'll know that it is the correct unit! I got stuffed by a seller & had to buy another correct diff which was very costly all round as you can imagine!
PostSubject: Re: is the finale drive correct for my bike   is the finale drive correct for my bike Icon_minitimeThu Mar 03, 2016 7:20 pm
The number is 38B (B for Bravo) so if it aint got that it's not a VS1400 unit! ! ! ! !
PostSubject: Re: is the finale drive correct for my bike   is the finale drive correct for my bike Icon_minitimeThu Mar 03, 2016 7:27 pm
I can't tell from that picture? if it's got "38B" on that plate it's from a 1400, I think the two bolts nearer the shaft are bigger too (from memory) so it looks like it is, you'll need the metal gasket plate from between the drive & swingarm too  is the finale drive correct for my bike 3498837457
this is mine for you to compare.
is the finale drive correct for my bike IMAG0873_zpsjrscy6dk
PostSubject: Re: is the finale drive correct for my bike   is the finale drive correct for my bike Icon_minitimeThu Mar 03, 2016 7:34 pm
that's why I was telling the lad to read the write up for more info on what he wants Sim.
ficus4p
ficus4p
PostSubject: Re: is the finale drive correct for my bike   is the finale drive correct for my bike Icon_minitimeThu Mar 03, 2016 7:40 pm
metal gasket plate ?
ficus4p
ficus4p
PostSubject: Re: is the finale drive correct for my bike   is the finale drive correct for my bike Icon_minitimeThu Mar 03, 2016 8:05 pm
he confirmed the 38B, guess the money is changing hands soon.
PostSubject: Re: is the finale drive correct for my bike   is the finale drive correct for my bike Icon_minitimeThu Mar 03, 2016 8:07 pm
There's a metal plate between the drive and swing arm where it connects together, you'll need it, the holes are spaced wider for the 1400 drive.
is the finale drive correct for my bike IMAG0874_zpsbtntn3bv
PostSubject: Re: is the finale drive correct for my bike   is the finale drive correct for my bike Icon_minitimeThu Mar 03, 2016 8:08 pm
Good advice Peter  is the finale drive correct for my bike 3498837457
ficus4p
ficus4p
PostSubject: Re: is the finale drive correct for my bike   is the finale drive correct for my bike Icon_minitimeThu Mar 03, 2016 8:09 pm
Sir, you are a life saver =) The deal is done
ficus4p
ficus4p
PostSubject: Re: is the finale drive correct for my bike   is the finale drive correct for my bike Icon_minitimeThu Mar 03, 2016 8:11 pm
getting the final drive, spacer and metal gasket for 130 =)
ficus4p
ficus4p
btw why do you need the spacer ?
PostSubject: Re: is the finale drive correct for my bike   is the finale drive correct for my bike Icon_minitimeThu Mar 03, 2016 8:16 pm
You will need to machine metal off it to fit the narrower drive unit or otherwise you'll need to modify your own spacer. You'll need to modify the shaft as well from YOUR 800 unit as you will see on the VS1400 diff swap pages.
PostSubject: Re: is the finale drive correct for my bike   is the finale drive correct for my bike Icon_minitimeThu Mar 03, 2016 9:24 pm
The spacer sets the distance between the wheel and the drive, have a read of this write up for some insight to what is needed  is the finale drive correct for my bike 3498837457
www.suzuki800.com/t2228-vs1400-drive-shaft-modification-how-to-thread
ficus4p
ficus4p
PostSubject: Re: is the finale drive correct for my bike   is the finale drive correct for my bike Icon_minitimeSun Mar 06, 2016 6:56 pm
final drive is bought, now I just need to find myself a used drive shaft, cheap! is the finale drive correct for my bike 4176454701
PostSubject: Re: is the finale drive correct for my bike   is the finale drive correct for my bike Icon_minitimeSun Mar 06, 2016 7:06 pm
Use the one on your bike in the mean time and look for a spare at your leisure.
ficus4p
ficus4p
PostSubject: Re: is the finale drive correct for my bike   is the finale drive correct for my bike Icon_minitimeSun Mar 06, 2016 7:12 pm
honestly I really dont want to use my own... my bike is still under warrenty, so not changing the drive before that runs out(5 months left).
Also Im thinking about only keeping my m 800 only a few years, so I want to be able to change the bike back for sale. I need something more long distance friendly
is there anything I need to know when looking for one ?
PostSubject: Re: is the finale drive correct for my bike   is the finale drive correct for my bike Icon_minitimeMon Mar 07, 2016 5:52 pm
Good for you Sir, it will seem like a new bike once fitted.
PostSubject: Re: is the finale drive correct for my bike   is the finale drive correct for my bike Icon_minitimeMon Mar 07, 2016 6:59 pm
You'll find most of them are advertised with the 800 drive as well, could be worth ringing the breaker/ seller and seeing if they'll sell you just the shaft? other than that? not much really, VL800 years 2001 to present and VZ800 2005 to present share the same shaft just to broaden your search a little.
ficus4p
ficus4p
PostSubject: Re: is the finale drive correct for my bike   is the finale drive correct for my bike Icon_minitimeMon Mar 07, 2016 7:09 pm
funny, I thought that the there would be alot of shafts for sale, when its used in so many bikes but not really. Most is from the US
PostSubject: Re: is the finale drive correct for my bike   is the finale drive correct for my bike Icon_minitimeTue Mar 08, 2016 12:06 pm
They are there but never when you make the decision to fit one, just keep looking every week.
» anybody ever thought to switch to belt-drive primary-drive?!
» Rear drive 'spider' cush drive thingy
» Final drive
» VS1400 Drive & Shaft Modification ......................How To Thread.
» shaft drive
is the finale drive correct for my bike Icon_minitimeby Anarchy2007 Tue Nov 12, 2024 4:19 pm
is the finale drive correct for my bike Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:26 pm
is the finale drive correct for my bike Icon_minitimeby DucatiDiag Mon Nov 11, 2024 6:03 pm
is the finale drive correct for my bike Icon_minitimeby wayne phillips Tue Nov 05, 2024 1:56 am
is the finale drive correct for my bike Icon_minitimeby Reidzzz Wed Oct 09, 2024 7:32 am
is the finale drive correct for my bike Icon_minitimeby zmaj_od_sipova Tue Sep 24, 2024 2:13 pm
is the finale drive correct for my bike Icon_minitimeby LordSweeteffall Mon Sep 23, 2024 9:44 pm
is the finale drive correct for my bike Icon_minitimeby watsonchuck1 Sun Sep 22, 2024 3:00 am
is the finale drive correct for my bike Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:59 pm
is the finale drive correct for my bike Icon_minitimeby Richard Jordan Fri Sep 13, 2024 11:56 pm
is the finale drive correct for my bike Icon_minitimeby DaniloPeternek888 Tue Sep 10, 2024 5:51 pm
is the finale drive correct for my bike Icon_minitimeby Badger Mon Sep 02, 2024 10:44 am
is the finale drive correct for my bike Icon_minitimeby henrikndk Thu Aug 29, 2024 5:29 am
is the finale drive correct for my bike Icon_minitimeby FrostyMug Sun Aug 25, 2024 8:07 pm
is the finale drive correct for my bike Icon_minitimeby Doc Cox Thu Aug 22, 2024 7:45 pm
is the finale drive correct for my bike Icon_minitimeby chrismason68 Fri Aug 16, 2024 1:57 pm
is the finale drive correct for my bike Icon_minitimeby Steve17hmr Thu Aug 15, 2024 4:23 pm
is the finale drive correct for my bike Icon_minitimeby JohnnyFive13 Wed Aug 14, 2024 2:44 pm
is the finale drive correct for my bike Icon_minitimeby Popshot Tue Aug 13, 2024 8:30 pm
is the finale drive correct for my bike Icon_minitimeby Brim Wed Aug 07, 2024 12:28 pm
